Old 08-06-2015, 07:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
Replacing Batteries
Old 02-25-2010, 07:18 PM
davidsawesome's Avatar
davidsawesome
davidsawesome is offline
Default Replacing Batteries
I have a 2005 Ram 2500 diesel, and I'm trying to replace the batteries. Theres a screw directly in front of each battery, facing the engine... I tried loosening it significantly, but the batteries won't move much.... Something is holding them in. Theres nothing about this in the manual, and I can't find anything on the internet.
Any help would be greatly appreciated.
Old 02-25-2010, 07:22 PM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
Sorry man, I'm not sure but someone on here may be able to help you or there is a diesel section to this forum.
https://dodgeforum.com/forum/dodge-cummins-diesel-88/
Old 02-25-2010, 08:25 PM
irelandshemi's Avatar
irelandshemi
irelandshemi is offline
i dont know if its anything like my 5.7 i just changed the battery on, but i had a bolt holding the plastic tab at the bottom of the battery to keep it down, mine wouldnt come all the way out and after some blood and swear words i finally got out the bolt cutters
Old 02-26-2010, 06:56 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
As said, there is that small plastic block at the bottom front of the battery that is screwed in place to hold it down. If you are turning that bolt and its not coming loose, then the piece on the bottom is likely spinning. You need to get under there and look. You may have to pull the well liners out.
Old 02-26-2010, 10:17 AM
rdunkin's Avatar
rdunkin
rdunkin is offline
Just went thriugh the same thing. Reach your habd underneath where the bolt is and hold the backing. It will unscrew all the way out. Then you have to pry the wedge next to the battery loose. If you remove just the bolt it wont come loose till you remove the wedge. Good luck Richard
Quick Reply: Replacing Batteries
