Oil leaks on 5.7 hemi
Old 05-11-2010, 09:30 PM
bies08's Avatar
bies08
bies08 is offline
Default Oil leaks on 5.7 hemi
I changed my oil about a month and a half ago and filled it up to level. I parked my truck yesterday around 7, got in it tonight about 6 and when i got back to my garage i found a oil leak about 4 inches wide. Wondering where it could come from or if there is a common oil leak on the dodges. It's an 03 dodge 2500 5.7 hemi 4x4.
Old 05-11-2010, 09:42 PM
Duroc's Avatar
Duroc
Duroc is offline
Hopefully its just a sending unit or something but you are going to have to get under there and do some better investigation work for someone to help you out better.
Old 05-12-2010, 07:25 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You must be new to vehicles and engines altogether. ALL engines no matter who makes then will leak eventually. The best thing you can do now is get some engine cleaner or degreaser and spray it on the leak and engine to clean it and then look to see where the leak is coming from. Oil leaks can be very small but spread oil around a lot so it is important to clean it and then look for the leak.
Old 05-12-2010, 08:31 AM
rocket23's Avatar
rocket23
rocket23 is offline
^^^^x2!! A 4 inch cicle sounds like oil plug. Or filter. did you lube the gasket?? Sorry had too ask. It was an oil change and that is what you worked on. imo.
Quick Reply: Oil leaks on 5.7 hemi
