how to get diagnostic codes 88 dodge ram 318
Old 04-28-2010, 04:07 PM
mjm1988's Avatar
mjm1988
mjm1988 is offline
Default how to get diagnostic codes 88 dodge ram 318
Rummaged around and cannot find the procedure - I have an 88 dodge ram with a 318 - first, how do you get the codes? from what I have been able to gather, it has something to do with turning the key on/off several times? Also, once I get the codes, how do I know what they mean?? thx, mike
Old 04-28-2010, 04:44 PM
SEAL's Avatar
SEAL
SEAL is offline
ON-BOARD DIAGNOSTICS Dodge OBD1 Pre 96
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
Leadbelly (12-23-2019)
Old 04-28-2010, 05:33 PM
mjm1988's Avatar
mjm1988
mjm1988 is offline
I see now why you are the "captain".....thanks!
Old 04-29-2010, 09:50 AM
mjm1988's Avatar
mjm1988
mjm1988 is offline
I came up with only 2 codes : 12 and 22, so I feel pretty good about that!!
Old 05-02-2010, 11:21 AM
samuelkopyna's Avatar
samuelkopyna
samuelkopyna is offline
i tried this with my truck and the check engine light didnt even come on.
iidreedyii (11-11-2023)
Old 05-02-2010, 01:07 PM
Exarkun007's Avatar
Exarkun007
Exarkun007 is offline
How do you clear them? I checked my new old dodge and all it had was 12, and it has a new battery so that's a no brainer
Old 05-02-2010, 02:42 PM
AeSix's Avatar
AeSix
AeSix is offline
turn the key on 50 times?
Old 05-02-2010, 03:04 PM
Exarkun007's Avatar
Exarkun007
Hmm the maint reqd light is on. Any idea how to check that out or make it go away?
Old 05-03-2010, 07:09 AM
SEAL's Avatar
SEAL
SEAL is offline
The maintenance required light is mileage driven and does not tell you anything. It takes a special tool at the dealer to turn it off. Ignore it until it burns out, pay the dealer to turn it off, or remove the bulb as I did.
To clear codes, disconnect the battery for about 5 minutes.
The 22 code is a problem as the computer uses the information output from the coolant temperature sensor to adjust timing and fuel.
Old 05-03-2010, 10:36 AM
mjm1988's Avatar
mjm1988
mjm1988 is offline
Is the best "fix" for the code 22 to replace the engine coolant temp. sensor, or could there be more to it than that? I guess what I am asking is what the recommended diagnostic procedure is for this code?? Is there a way to test the existing engine temp sensor output??
Quick Reply: how to get diagnostic codes 88 dodge ram 318
