Old 08-10-2015, 07:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
what wheels fit? 6 lug
Old 06-23-2010, 01:15 AM
Deerkiller9991's Avatar
Deerkiller9991
Deerkiller9991 is offline
Post what wheels fit? 6 lug
i have the 6 lug rims on my truck. what other vehicles have the same bolt pattern to swap out? ie dodge, chevy, ford, etc and what models?
Old 06-23-2010, 01:22 AM
95_318SLT's Avatar
95_318SLT
95_318SLT is offline
From FAQ:
Wheel bolt pattern:
1987-1990 5 x 4.5" (lots use this bolt pattern from Chevy's to Toyota)
1991-2009 6 x 4.5", 6 x 114.3 (rare, hard to find)
Wheels that will work for the 6x 4.5:
91-04 Dakotas, 98-03 Durangos, All Vipers, and 05-08 Nissan Pathfinder/Frontier/Xterra, 04-05: Cadillac SRX, Suzuki Equator 08-09.
Bolt pattern all makes and years:
http://www.okoffroad.com/editorial-boltpattern.htm
http://www.discountedwheelwarehouse...._Reference.cfm
Old 06-23-2010, 01:29 AM
Deerkiller9991
thanks, didnt look there
Old 01-04-2023, 10:51 AM
96dakotasport3.9's Avatar
96dakotasport3.9
96dakotasport3.9 is offline
will these wheels fit my 1996 dodge dakota
these are off of a 2003-2004 dodge durango. they are 16 x 7 inch. i have 16 x 7 black steel wheels on it right now.
Old 01-07-2023, 09:17 AM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
Measure the holes. One measurement center to center across the diameter then in between each hole. IDK the diameter measurement you want but the hole to hole should be 4.5". You may just have to jack your truck up and take a wheel off to see if it fits.
Old 01-07-2023, 11:13 AM
96dakotasport3.9
do you think it would hit the upper control arm.
Old 01-07-2023, 01:41 PM
onemore94dak
I have no idea. Try the links up above and see if the info is there.
Quick Reply: what wheels fit? 6 lug
