Changing gear ratios 01 ram
Old 05-29-2010, 11:42 PM
Nortzy's Avatar
Nortzy
Nortzy is offline
Default Changing gear ratios 01 ram
how might i go about changing the gear ratio in a 2001 ram 1500 RWD, it's 3.55, i am thinkin about a little higher... don't know about 4.10... how might i go about it? if i have to i will take it to the dealer. but is it possible to do it myself?
Old 05-29-2010, 11:53 PM
GeorgiaDodge's Avatar
GeorgiaDodge
GeorgiaDodge is offline
its possible to do it yourself if you have done rearends before or know somebody that has, you have to be careful about shims. i probably wouldnt go to a 4.10 im personally looking at upgrading to a 3.92 for my 2wd. im sure others will chime in shortly
Nortzy's Avatar
Nortzy
Nortzy is offline
i pretty much just want 3.92... if i have to go to the dealer whats the average labour time?
Old 05-30-2010, 12:03 AM
GeorgiaDodge
i imagine the dealer would hit you pretty hard. probably around 1500-2000 is my guess. I used to build swamp buggy jeeps so i know how to change gears. they are a pain to do it right but if you do it wrong your in for some money
Old 05-30-2010, 01:05 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
you have to set the lash right?
also i have 4.10's and running 265/75/16 10 ply tires, and its a perfect combo IMO....
Old 05-30-2010, 01:08 AM
GeorgiaDodge
yeah you have to set the lash, any grinding is bad news right off the bat
Old 05-30-2010, 01:10 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
how do you set the lash? what tools are needed? if you dont mind informing me
sorry to OP, I'm not trying to jack the thread
Old 05-30-2010, 01:24 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
The dealership will rape you. Don't go to them, you can get just a good of job done by a quality mechanic that you trust. Make sure they are good and you trust them, because there are a lot $tealerships and mechanics out there that will screw the job up.
For labor, you're talking $300-$400 for the rear axle usually.
Old 05-30-2010, 08:01 AM
greenmachine's Avatar
greenmachine
greenmachine is offline
i paid someone to do mine 800 for parts and labor. i got the mopar lsd.
Old 06-02-2010, 11:31 AM
tuski's Avatar
tuski
tuski is offline
A friend of mine just put new gears and a posi in his camero, he had some help from his dad but he said it wasn't all that hard. Just need to take your time and do everything correct and not skip any details.
Quick Reply: Changing gear ratios 01 ram
