Last edit by: IB Advertising
Browse all: 4WD
- Dodge Ram 2nd Gen How to Replace Front Axle 4WD Actuator
Step by step instructions for the do-it-yourself repairs.
Browse all: 4WD
4wd not engaging
4wd not engaging
I've been trying to figure out what's wrong with my truck, I followed this:
http://www.dodgeram.org/tech/repair/..._engagment.htm
- Shift into 4WD and move truck a couple of feet
- If light is still off, park truck, block the wheels, set the park brake, jack right front wheel, and try to hand spin the wheel
- If wheel doesn't turn, 4x4 is functioning properly but there is a wiring problem: use an ohmmeter to check the 4x4 switch, wiring, fuse, and bulb.
- If wheel turns freely, the front axle or transfer case is not engaged: continue...
- Attempt to hand spin the front driveshaft If the driveshaft WILL spin, the transfer case is not engaged Check the transfer case shift linkage, problem is in linkage (or in the tran$fer ca$e internal$ <-- yes this means $$, ouch!)
- If the driveshaft will NOT spin, the transfer case is engaged properly: continue...
- USE CAUTION! With transmission in neutral or park, start engine, measure vacuum on the two vac lines at front axle shift motor. One line should have approx 20" vacuum, other line should have none.
- If NO vacuum measured, look for vacuum leak or bad vacuum switch.
- If both lines have vacuum, look for a bad vacuum switch or ruptured CAD actuator diaphragm.
- If one line has 20" +/- vacuum:
- Move transfer case lever to 2WD, measure vacuum again. Lines should have swapped vacuum signals.
- If No: vacuum switch bad or 4WD shift linkage needs adjusting
- If Yes: Vacuum motor bad or stuck, or shift fork stuck: continue
- Remove vacuum shift motor from the axle, attach vac lines to shift motor, engage/disengage 4WD. Does shift motor plunger move at least 1/2"?
- No: shift motor bad
- Yes: Check axle shift fork and vacuum motor for binding
Bader Almuqbali (04-25-2020)
does the four wheel drive indicator light on your dash come on when you put it in four wheel drive. When the vacuum diaphram slides the collar over to lock the shafts together it pushes in the switch that activates the 4X4 light. If it's not coming on, the collar and plunger aren't moving correctly.
FYI, my 4x4 light never has come on, but 4low always has. Bulb burnt out?
I was planning on replacing the vacuum system with the cable actuator, but I just haven't got around to it yet.
good work so far, but can you put the truck up on 4 jack stands and start at the t-case and work down stream. check things in this order.
does front drive shaft turn.
do front wheels turn (probably not since you wrote this post)
does vacuum switch from one line at the cad to the other.
remove cad.
does the fork slide over.
can you move the coupler byhand on/off the 2 axle pieces.
(there's a bushing in there that might be worn out causing out of alignment. also coupler or shaft could be buggered up).
can you get the light on the dash to work (its activated by switch on cad, only when everything slides all the way over).
remove cad.
remove cad.
remove cad.
wheels don't turn
vacuum switches over, but not sure how much vacuum, no gauge
fork slides over
have not tried to move coupler by hand. thanks, i'll try that
light has never worked, except 4lo. didn't think to check it when moving fork by hand.
