How much coolant does it hold 02 3.8 dual heater
Old 02-24-2010, 04:51 PM
2002caravan's Avatar
2002caravan
2002caravan is offline
Default How much coolant does it hold 02 3.8 dual heater
I have an 02 Grand Caravan with a 3.8L and dual heaters. How much does it hold? I blew a hose and had to fill with water. I need to know the capacity so I can estimate how much concentrate to use to get the ratio back.
Also, if anybody knows. How much coolant total from the radiator and engine by pulling the lower hose?
Thanks!!
Old 03-02-2010, 06:17 PM
GQ-ROD's Avatar
GQ-ROD
GQ-ROD is offline
Your owners manual will tell you the amount it will hold.
On my 96 grand caravan with the 3.8 v-6 dual heat and air it held one gallon of pure antifreeze, one gallon of distilled water and about 1/4 to 1/2 more gallon of of 50/50 prediluted anti freeze.
You will of course get some loss when you are burping the radiator to get the air out but this should get you in the right direction if you haven't already fixed it.
Old 03-02-2010, 08:36 PM
ez1913's Avatar
ez1913
ez1913 is offline
2.4L - 9.5qts
3.0L - 10.5qts
3.3/3.8L - 10.5qts.
Capaities are approxamate, add as necessary.
Old 03-03-2010, 12:09 PM
2002caravan
Originally Posted by ez1913
2.4L - 9.5qts
3.0L - 10.5qts
3.3/3.8L - 10.5qts.
thank you
Old 03-03-2010, 12:27 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
SPECIFICATIONS - FLUID CAPACITIES
DESCRIPTION</B>
SPECIFICATION</B>
Fuel Tank (Gas) 75 L (20 gal.) Fuel Tank (Diesel) 75 L (20 gal.) Engine Oil* - 2.4 L 4.7 L (5.0 qts.) Engine Oil* - 3.3/3.8 L 4.7 L (5.0 qts.) Engine Oil* - 2.5 L (Diesel) 6.0 L (6.3 qts.) Cooling System** - 2.4 L 10.7 L (11.4 qts.) Cooling System** - 2.5 L Turbo Diesel with Auxiliary Heater 13.8 L (14.6 qts.) Cooling System** - 3.3/3.8 L without Auxiliary Heater 12.6 L (13.4 qts.) Cooling System** - 3.3/3.8 L with Auxiliary Heater 15.4 L (16.3 qts.) Automatic Transaxle - Service Fill 3.8 L (4.0 qts.) Automatic Transaxle - 31TH Overhaul Fill 8.6 L (9.1 qts.) Automatic Transaxle - 41TE Overhaul Fill 9.2 L (9.7 qts.) Manual Transaxle (T850 5-Speed) 2.4-2.7 L (2.5-2.9 qts.) AWD Power Transfer Unit 1.15 L (2.4 pts.) Power Steering 1.2 L (2.5 pts.) AWD Bi-directional Overrunning Clutch 0.575 L (1.22 pts.) AWD Rear Carrier 0.7 L (1.48 pts.) * (includes oil filter) ** (includes heater and recovery/reserve bottle)
Old 03-03-2010, 04:04 PM
2002caravan
Muchos Grasias!
To be honest I would put this off until next fall but we have been having some weird weather. It stabilized in the 40-50's then a couple days ago it dipped down to 5 degrees. Don't think it is lean enough to freeze but why risk major damage.
Quick Reply: How much coolant does it hold 02 3.8 dual heater
