42RLE pan drop - RTV or gasket when reassembling?
Old 03-02-2010, 06:00 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Damn Dirty Ape is offline
Default 42RLE pan drop - RTV or gasket when reassembling?
WHat have you all used, I know it comes with Mopar RTV from the factory but the kit I got (Wix) has a cork gasket.. That being said, did you use RTV Mopar (what color)? or the gasket?
thanks
Old 03-02-2010, 06:11 PM
rengnath's Avatar
rengnath
rengnath is offline
When I took my truck in to get the fluid changed at a local shop they used black RTV to seal it.
Old 03-02-2010, 08:34 PM
studlyblueiz's Avatar
studlyblueiz
studlyblueiz is offline
as far as i know only the older vehicles that use cork gaskets are to use sealant. Newer vehicles use rubber gaskets and don't need sealant. I used just the rubber gasket. It came with the filter. Sealant is more of pain if you don't need it.
Old 03-02-2010, 10:08 PM
Damn Dirty Ape
well after checking with the Dodge parts dept. they don't even have a listing for a gasket for the 42rle transmission.
Old 03-02-2010, 10:18 PM
studlyblueiz
i got both filters and the gasket at Advance Auto
Old 03-02-2010, 10:37 PM
rengnath's Avatar
rengnath
rengnath is offline
Dodge wont have a gasket, any gasket that you find will be aftermarket.
Old 03-03-2010, 11:48 AM
sdsdsd's Avatar
sdsdsd
sdsdsd is offline
I used RTV
Old 03-04-2010, 12:57 AM
projektdirtfab's Avatar
projektdirtfab
projektdirtfab is offline
yea the newer 42's use a special rtv....so everyone that used checker's or autozone rtv will have leak problems soon. mopar atf eats through that crap....gotta use mopar rtv
Old 03-04-2010, 09:56 AM
Damn Dirty Ape
what color is it? full name/ part # by chance? I ask because the parts person knows less about their parts and lookup system than I probably do. More than once I've gotten the wrong item.
Old 03-04-2010, 11:26 PM
projektdirtfab
ill have to grab the tube from work in the morning. its black and it says right on front for use with atf +4 (or whatever we use) and has the mopar symbol on it.
check back tomorrow....
Quick Reply: 42RLE pan drop - RTV or gasket when reassembling?
