Ram 2004 HEMI spark plugs
Old 02-21-2010, 11:33 PM
maximedelo's Avatar
maximedelo
maximedelo is offline
Default Ram 2004 HEMI spark plugs
Hi,
I have an 04 Ram 1500 5.7 HEMI 4doors 4WD and I would like to replace my spark plugs. My friend told me I had 16 plugs?? Is it true?? Which spark plugs would you recommend??? If you have a part# for me that would be much appreciated!!
Thanks!!
Max
Old 02-21-2010, 11:37 PM
glass3222's Avatar
glass3222
glass3222 is offline
Yes you have 16. Get the NGK or Champion copper plugs. Do a search for spark plugs and you will find a lot of reading that will answer all of your questions.
Old 02-22-2010, 01:08 AM
3500Ram04's Avatar
3500Ram04
3500Ram04 is offline
i changed my plugs today and its took about a hour not as bad as i have read on here plus i cleaned my tb while i was at it
Old 02-22-2010, 01:45 AM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
a hour? It took that long just to open up all 16 plug cartons LOL! You either had help, were in a big hurry, or really lucky lol.
Getting some of those coil pack bolts back in was probably the hardest part in my opinion. Also, if you are short or have small arms, good luck or find something to stand on.
16 Champion coppers, the stock number is 570. The plug number is RE14MCC4, and the gap is .045. Get some grease for the boots and put antisieze on the threads of the plugs.
Old 02-22-2010, 08:42 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Off_Road_Teacher is offline
Like the others have said, stick with the champions.
I wish I could do my plug change in an hour. That is the fastest that I have ever heard of someone doing all 16 plugs on their own.
Old 02-22-2010, 10:01 AM
BEAR's Avatar
BEAR
BEAR is offline
you did 16 plugs and cleaned the TB in a hour? Dang it man, next time you do this make a video I would pay to see that. You musta been JUMPIN!
To the OP go with Champs or NGKs and you wont go wrong.
Old 02-23-2010, 12:37 PM
3500Ram04's Avatar
3500Ram04
this wasnt my first time changing a set of spark plugs i have changed alot .... first time for the hemi and yes it took about hour .... im 6'2 so reaching the plugs was easy the coil packs bolts came out it about two seconds had an electric racket i used on them ... and the plugs wasnt that hard to reach .... when i start something i like getting it done so i dont jack around
Old 02-23-2010, 02:16 PM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
had an electric racket i used on them....
cheater
Old 02-23-2010, 02:36 PM
chrisy1961's Avatar
chrisy1961
chrisy1961 is offline
Smile
I cheated too. I had one of my kids friends crawl up inside the engine compartment and change the back 2 on the passenger side. He's 5'2" and all of 120lbs. I'm 5'10" and 280 lbs. That was the best $10 I ever spent. LOL
Old 02-23-2010, 02:38 PM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
HAHAHAHA ^^^^ Thats awesome
Quick Reply: Ram 2004 HEMI spark plugs
