2000 Neon NO SPARK
Old 04-07-2010, 09:56 PM
thomas665's Avatar
thomas665
thomas665 is offline
Default 2000 Neon NO SPARK
Ok I have change all senors and coil. I have also change Harness and computer, and steering colum and I still have no spark... I do not know what else to do Please Help
Old 04-10-2010, 11:47 AM
thomas665's Avatar
thomas665
Default Still no spark
I still have no spark I have 12V to coil and 8V to Cam sensor and have change everything that I can think of. So know I am going to change the harness inside the car. I have change cam sensor , crank sensor, knock sensor, Coil, Computer, motor harness, and steering colum. Please help
Old 04-10-2010, 12:22 PM
Isakill's Avatar
Isakill
Isakill is offline
All I can come up with right now is the ground straps to the engine.
Are they in good shape? Do they have good continuity?
I need to change mine so it's a good possibility yours are bad as well.
Old 04-10-2010, 01:43 PM
thomas665's Avatar
thomas665
Yes The ground straps are bolted down and in good shape!!!!!
Old 04-10-2010, 02:07 PM
Isakill's Avatar
Isakill
Isakill is offline
But do they have good continuity?
Use an Ohmmeter and check the resistance between the body and the engine block. It should be 0 or extremely close to it.
Edit:
Also, how exactly did you check for spark?
The "old man's" way was to take a screwdriver and shove into the spark plug boot while it's not on a spark plug and hold it about an inch away from "ground". You would hear a telltale click, or if done at night a blue to orange spark. depending on how "hot" the ignition is.
By hot I mean by how much voltage is being thrown to the plugs. DO NOT be touching any ground while doing this.. it's not a pleasant experience when 15KV+ goes coursing through your arms. Dunno if this would work on a newer vehicle.
Another note, it's current that kills, not voltage. But it don't take much to do it! Under the right conditions 1/4th of an amp.
Old 04-10-2010, 03:12 PM
thomas665's Avatar
thomas665
I used a test light and every ground checks out ok I have even went as far as changing out the throttlebody I am just out of ideas and have no clue what to do next.
Old 04-10-2010, 03:17 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Does the engine turn over?
Old 04-10-2010, 03:52 PM
thomas665's Avatar
thomas665
yes even has good compression
Old 04-10-2010, 06:08 PM
darthroush's Avatar
darthroush
Section Moderator
Have you ohm-tested your coil pack (just because it is new doesn't mean it can't be DOA) and spark plug wires to ensure they are within specs? Are the plugs good? The cam and crank sensors are good? In addition to the coil, the cam and crank sensors make up the three main components of the ignition system.
EDIT: Here's a list from the DSM about crank, but no start possible causes. Might help you narrow down some more testing areas:
NO START PRE-TEST
POWERTRAIN FUSES OPEN
FUEL PRESSURE OUT OF SPECS
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP INLET STRAINER PLUGGED
FUEL PUMP MODULE
FUEL PUMP RELAY FUSED B+ CIRCUIT
FUEL PUMP RELAY OUTPUT CIRCUIT OPEN
FUEL PUMP RELAY
FUEL PUMP GROUND CIRCUIT OPEN/HIGH RESISTANCE
FUEL PUMP MODULE
5 VOLT SUPPLY CIRCUIT
CKP SENSOR SIGNAL CIRCUIT OPEN
CKP SENSOR SIGNAL CIRCUIT SHORTED GROUND
CKP SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE
CKP SENSOR SIGNAL SHORTED TO 5 VOLT SUPPLY CIRCUIT
SENSOR GROUND CIRCUIT OPEN
ASD RELAY OUTPUT CIRCUIT
CRANKSHAFT POSITION SENSOR
IGNITION COIL
IGNITION COIL DRIVER CIRCUIT OPEN
IGNITION COIL DRIVER CIRCUIT SHORTED TO GROUND
PCM - COIL
PCM - CKP SENSOR SIGNAL
OTHER POSSIBLE CAUSES FOR NO START
Old 04-10-2010, 06:31 PM
thomas665's Avatar
thomas665
Everything you have said I have checked and everythings fine. The parts are coming off of a running 99 neon the coil starts the other car but not 2000. I am just stuck
Quick Reply: 2000 Neon NO SPARK
