OBDI (Pre '96) Codes
Old 03-30-2010, 11:52 PM
95_318SLT's Avatar
95_318SLT
95_318SLT is offline
Default OBDI (Pre '96) Codes
The current code list linked in FAQ is incomplete, so I'm writing up a new one...
To check the codes stored in the computer:
1. Cycle the ignition key ON-OFF -- ON-OFF--- ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "12" is generally accepted to represent the beginning of codes on our trucks.
A code of "55" represents end of codes. If this is all you get then no error codes are stored in the computer. This is the normal condition.
Code and description
11** Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
13** No change in MAP output voltage from start to run
14** MAP sensor output voltage outside the acceptable range (too low or too high)
15** No vehicle speed sensor signal
17* Closed loop temp not reached or engine cold too long
21** 02s sensor does not detect rich or lean condition (signal stays at center)
22** Engine coolant temp sensor signal outside the acceptable range
23** Intake air temp sensor signal outside acceptable range
24** Throttle Position sensor signal outside acceptable range
25** Idle air control motor circuit short or open condition detected
27* Injector control circuit failure
31** Evap Solenoid circuit short or open condition detected
32** EGR Solenoid circuit short or open condition detected
33* A/C clutch relay circuit short or open condition detected
34* Speed control vacuum or vent circuit short or open condition detected OR speed control switch input outside accepted range
35 Rad Fan control relay circuit short or open condition detected (4 cyl only)
37* Torque converter clutch solenoid CKT or park/neutral switch failure OR Transmission Temperature sensor to high, which is specific to Ram PCM 94-up Dakotas don't have the transmission temperature sensor.
41** Generator field not switching properly
42* Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43** Multiple/ single cylinder misfire
44* Battery temp sensor volts out of accepted range
45* Transmission OD solenoid circuit short or open condition detected
46** Charging system voltage too high
47** Charging system voltage too low
51** Fuel system lean
52** Fuel system rich
53* Internal PCM failure
54* No cam signal at PCM
55* End of error messages (If you get this only, no errors were found)
62* PCM failure SRI mile not stored
63* PCM Failure EEPROM write denied
64** Catalytic Converter Efficiency Failure
65 Power steering switch failure
Fault Codes with * - check engine lamp will not illuminate at all times if this code was recorded
Fault Codes with ** - Checking engine lamp will illuminate when the engine is running if this code was recorded
Old 03-31-2010, 12:04 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
I will replace. Good job.
Old 04-06-2010, 08:21 PM
thebudman84's Avatar
thebudman84
thebudman84 is offline
Default obd1 DTC 32 51 22
how would i go about fixing these
Old 04-06-2010, 08:24 PM
thebudman84
i know on a obd1 32 code check the wring but could you get me a link of the wiring
i know on a obd1 51 code its bad fuel pressure to set a lean code when i know my fuel pump is under about 7 to 8 psi then the spec fuel psi
also on a obd1 22 code i dunno if maybe the other 2 are setting it off or my comp is going
Old 04-06-2010, 10:50 PM
95_318SLT's Avatar
95_318SLT
32 - Replace the EGR valve
51 - Sounds like you have it down, but it could also be a bad 02 sensor
22 - Simply replace the coolant temp sensor
Also, don't be afraid to start a new thread and be very descriptive about the issues you are having! Also, give information about your truck! I could give you a link to download the wiring diagrams if I knew what you're driving!
Old 09-04-2010, 04:35 PM
mojaveman48's Avatar
mojaveman48
mojaveman48 is offline
How would you go about fixing codes 12 11 15 33 and 42 on a 1991 dodge dakota 4x4 v8 5.2 LE Thanks
Old 02-11-2011, 02:44 PM
ddgdkt96's Avatar
ddgdkt96
ddgdkt96 is offline
Hey, I am getting the 1 2 code, then 2 1, then 2 1 again, and then at the end a 5 6. is this possibly a misinterpreted 33?
I wonder if the difference is because I have a 96?
what does it all mean
Old 08-08-2011, 12:52 PM
95Sport4X4's Avatar
95Sport4X4
95Sport4X4 is offline
My codes came out, 37, 32, 55. I just ordered my new EGR valve, what about the 37? It's a stick shift!
Old 08-08-2011, 01:03 PM
Crazy4x4RT's Avatar
Crazy4x4RT
IIRC even manual transmissions will have a neutral safety switch.
For others I will close this thread. If you have a question on the codes or need help open a new thread.
Quick Reply: OBDI (Pre '96) Codes
