bad computer??????
Old 02-15-2010, 03:58 PM
dadodeez's Avatar
dadodeez
dadodeez is offline
Default bad computer??????
The other day i tried to start up my truck but it wouldnt. I charged the battery and put it in and tried again. Got it to turn over but wouldnt start still. When i let off the key the lights and computer were clicking in unison. I couldnt hear the fuel pump so i changed that thinking that was the problem but its still doing the same thing. My voltage gauge and fuel gauge are all the way down to zero but i have power in the cab. I know the tank has gas in it from changing the pump. Im wondering what this could be. I want to get a new pcm and put it in but dont know if theres something else wrong that could short out the new one. Or if this is even the problem. My fuel pump wont start working unless i run a jumper from the battery post to the relay if that helps. I would appreciate any advice from anyone before i push the dam truck off a cliff. Thanks.
Old 02-15-2010, 05:26 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Any codes show up?
FF
Old 02-15-2010, 06:14 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
try changing the fuel pump relay in the pdc under the hood, sounds like you arent getting power to the fuel pump, and that is the most common culprit
Old 02-15-2010, 09:52 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Does your durango have a 4.7L motor. Have you ck the fuse's in the PDC? A blown fuse will give you the same problem.
Old 02-16-2010, 10:06 PM
Chemuza's Avatar
Chemuza
Chemuza is offline
Exact same problem with mine. Let me know if you figure anything out and I'll do the same. I swapped relays around and had all the same symptoms so that doesn't seem to be the fix.
Old 02-16-2010, 10:38 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Check your battery connections for corrosion.
Old 02-16-2010, 11:28 PM
shrpshtr325
THE ULTI-MOD
thats another place to check, but iv never heard of it throwing a no buss code
Old 02-17-2010, 03:53 AM
Chemuza's Avatar
Chemuza
Chemuza is offline
It's got to be something electrical. We tried shooting starter fluid into the carb (probably a bad a idea but oh well) and can't get it to fire. We're guessing it's a bad ground or a frayed wire somewhere. I cleaned the ground and pos terminals and installed a new battery but it's still faulting. Going to check continuity for the ground and see if there are any bad/frayed wires. Thanks for your help btw.
Old 02-17-2010, 11:35 PM
hydrashocker
Do you have spark?
Old 02-18-2010, 04:25 AM
Chemuza's Avatar
Chemuza
Chemuza is offline
Nada spark or fuel. Tested fuel pressure with the key on and nothing. Also hooked up a diagnostic unit and couldn't get it to connect. Still have to check connections, ground etc. Next step will probably be a new PCM.
My mechanic thinks I reversed polarity while originally trying to jump the battery with a charger but I know that wasn't the case. I might be on the short bus now and then but that's something I've never done or could forget.
Quick Reply: bad computer??????
