Moonroof/Sunroof
Old 05-11-2010, 09:33 PM
dakotajac97's Avatar
dakotajac97
dakotajac97 is offline
Default Moonroof/Sunroof
Anyone here ever install their own sunroof? I have a 99 dakota and would like to put one in. There are kits available for new ones that run $500-700. I thought maybe I could get one from a dakota or durango in the junk yard that has one as a cheaper alternative. Any thoughts or experience with this?
Old 05-11-2010, 09:47 PM
01SilverCC's Avatar
01SilverCC
01SilverCC is offline
Yes I have installed sunroofs, but never in a Dakota. I would not get a used one, it would very likely have a very bad leak problem. Best bet is to find a truck accesooies shop or independent car audio/accessories store that would have a better price, or maybe just have it installed. If you have the roof console with the computer and all that, a sunroof won't be compatible. If you don't have the console, you will still have to either relocate or lose the dome light.
Jimmy
Old 05-11-2010, 11:18 PM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
We had one installed in our 99 ford f250 I think it was about 1,000 for the dealer to do it. Personally I would have a pro install it you def dont want a hole that big leaking. Its possible to install yourself but you will need to be very careful.
Old 05-12-2010, 08:36 AM
McNasy's Avatar
McNasy
McNasy is offline
if you go to webasto.com, they should be able to find a roofer in your area. depending on the type of sunroof you want will depend on the dollars you spend. i charge dealers $799 for a top sliding electric roof and $1100 for an internal sliding roof. remember you get what you payfor. a lap full of water is not worth the $300 you saved on a cheap roof
