key fob
Old 04-21-2010, 07:32 PM
btfor's Avatar
btfor
btfor is offline
Default key fob
how do you program a key fob for a 2010 grand caravan & how many key fobs can be made? DIY
Old 04-21-2010, 10:07 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
You can program up to 8 remotes. But you need to have the dealer program the remote, because you need the key codes.
Old 04-22-2010, 07:11 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
DodgeCaravan2010SXT is offline
not 100% true, dealer needs to program it if you have only one left. If you have the 2 originals or 2 then you can program it. its in the manual howto. if i recall you have to put the firt turn it to on then remove then put next do same and then put in the one you want to program.
Old 04-22-2010, 06:36 PM
btfor's Avatar
btfor
btfor is offline
thanks ill look thru the manual. i bought the van this week and the dealer told me $280!!!! for each new key fob
Old 09-21-2010, 03:01 PM
Anglhrt's Avatar
Anglhrt
Anglhrt is offline
Yup, I just bought a 2010 grand caravan sxt previously owned a week ago. Only had one key fob. $170.00 for the fob and 30.00 to program it plus tax... what a huge rip-off.
Old 09-22-2010, 03:38 AM
DodgeCaravan2010SXT
depending ya deal i would of requested it on the sale of the van that 2 keys be supplied. anyways you can now get one from ebay $50.00 and program it yourself. always good to have if you loose one ya can still program it yourself.
Old 09-22-2010, 09:56 PM
lovvorn's Avatar
lovvorn
lovvorn is offline
Default serial number
You are correct ,but you will need the serial number of y0ur van to order a new & correct fob !!! then insert an old fob turn to on then off ,then the second old fob to on then off , then the new fob to on & start the engine . this has to be completed in 10 seconds !!! "10 seconds " my thoughts Duane # 6363
Old 10-06-2010, 11:13 PM
gonefission's Avatar
gonefission
gonefission is offline
The key fob must be new to be programmed. If it was previously programmed to a different vehicle, the dealer cannot program it. There must be some way to wipe the program and reprogram the key fob. If anyone knows how, please share.
Old 10-06-2010, 11:46 PM
master tech
The dealer can erase all keys that are program and start over. And program all key again.
