Catalitic converter removal: pro's vs.cons
Old 04-06-2010, 10:05 PM
bseeton1's Avatar
bseeton1
bseeton1 is offline
Default Catalitic converter removal: pro's vs.cons
mines rattlin and starting to not idle properly at times,have been reading about removing it all together wanted to get some input as to why i should or shouldn't do this. Have been told you can really increase your mileage but want more input. 98 1500 4x4 360 auto 150k. flowmaster via previous owner. Also my air flow in the cab kick of temperarily when i get on it;vaccum issue of some sort i'm guessing
Old 04-06-2010, 10:46 PM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
Pros and cons of removing cat
Pro's- no more cat to deal with, saves money of replacing one, sounds better, less restriction in exhaust, motor breathes better
Cons- wont pass emissions, can throw a code(fixed by one of many methods), polutes the air
Old 04-06-2010, 11:01 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Maxx_Magnum is offline
if you don't have emissions testing there, I'd get rid of it. Mines gutted and I get code P0420 once every couple months or so, it'll go off by itself after a few days if I don't clear it first. And it does sound better
Old 04-06-2010, 11:14 PM
CPTAFW163's Avatar
CPTAFW163
CPTAFW163 is offline
no backpressure at all. Need some backpressure.
Biggest con is putting it back in when getting the smog inspection (if you live in a smog area).
Is Orange County NY still a no-smog area? I remembered only NYMA areas were smog areas. But I heard NY state went California.
redheadhunter21
Oh yea forgot to put that if it was me I would take it off, I dont have mine on and would never think of putting one on, unless I had too
Old 04-07-2010, 07:19 AM
niceandeasy's Avatar
niceandeasy
niceandeasy is offline
Well what is the best way to gut it and does some one have pics. and how you fix the code if it keeps poping up
Old 04-07-2010, 07:31 AM
Maxx_Magnum
Well, if you can get the pipe off behind the cat, you could use a long bar or something similiar and beat on the stuff til it breaks up enough to get out, I've done that in the past. Mine was gutted when I got it, whoever did it just cut the side open and did it that way then just welded it back up. Dunno what would be easier for ya....
And there was a DIY for the O2 sensor mod but I can't seem to find it.... Basically what it does in the end is move the sensor out of the direct flow of the exhaust, and this tricks it into thinkin the cat is still functioning properly.
edit: found it
https://dodgeforum.com/forum/2nd-gen...ving-cats.html
Old 04-07-2010, 07:42 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
i cut the muffler out, and now i can see the honey comb. i keeping my CAT on while i hollow it. I can get a prybar down there and hammer it to break it all up. Then im just going to strt it and rev it to blow out all the honeycomb. I hope to do mine next week, but i need to get a muffler first
Old 04-07-2010, 09:04 AM
pcfixerpro's Avatar
pcfixerpro
pcfixerpro is offline
edit: found it
He did that on a 3rd gen. While the concept is the same, I was unable to use two of the non-foulers like in the diy. I came up with something slightly different.
https://dodgeforum.com/forum/2nd-gen...-surprise.html
Old 04-07-2010, 11:03 AM
ICEMAN_CH's Avatar
ICEMAN_CH
ICEMAN_CH is offline
I just left my O2 sensors hanging with plastic caps on them. The caps melted but I never get the code.
Quick Reply: Catalitic converter removal: pro's vs.cons
