Wiper blades hitting each other
Old 02-07-2010, 03:37 PM
yfzracer912's Avatar
yfzracer912
yfzracer912 is offline
Default Wiper blades hitting each other
I have a 2001 Dodge Caravan and this is my 3rd set of wiper blades that have hit each other while cleaning my windsheild. As this happen to anyone else?
Old 02-07-2010, 04:13 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Yes they do. What happens is the nut loosen up and arms start hitting each other. Remove the covers and loosen the 15mm nut and adjust the arms and tighten the nuts.
Old 02-07-2010, 10:52 PM
yfzracer912
Ok which nut do I loosen up and how do you adjust the arm? Thank you very much cz this problem is annoying.
Old 02-08-2010, 07:36 AM
yfzracer912
Thanks Master! So I dont need any special tool to pull of the wiper arm?
Old 02-08-2010, 10:30 AM
master tech
Battery post puller or channel lock pliers.
Quick Reply: Wiper blades hitting each other
