2nd Gen Durango 2004 - 2009
2004 Durango SLT - Engine knocking when cold
Old 02-18-2010, 07:44 AM
rogers9671's Avatar
rogers9671
rogers9671 is offline
Default 2004 Durango SLT - Engine knocking when cold
When I start it up the engine knocks/pecks for a while until the temp gague gets to almost mid way between hot and cold. it has 102,000 miles on it. Any suggestions??? I don't know if this may be a lifter or what.
Thanks.
Old 02-18-2010, 07:50 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
What size or liter is your engine?
FF
Old 02-18-2010, 08:06 AM
rogers9671's Avatar
rogers9671
4.7L Engine
Old 02-18-2010, 10:26 AM
1969CoronetR/T
vaffanculo
I would use Seafoam to clean the throttle body, use better grade of gas, and tune-up the engine to see if that clears up the problem,
FF
Old 02-18-2010, 11:16 AM
rogers9671's Avatar
rogers9671
I had read in a previous post about the manafold studs, could that be a possibility?
Old 02-18-2010, 12:48 PM
1969CoronetR/T
vaffanculo
This seems to be a common problem with the 4.7L. It can not hurt to look at them,
FF
Quick Reply: 2004 Durango SLT - Engine knocking when cold
