Stalled now won't start
Old 03-14-2010, 11:37 PM
05_hemiram's Avatar
05_hemiram
05_hemiram is offline
Unhappy Stalled now won't start
I fired my truck up tonight to move it into the garage and it stalled on me and now it won't start up again. I didn't let the engine warm up at all and it's been sitting all day (temp here is about 0 degrees celcius). That's my bad, I know. when I first started it it was perfect, shifter from reverse into drive and stalled out of nowhere. It turns over, seems to fire really weak for a fraction of a second and then dead. I don't know what to do now.
Smells pretty rich at the exhaust pipe, so I don't know if you can flood it or what. I let it sit for 20 mins and tried it again and nothing. I'm hoping it will start in the morning.
One other thing, I removed my muffler back in october and had it straight piped. That is the only mod done to the truck.
Has anybody heard of this problem before? Any help would be greatly appreciated.
Old 03-14-2010, 11:40 PM
SilsHemi's Avatar
SilsHemi
SilsHemi is offline
Do you have shorty wires? The reason I ask, I read those are having some starting issues in cold weather.
Sil
Old 03-14-2010, 11:48 PM
05_hemiram's Avatar
05_hemiram
No shorty wires. The truck has been good all winter, and it gets d*mn cold here in Saskatchewan. I turned on my windshield wipers while turning the wheel and had the headlights on all at the same time, seems almost like a system overload. Can't figure out why she won't fire now though.
Old 03-14-2010, 11:55 PM
98cherryram's Avatar
98cherryram
98cherryram is offline
Have you replaced your wires ever? I replaced the wires on my old 98 once and a few of them were sitting on top of the engine and melted, my truck would occasionally start up, stall afterwards, then die soon afterwards.
Hope this helps, good luck!
Old 03-15-2010, 12:28 AM
05_hemiram's Avatar
05_hemiram
I've never replaced the wires, I just purchased the truck in October and haven't done anything to it other than the straight pipe.
Old 03-15-2010, 12:56 AM
rocket23's Avatar
rocket23
rocket23 is offline
How many miles? should be a failing fuel pump not common but possible. gotta start there 1.fuel/2air/3spark You get those and still nothing then it gets expensive.I'd check those first aree you getting fuel ,air and spark???
Old 03-15-2010, 05:05 AM
RedTruck-VA's Avatar
RedTruck-VA
RedTruck-VA is offline
Cold is a bitch. Can you get some heat under the hood. Maybe a drop light with a blanket on the hood. Let her sit and she will probably fire up in the morning.
Old 03-15-2010, 07:54 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You know, I know a guy with an 05 from Regina............hmmm..........
Anyway, for what it is worth, can you press and hold the gas pedal to the floor and start it?
Old 03-15-2010, 08:26 AM
loflyer2's Avatar
loflyer2
loflyer2 is offline
Sounds like similar problem I had recently. I replaced the camshaft position sensor and it fixed the problem. Inexpensive part and not too hard to install (definitely not easy though). I have 05 hemi ram 4x4 with 108k miles.
Old 03-15-2010, 08:58 AM
05_hemiram's Avatar
05_hemiram
Started up this morning so I let it warm up while I had a shower before moving it back into the garage. Seems like when you push on the break it stutters a bit like its going to stall then it idles back up. Oh well, at least it's running now. I shut it down and it fired back up like a champ, so I'll watch it I guess. Thanks for the help guys.
P.S. Weedahoe, I am in Regina.
Quick Reply: Stalled now won't start
