how can i raise the front end
Old 04-24-2010, 10:30 PM
jose13b's Avatar
jose13b
jose13b is offline
Default how can i raise the front end
put 35's on my truck and raised the torchan bars all the way but know the front is higher then the back so i put a 3 inch lift blocks on the rear axle and now i want to raise the front one each or maybe 2 inches what can i do? is there a spacer i can get for the shock tower to space it one inch.
[/IMG]
Old 04-24-2010, 11:04 PM
oefootball_70's Avatar
oefootball_70
oefootball_70 is offline
get new keys.
Old 04-24-2010, 11:12 PM
Shiloh 24's Avatar
Shiloh 24
Shiloh 24 is offline
That's hell of a lot of stress on those t bars, I'd just put a smaller block in the rear 3" is a bit much ne way. You don't need that much lift to clear a 35" tire with a 4wd.
Old 04-24-2010, 11:13 PM
rocket23's Avatar
rocket23
rocket23 is offline
well you got a delemma dontcha?? You can get new keys but I think you'll be happier with a bigger lift kit imo
Old 04-24-2010, 11:25 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
You can't use leveling keys AND a T-bar crank... Besides, if you tried to do more than 2.5" inches you'd be busting CVs all the time...
A LEVEL is just that, it levels the truck with the rear, if you went higher then the rear with the bolt crank you have already put way too much stress on your front end components.
If you want more than 2.5" of lift from stock on the front, you need to purchase a body lift or a real suspension lift. Otherwise use smaller blocks in the rear...
Old 04-25-2010, 10:27 AM
jose13b's Avatar
jose13b
jose13b is offline
what are keys
Old 04-25-2010, 10:55 AM
rebel61021's Avatar
rebel61021
rebel61021 is offline
they are what adjust the ride height on the T bars. Here is the new set I put on my truck the rusted one is the stock key and was replaced by the new key that gave me the 2.5 inches of lift with out really hurting the ride quality.
Old 04-25-2010, 02:24 PM
98cherryram's Avatar
98cherryram
98cherryram is offline
Just to kinda help you out shiloh, it doesnt really stress the t-bars... I've never heard of someone hurting a set of the t-bars on these trucks... what it mostly hurts is the cv's. If you can find someone who hurt the t-bars on their truck, I can show you someone who had them jacked up to the max with leveling keys and was hitting things way to hard with their front end, like jumping at the dunes or dropping off of rocks and stuff really fast, which even then they are more likely to break other things first...
Old 04-25-2010, 10:58 PM
jose13b's Avatar
jose13b
jose13b is offline
ok am confused where do I find this under the truck and where do I by them will it give me more of a lift because my t-bars are all the way turned and I just want to go up 1 or 2 inches thanks
Old 04-25-2010, 11:06 PM
Shiloh 24's Avatar
Shiloh 24
Thanks man, I try to sound like I know 4x4's. I know some of the basics, one of them being I know what he is tryin to do is bad lol.
As for the OP read what Hammer said, you can't really go any higher than you are now because your CV's are gonna just get obliterated. Just put a smaller block in the rear and uncrank to t bars until level.
Quick Reply: how can i raise the front end
