2000 neon will not crank
Old 02-03-2010, 05:34 PM
storman's Avatar
storman
storman is offline
Default 2000 neon will not crank
hi, everyone new to this site, great site,
i have a 2000 neon, it would start but only 2 cilenders
tried changing coil same thing , the garage said it was the computer,
changed it, then work on all cillenders for 10 seconds or so then died.
now it wont crank, put the old computer back and she would crank again.
very confused, any help would be aprecated . CHEERS"
Old 02-23-2010, 07:25 PM
aspensti's Avatar
aspensti
aspensti is offline
do you have a check engine light?
Old 02-23-2010, 09:18 PM
Twkdout066's Avatar
Twkdout066
Twkdout066 is offline
It could be something in the wiring, I am assuming you changed the spark plugs and wires if you have changed the coil.
Old 02-24-2010, 08:11 AM
storman's Avatar
storman
storman is offline
there is no check engine light,
just wondering if the computer has to have the same number as the original for it to work?
Old 02-24-2010, 08:15 AM
storman's Avatar
storman
storman is offline
no i didnt change the plug wires but that wouldnt prevent her from cranking would it, not sure of that, any suggestions is appreciated.
Old 02-28-2010, 03:15 PM
Twkdout066's Avatar
Twkdout066
No I was referring to it only firing on two cylinders. Usually if it won't crank it is a starter, starter relay, battery cable, ignition cylinder, or bad electrical connection somewhere between the key and starter.
Quick Reply: 2000 neon will not crank
