CV Joint for front driveshaft
Old 02-26-2010, 03:39 PM
bpark8824's Avatar
bpark8824
bpark8824 is offline
Default CV Joint for front driveshaft
I noticed a bad humming and a slight grind coming from the front after I drove around in 4wd this week. Then I looked under and noticed the boot around the cv was totally gone and so was any grease that was suppose to be packed around the bearings...
Anyway long story short I need a new cv joint for the front driveshaft on the t-case end. But I called Napa and Federated and neither had one. I then called Dodge and they say they only sell the whole drive shaft assembly... at $412. I don't want to pay that much for something when I only need the cv. Anyone know where I can get JUST cv? If not I will have to look into getting a re-maned drive shaft or the junk yard. But really hoping I can get just the cv.
Any help is appreciated. Thanks.
Old 02-27-2010, 02:05 PM
diright's Avatar
diright
diright is offline
Default front shafts
The whole front shafts are only $60.00 or so at Advance Auto. Replaced one when I worked on my 98
Old 02-28-2010, 09:15 AM
bpark8824's Avatar
bpark8824
They changed in 2000 to a better unit, and they got more expensive in the process...
Thanks though.
Quick Reply: CV Joint for front driveshaft
