Dodge Ram 1500 5.9 360 Oil Pressure *help*
Old 02-17-2010, 07:43 PM
Joe6223's Avatar
Joe6223
Joe6223 is offline
Default Dodge Ram 1500 5.9 360 Oil Pressure *help*
I recently noticed that my oil pressure has went down about two psi. It used to always be a 40 at idle and would just go over the 40 mark when regular driving. Lately at stops the needle has been going just under the 40 mark. What could of made this ? And should I worry? My alternator is going could it be less stress on the motor from that going causing the truck less work at idle?
Two Oil changes ago I started going with Mobi
l 1 High Mileage synthetic and a K&N oil filter.
1996 Dodge Ram 1500 5.9 360 4X2
  • K&N Intake
  • Flow master Exhaust
  • 180 Thermostat
  • Jet Chip
  • MagnaFlow Catalytic Converter
Old 02-17-2010, 07:55 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
Probably just the oil pump on its way out. Rock Auto has a new Sealed Power oil pump for $30.
Here is a DIY on oil pump removal:
http://www.pavementsucks.com/tech-article-31.html
Hope this helps! Welcome To Dodge Forum!
Old 02-17-2010, 07:58 PM
yakkier's Avatar
yakkier
yakkier is offline
Have you checked your oil ? how is your tempature ? also have you changed your oil filter lately ? stopped up oil filter will cause low pressure in the pump and will throw off your over all oil pressure
Old 02-17-2010, 08:00 PM
PurplDodge's Avatar
PurplDodge
A stopped up oil filter will just go into bypass, and that would raise the oil pressure, not drop it.
Old 02-17-2010, 08:08 PM
yakkier's Avatar
yakkier
yakkier is offline
if sludge gets into the pump it will cause it to lower.
Old 02-17-2010, 08:09 PM
oklahoma's Avatar
oklahoma
oklahoma is offline
i am having a similar problem, but my oil pressure drops to 0 when its warmed up and idle, but when it goes up even 50 rpm it shoots right back up, my dad said his old dodge had the same problem and it was the oil pressure sending unit. but im not sure if that would cause it to drop just 2 psi
Old 02-17-2010, 08:19 PM
Gerehead8's Avatar
Gerehead8
Gerehead8 is offline
You could do some of the suggestions on here and it wouldn't hurt. I wouldn't woory about it though. The dash gauges are not accurate anyway. You are only really at about 5-7 psi at idle anyway. I run a mechanical oil pressure gauge so it shows exactly what the pressure is.
Old 02-17-2010, 08:55 PM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
Wouldnt think about it too hard, just check your oil level and color, if its fine just keep an eye on it, my oil pressure is about were yours is at and goes about as far on the high side of 40 when in the gas hard
Old 02-17-2010, 09:04 PM
jmhai's Avatar
jmhai
jmhai is offline
+1.... Mine moves a little more in each direction and has done it since the day I bought it...
Old 02-18-2010, 11:46 PM
Joe6223's Avatar
Joe6223
Joe6223 is offline
I think I am going to replace the oil pump in the spring just to be safe. I noticed today that is was a little warmer out that the gauge drops a needle more. So the warmer it gets the more the pressure goes down how is this going to be when it is 80 degrees out it was barley 50 today??
The oil level is fine and my temp for the motor is at 175-180 (checked today)
Quick Reply: Dodge Ram 1500 5.9 360 Oil Pressure *help*
