2002 Ram 1500, Trans Slips, P2706 code
Old 05-22-2010, 03:44 PM
lynster's Avatar
lynster
lynster is offline
Default 2002 Ram 1500, Trans Slips, P2706 code
2002 Dodge Ram 1500
4.7L engine
45RFE 4-speed automatic
Problem:
Occasional slippage
Check engine light (the MIL) comes on
OBD-II scanner reads code P2706: MS Solenoid (Multi-Shift)
Seems to be intermittant, but getting worse. There are times when the vehicle performs normally and the error clears itself.
Vehicle has ~120k miles with original fluid. (yes, I feel guilty about this...)
Fluid appears very clean, does not smell burned, and is at proper levels, cold and hot.
Fault code appears to point at a defective MS Solenoid assy (inside the tranny), or,
a defective TCM module
Some questions:
1. Is the Solenoid assy a common failure? or might this more commonly be the TCM?
2. As viewed from underneath the Trans, it appears the Solenoid assy is mounted on top of the valve body. One must assume the valve body needs to be removed. Can this be done in my driveway (Trans still in the truck) without danger of critical parts dropping out?
3. Would changing the fluid and filters resolve this?
Any help would be appreciated. I'd like to have a better idea of how to approach this before I start dumping a lot of $$ for a fix.
Old 05-22-2010, 04:07 PM
OlDirtyJohn's Avatar
OlDirtyJohn
OlDirtyJohn is offline
Originally Posted by lynster
2002 Dodge Ram 1500
4.7L engine
Problem:
Occasional slippage
Some questions:
that sounds like a faulty solenoid to me. i have heard of them failing before. you are correct that it is located above the VB. so you will need to drop the pan, remove both filters, and drop the VB. it is very easy to do, just messy without having a drainplug on the pan. only thing you will have to worry about is getting the shift linkage shaft lined back up properly (not hard at all). personally, i would give the solenoid a shot, and replace fluid/filters while you are in there. reason being, if you do fluid and filters and it doesnt fix it and you need to replace solenoid. you will have to drop the pan again, and waste 6-7 qts of fluid.
here are some pics for your reference.
tranny with pan off
filters removed:
unplug TRS connection on outer driver side of tranny:
remove valve body, its held in place by about 6-8 hex bolts
solenoid will be attached to the top of the VB. sorry dont have a good pic of this, sorry.
Old 05-27-2010, 06:23 PM
lynster's Avatar
lynster
lynster is offline
Really appreciate the reply and the pics... I'll be getting into this as soon as I can.
Wow... these solenoids ain't cheap !!
Old 05-27-2010, 07:59 PM
OlDirtyJohn
also, to take the solenoid off of the valve body, just take 15 of the torx bolts off from directly underneath the solenoid. then it will pop right off. if you have trouble with that, let me know, and i will try to get you some more pics.
Quick Reply: 2002 Ram 1500, Trans Slips, P2706 code
