Old 08-06-2015, 01:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System
Print Wikipost
Water Pump Inlet Tube Leaking-Replacement Not Snug
Old 03-06-2010, 06:05 PM
cosmorphis's Avatar
cosmorphis
cosmorphis is offline
Default Water Pump Inlet Tube Leaking-Replacement Not Snug
Hey guys. I changed my water pump about a year ago, and used the old "water pump inlet tube", but it would always leak a little anti-freeze. I tried buying a replacement from O'Reilly Auto Parts, but it is also a little loose, and not very snug. I think I might of widened the hole by messing with it too much. Any ideas on how to make this a tight, non-leaking fit? I thought about using teflon tape, but didn't know if that would break off inside the cooling system. Maybe I can use some sort of sealant around the edges, once I have it in there? I know that it will get super hot, so it has to stay good under intense heat. Any suggestions would be appreciated. Thanks!
Old 03-06-2010, 06:08 PM
DukesOfHazzard's Avatar
DukesOfHazzard
DukesOfHazzard is offline
Thats got a o-ring on it correct? I would try a thicker/fatter/ o-ring.
Old 03-06-2010, 06:35 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
plan a - ^ thicker fatter o-ring with a little oil on it.
plan b - thicker fatter o-ring with a generous amount of rtv on it (clean off any oil).
Old 03-06-2010, 07:47 PM
Me&MyMopar's Avatar
Me&MyMopar
Me&MyMopar is offline
I had the same issue, except mine was a brand new tube that came with the water pump. I just used rtv with the supplied o ring, and it hasn't leaked at all.
Old 03-06-2010, 10:11 PM
cosmorphis's Avatar
cosmorphis
I've got some Super Blue Silicone Gasket Maker by VersaChem. http://www.oreillyauto.com/site/c/de...1759&ppt=C0137 Is that the same thing, or is there a brand/type you guys would recommend, that I can get at AutoZone or Oreilly? Thanks.
Old 03-06-2010, 10:20 PM
J415's Avatar
J415
J415 is offline
^ That'll work...
Old 03-06-2010, 10:25 PM
cosmorphis's Avatar
cosmorphis
Sweet. Thanks!
Quick Reply: Water Pump Inlet Tube Leaking-Replacement Not Snug
