Overfilled ATF now transmission stuck in low
Old 04-30-2010, 09:31 PM
eviltwin67's Avatar
eviltwin67
eviltwin67 is offline
Default Overfilled ATF now transmission stuck in low
I didn't realize that I overfilled the ATF fluid until after I was driving and the transmission wouldn't shift into a higher gear. I siphoned out the excess so the level is back to normal, so is there a way to reset it to shift normally?
Old 05-01-2010, 08:54 PM
TJeepman's Avatar
TJeepman
TJeepman is offline
So what's it doing now?
- staying in low?
- in limp mode?
- shifting normally but rough shifts?
Old 05-02-2010, 08:52 AM
eviltwin67's Avatar
eviltwin67
It stays in the same gear instead of shifting to a higher gear like it should when you hit 40+mph and it does show P0755.
Old 05-02-2010, 10:08 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
DodgeCaravan2010SXT is offline
did a google on code says something on the solinoid pack.
Old 05-02-2010, 03:55 PM
2002caravan's Avatar
2002caravan
2002caravan is offline
So you added too much or you drained and refilled?
When I did my last tranny service it took a few miles to get it working right. My guess was air bleeding out.
Old 05-02-2010, 08:34 PM
eviltwin67's Avatar
eviltwin67
No I was just adding ATF through the "dipstick." I sneezed and the bottle slipped out of my hand and poured a good amount into the funnel so it went in. I didn't have anything to siphon it at home, so I drove to the store to buy a tube to fit down the dip stick tube. On the way there, that's when I noticed it wouldn't upshift when going 40+mph. I siphoned it in the store parking lot, but it still didn't shift out of the same gear it starts out in.
Is there something I can to do to "reset" it to work normally?
Quick Reply: Overfilled ATF now transmission stuck in low
