Door lock not working (just one door)
Old 04-05-2010, 07:51 PM
jdpartsman's Avatar
jdpartsman
jdpartsman is offline
Default Door lock not working (just one door)
The drivers side QC door no longer responds to either the keypad or the switch inside the truck. The other three doors work fine. What is mosy likely the problem? The local shop thought it might be the motor that operates the lock on that door. He said they are spendy, but could get one from a junked out truck for less then half....whatever that was.
Old 04-05-2010, 08:01 PM
SilverBullet08's Avatar
SilverBullet08
SilverBullet08 is offline
yep sounds like the motor went bad...
Old 04-05-2010, 09:08 PM
ramjamhemi's Avatar
ramjamhemi
ramjamhemi is offline
Yep, door lock actuator. Try local junkyards or Greenleaf auto on the internet. I found some on Ebay when I needed one.
Old 04-05-2010, 09:17 PM
meen green machine's Avatar
meen green machine
meen green machine is offline
i have the same exact problem with the same exact door.
With mine when i push down manually it dosent go as far down as the others but still locks
Old 04-06-2010, 08:11 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I had the same with my D/S door. I ended up replacing the lock actuator and everything was fine.
Look for P/N 55276791AF
price is $45 on http://wermopar.com/
price is $25 on http://www.allworldautomotive.com
Old 04-06-2010, 08:19 AM
regert's Avatar
regert
regert is offline
I have the same problem on the drivers rear door and I changed the accuator assembly and she still NO worky, I'm not sure whats wrong with it kinda sucks, anyone got any ideas. Sorry JD partsman not trying to hyjack your thread.
Thanks Regert
Old 04-06-2010, 08:46 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Thanks Regert
The other issue guys have similar to this with the same symptoms are broken wires in the door boots. check those
Old 04-06-2010, 09:48 AM
jose13b's Avatar
jose13b
jose13b is offline
I have the same door problem should be a recall checked the wires and they are okay am going to check those sites
Old 04-06-2010, 10:18 AM
regert's Avatar
regert
regert is offline
I looked at my wires as well and they look fine, I know when I put in the new accuator the lock worked 4 times and then nothing after that. could it be the drivers door switch group or even the fuse box? really sucks, I've had the truck for 2 years now and it's work for the first 2 months and nothin since.
Old 04-06-2010, 11:05 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
it could be a switch but I would think the RKE would still work though
Quick Reply: Door lock not working (just one door)
