remote starter problems
Old 03-14-2010, 03:32 PM
gregcooney1's Avatar
gregcooney1
gregcooney1 is offline
New Member
Default remote starter problems
I have a 2005 ram qc with a hemi that has a prestige remote starter installed in it. It has been installed for about a year and a half and was working fine until yesterday. Now if i go start it it will start up and then shut right off it will try three times and then will stop. If i go to start it with the key it starts right up. I eventried to sit in the truck and give it gas while it tries to start but it still dies. Anyone with any advice is helpful thanks
Old 03-14-2010, 03:37 PM
Fav40's Avatar
Fav40
Fav40 is offline
Have you done ANYthing to the truck recently prior to the problem ? Tail lights ?
Old 03-14-2010, 03:46 PM
gregcooney1
New Member
no nothing at all
Old 03-14-2010, 04:36 PM
rbeard79's Avatar
rbeard79
rbeard79 is offline
What color key do you have? If it is grey, then you have a bypass module that could have lost programming or gone bad. It will still start the truck, but the keysense kills it after 5 seconds. Just installed a Viper on mine, and the bypass is what allows the truck to start without the key in the ignition. Hope that helps!!
Old 03-14-2010, 05:00 PM
Martin460's Avatar
Martin460
Martin460 is offline
Old 03-14-2010, 05:07 PM
newfiebullet's Avatar
newfiebullet
newfiebullet is offline
x3 on this problem. mine starts and runs for 7 seconds then shuts off. cant start it anymore with remote until you start with the key first. I jjust installed new headlight bulbs but cant see this bein the problem. Goin to the shop monday for o2 sensor so ill see if we can get it figured out.
Old 03-14-2010, 05:21 PM
gregcooney1
New Member
I have the black key
Old 03-14-2010, 05:25 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
could be a bad hood pin if you have one installed. could be anything tripping it and making it shut off as a security feature or breach.
Old 03-14-2010, 05:26 PM
rbeard79's Avatar
rbeard79
rbeard79 is offline
did you have it installe by a local shop? If som take it back. You should have a lifetime warranty on the install?? Does your black key have the keyless entry buttons on it? I so, you have a sentry key, and it should have a bypass like mentioned above!
Old 03-14-2010, 05:28 PM
rbeard79's Avatar
rbeard79
rbeard79 is offline
I didn't think they would even try and start if the hoodpin was not working properly???
Quick Reply: remote starter problems
