pulling 8000 lbs
Old 03-28-2010, 05:19 PM
mmartinez02's Avatar
mmartinez02
mmartinez02 is offline
If you wanated to tow 8,000 lbs, you should have bought an F150 or Tundra.
Old 03-28-2010, 05:41 PM
Bent's Avatar
Bent
Bent is offline
I don't suspect he wanted to tow 8000 pounds, More likely the opportunity came up to make things a little easier on himself if he was able to use his truck he has to tow the load.
An old farmer told me a long time ago, if you have a big wagon to pull, you hitch it to a horse, not a dog. But sometimes necessity prevails.
Old 03-28-2010, 06:59 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
Your first post and you use it for some trash like that?? I GAURANTEE I could out tow ANY f150 or tundra.
Old 03-28-2010, 07:07 PM
Bent's Avatar
Bent
Bent is offline
Old 03-28-2010, 07:44 PM
caliboy@heart's Avatar
caliboy@heart
caliboy@heart is offline
WTF?! what a d-bag.
Old 03-28-2010, 07:48 PM
caliboy@heart
I'm towing over 8k lbs about 3 months from now...proly up to about 8100 lbs. After reading the manual, it said that you have to have 10-15% of your load on your hitch. It also says that you must have a WD hitch for anything over 350 lbs on your hitch. Since your gonna have 800 lbs on your hitch, you def NEED a WD hitch. I will be buying on in the near future as well and I will also be putting rear air bags on too. If your hitch is factory then you also have all the other coolers in front of your radiator that you NEED as well like I do. Also, make sure to get a good brake controller. Install is a snap since there is already a plug under the dash.
Old 03-28-2010, 09:44 PM
nathangfnd's Avatar
nathangfnd
nathangfnd is offline
ford have crappy motor and tundras are ugly
Old 03-28-2010, 10:21 PM
mmartinez02
not on a 1500 a 2500 might do it .
__________________
So, I go to the Denver RV show and buy a 7K lbs trailer, Later, I decide to upgrade my TV and decide on the badest boy on the block, a 1500 Hemi - 5.7 - 3.92. Then, I start reading these forums and it's like I bought a Datsun pickup. Nothing but... you can't tow that much weight with a 1/2 ton, you need a 3/4 - one ton, buy air bags/tranny cooler/super chip/. WELL WHAT THE WHAT??? I towed the trailer and believe it or not, it did fine. 65 mph up and down the hills. Yes, your 1500 can tow 8,000 lbs. Just do it safely.
Old 03-28-2010, 10:39 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
your first post was completely erroneous, and your second post contradicted the first one as well as gave subtle jabs at this forum.
keep em comin buddy you're on a roll
Old 03-28-2010, 11:00 PM
mmartinez02
Yes, I was being sarcastic. Just tired of reading what a whimp my 1500 is. Like I said, my trailer is 7K lbs, dry and the truck does fine. Well within the legal/warranty/safety limits of the truck. And of course I also bought a WD hitch and Prodigy brake control which really help.
Quick Reply: pulling 8000 lbs
