LED Tail Light Bulbs???
Ok, so with the nightshade on my tails, it pretty apparent that i need some brighter tails. I need help tho. When it came to my HID's, i went with Twiggy cause all his stuff was plug and play and all the resistors/capacitors were already installed. Now with my tails i'm lost. If i go the LED route, i need load resistors. superbrightleds.com has the bulbs and resistors. Can anyone tell me how man resistors i need? 1 per bulb? and how do i wire these resistors in when i only have 3 wires at the plug going into the circuit board into the tail light? Do i then only need 1 resistor at that plug? If anyone can give me a hand or do a quick write up i'd appreciate it. I searched but "LED" being a 3 letter word wont allow.
As far as I know, take it how you want to, if you do LED push in and turn bulbs, yes you need a resistor on each power wire going to the turnsignal bulb or it will blink very fast.
here is a chart to pick out what resistor you need to pick up at Radio Shack
http://www.superbrightleds.com/cgi-b...2Fled_info.htm
LED's are NOT going to be any brighter than the halogens you have unless you get the chip type led's that have like 60 led's per bulb. Even with the 60 count, the Lumen output will still be less than the current halogen bulbs you are currently using.
LED's alter the color of the light to a cooler white color which looses light ouput. So, you can have a brighter halogen bulb that has a slight hue of yellow to it or a clean white looking bulb that has less output.
Big misconception that LED's have more ouput than halogens.
They might be those 60packed bulbs, but all I can say is that LED's ARE NOT brighter than Haliogens as of yet with todays technology. The chip type Led's are the brightest but still have nowhere near the Lumen ouput of Halogens.
I think I know who you are reffering to and I believe the same guy installed Halo's in his taillights which is what produces the brightness, not the led bulbs.
I'm going to school right now for this stuff and it has been talked about in class. I'm not just puling this outt my ***. Had no intentions of rhyming there...lol
Again, LED produces a whiter light that APPEARS brighter, but actually isn't. Still provides less lumen output ofcourse unless there is like 1,000led's per 1 halogen bulbs..duhh..
You need a resistor for each bulb. There are guys who use 3157 as well.
