How to tell what class your hitch is?
Old 05-22-2010, 10:39 PM
BigRedRam95's Avatar
BigRedRam95
BigRedRam95 is offline
Default How to tell what class your hitch is?
Does anyone know how to tell what class the hitch on my truck is? It does not have a sticker like most so I cant tell. I am going to buy a 5000LB camper and neet to know if my hitch is rated for that kind of weight.
Old 05-22-2010, 10:47 PM
GeorgiaDodge's Avatar
GeorgiaDodge
GeorgiaDodge is offline
i believe there are 3 classes, could be wrong and probably am(i will get corrected). class A,B,C. i think A is light duty(under3,000 lbs), Class B under 6000 lbs. and C under 10,001 Lbs. there are a couple of sizes as far as receivers go. dont know what weight they do. maybe someone will chime in.
Old 05-22-2010, 11:30 PM
There SHOULD be a label, either stamped steel, riveted to the hitch or, numbers stamped right into the crossbar of the hitch. It will have a great deal of useful information for ya.
Old 05-22-2010, 11:31 PM
lblair04's Avatar
lblair04
lblair04 is offline
Im pretty sure all 2" receiver style hitches will be at least a class III/IV. Not sure the weight that class can carry tho.
Old 05-22-2010, 11:39 PM
Class III is: WC GTW - Up to 5,000 lbs. (max weight)
WC TW - Up to 500 lbs (tongue weight)
Old 05-23-2010, 05:00 PM
BigRedRam95
I do have a 2x2 inch recever. I got under my truck today and there was no tags, sickers, or ingravings. Any more ideas.
Old 05-23-2010, 07:00 PM
Do you know if it was factory installed?
Aside from that, I haven't a clue. Might be better off just going and purchasing something that you KNOW will work, rather than taking a chance of having to wonder whose trailer that is passing you, only to realize it is yours........
Old 05-23-2010, 07:10 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
I would bet 3.
Old 05-23-2010, 08:07 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
If it's a 2" receiver, it's a III or IV. Class V has a 2.5" receiver. On a half-ton truck you're limited to Class III loads anyway because the suspension cannot handle Class IV loads.
Old 05-23-2010, 08:59 PM
BigRedRam95
well I will never pull the camper with out a weight distributing hitch and sway bars so I should be ok right.
Could someone post a pic of the hitch on there 1/2 ton?
Quick Reply: How to tell what class your hitch is?
