Rusted Strut Tower repair Kit Question
Old 06-13-2010, 06:41 PM
Robertsr's Avatar
Robertsr
Robertsr is offline
Default Rusted Strut Tower repair Kit Question
I have looked all over for this answer. So I have a 2000 caravan and the strut tower needs the repair kit terribly. However before I go and order it can anyone possibly tell me what tools I'll need to do the job? I am going to use the glue and already have the gun. I could really use some step by step on this. Also I have no idea how to remove the cowling so I can get to the strut. Thanks so much.
Old 06-13-2010, 07:50 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
Here is the TSB for the strut tower repairs for 1996 thru 2000 ns minivans.
NUMBER: 23-044-02
GROUP: Body
DATE: Oct. 14, 2002
SUBJECT:
NS Strut Tower Corrosion
OVERVIEW:
This bulletin involves correcting a corrosion staining, surface corrosion, or corrosion
perforation condition at the top of the strut tower/s.
MODELS:
1996 - 2000 NS Town&Country/Voyager/Caravan
SYMPTOM/CONDITION:
Cosmetic corrosion or perforation at upper strut tower/s usually between the strut
and upper load path beam inner panel (inner fender).
DIAGNOSIS:
Inspect left and right strut towers for condition. If corrosion is present, perform
one of the following repair procedures.
NOTE: ANY UNDER HOOD LABELS REQUIRING REPLACEMENT DURING THESE
REPAIRS SHOULD BE OBTAINED PRIOR TO BEGINNING REPAIRS.
PARTS/MATERIALS REQUIRED:
Qty. Part No. Description
1 05080009AA Strut Cap (Left Side)
1 Kit 05086513AA NS Strut Cap Installation Kit
(Left Side).
1 05080008AA Strut Cap (Right Side)
1 Kit 05086512AA NS Strut Cap Installation Kit
(Right Side).
11/2 - 2 Cartridges
Per Side
05083855AA Mopar Structural Adhesive
EQUIPMENT REQUIRED:
W-7804R 90-degree drill motor (PSE)
W-861 High-speed air cutter (die grinder) (PSE)
23-044-02 -2-
05016570AA Adhesive dispenser (MOPAR)
W-AK175 ACH Power set rivet gun (PSE)
REPAIR DESCRIPTION:
Repair A - Cosmetic corrosion removal and the application of corrosion
resistant materials and/or primers and topcoats.
Repair B - Corrosion perforation removal and installation of 1 or 2 new cap/s and kit/s.
NOTE: REPAIR PROCEDURES ARE OUTLINED IN THE INSTRUCTION
SHEET INCLUDED IN THE PARTS KITS.
Quick Reply: Rusted Strut Tower repair Kit Question
