DTC Codes here
Old 02-03-2010, 11:54 AM
KRZY.BMET's Avatar
KRZY.BMET
KRZY.BMET is offline
Peaceful Browser
Default DTC Codes here
AMPLIFIER (AMP)
Diagnosis and Testing
B1460-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B1461-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1462-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1463-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1464-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B1465-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B1466-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1467-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1468-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1469-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B146A-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B146B-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B146C-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B146D-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B146E-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B146F-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B1470-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1471-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1472-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1473-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B1474-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B1475-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1476-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1477-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1478-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B1479-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B147A-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B147B-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B147C-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B147D-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B147E-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B147F-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1480-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1481-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1482-CHANNEL 7 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B1483-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
 B1484-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1485-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1486-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1487-CHANNEL 8 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B1488-CABIN EQ MISMATCH PERFORMANCE
 B210D-BATTERY VOLTAGE LOW
 B210E-BATTERY VOLTAGE HIGH
 B221F-AMPLIFIER INTERNAL
 U0019-CAN B BUS
 U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM)
 U0184-LOST COMMUNICATION WITH RADIO
 CONTROLLER, Occupant Restraint (ORC)
 Diagnosis and Testing
 B1B00-DRIVER AIRBAG SQUIB 1 CIRCUIT LOW
 B1B01-DRIVER AIRBAG SQUIB 1 CIRCUIT HIGH
 B1B02-DRIVER AIRBAG SQUIB 1 CIRCUIT OPEN
 B1B03-DRIVER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
 B1B04-DRIVER AIRBAG SQUIB 2 CIRCUIT LOW
 B1B05-DRIVER AIRBAG SQUIB 2 CIRCUIT HIGH
 B1B06-DRIVER AIRBAG SQUIB 2 CIRCUIT OPEN
 B1B07-DRIVER AIRBAG SQUIB 2 CIRCUIT SHORTED TOGETHER
 B1B08-PASSENGER AIRBAG SQUIB 1 CIRCUIT LOW
 B1B09-PASSENGER AIRBAG SQUIB 1 CIRCUIT HIGH
 B1B0A-PASSENGER AIRBAG SQUIB 1 CIRCUIT OPEN
 B1B0B-PASSENGER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
 B1B0C-PASSENGER AIRBAG SQUIB 2 CIRCUIT LOW
 B1B0D-PASSENGER AIRBAG SQUIB 2 CIRCUIT HIGH
 B1B0E-PASSENGER AIRBAG SQUIB 2 CIRCUIT OPEN
 B1B0F-PASSENGER AIRBAG SQUIB 2 CIRCUIT SHORTED TOGETHER
 B1B18-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT LOW
 B1B19-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT HIGH
 B1B1A-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT OPEN
 B1B1B-LEFT SIDE CURTAIN SQUIB 1 CIRCUIT SHORTED TOGETHER
 B1B20-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT LOW
 B1B21-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT HIGH
 B1B22-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT OPEN
 B1B23-RIGHT SIDE CURTAIN SQUIB 1 CIRCUIT SHORTED TOGETHER
 B1B70-UP-FRONT LEFT SATELLITE ACCELERATION SENSOR INTERNAL
 B1B71-UP-FRONT RIGHT SATELLITE ACCELERATION SENSOR INTERNAL
 B1B72-LEFT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
 B1B73-LEFT SIDE SATELLITE ACCELERATION SENSOR 2 INTERNAL
 B1B75-RIGHT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
 B1B76-RIGHT SIDE SATELLITE ACCELERATION SENSOR 2 INTERNAL
 B1B8D-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT LOW
 B1B8E-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT HIGH
 B1B8F-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT OPEN
 B1B90-DRIVER SEAT TRACK POSITION SENSOR CIRCUIT SHORTED TOGETHER
 B1B91-DRIVER SEAT TRACK POSITION SENSOR CONFIGURATION MISMATCH
 B1BA5-AIRBAG SQUIB CONFIGURATION MISMATCH
 B1BC7-DEPLOYMENT DATA RECORD FULL
 B1C27-LEFT SIDE SEAT THORAX SQUIB 1 LOW
 B1C28-LEFT SIDE SEAT THORAX SQUIB 1 HIGH
 B1C29-LEFT SIDE SEAT THORAX SQUIB 1 OPEN
 B1C2A-LEFT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER
 B1C2B-RIGHT SIDE SEAT THORAX SQUIB 1 LOW
 B1C2C-RIGHT SIDE SEAT THORAX SQUIB 1 HIGH
 B1C2D-RIGHT SIDE SEAT THORAX SQUIB 1 OPEN
 B1C2E-RIGHT SIDE SEAT THORAX SQUIB 1 SHORTED TOGETHER
 B1C38-1st ROW DRIVER RETRACTOR TENSIONER CIRCUIT LOW
 B1C39-1ST ROW DRIVER RETRACTOR TENSIONER CIRCUIT HIGH
 B1C3A-1st ROW DRIVER RETRACTOR TENSIONER CIRCUIT OPEN
 B1C3B-1st ROW DRIVER RETRACTOR TENSIONER CIRCUIT SHORTED TOGETHER
 B1C3D-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT LOW
 B1C3E-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT HIGH
 B1C3F-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT OPEN
 B1C40-1st ROW DRIVER SEAT BELT BUCKLE TENSIONER CIRCUIT SHORTED TOGETHER
 B1C47-1st ROW PASSENGER RETRACTOR TENSIONER CIRCUIT LOW
 B1C48-1ST ROW PASSENGER RETRACTOR TENSIONER CIRCUIT HIGH
 B1C49-1st ROW PASSENGER RETRACTOR TENSIONER CIRCUIT OPEN
 B1C4A-1st ROW PASSENGER RETRACTOR TENSIONER CIRCUIT SHORTED TOGETHER
 B1C4F-1st ROW PASSENGER SEAT BELT BUCKLE TENSIONER CIRCUIT SHORTED TOGETHER
 B212C-IGNITION RUN/START INPUT CIRCUIT OPEN
 B212D-IGNITION RUN ONLY INPUT CIRCUIT OPEN
 B2207-OCCUPANT RESTRAINT CONTROLLER INTERNAL 1
 B2208-OCCUPANT RESTRAINT CONTROLLER INTERNAL 2
 B220B-OCCUPANT RESTRAINT CONTROLLER FIRING STORED ENERGY
 B223B-VEHICLE CONFIGURATION MISMATCH
 B2255-OCCUPANT RESTRAINT CONTROLLER ROLL OVER FEATURE DISABLE
 B222A-VEHICLE LINE MISMATCH
 U0002-CAN C BUS OFF PERFORMANCE
 U0170-LOST COMMUNICATION W/UP-FRONT LEFT SATELLITE ACCELERATION SENSOR
 U0171-LOST COMMUNICATION W/UP-FRONT RIGHT SATELLITE ACCELERATION SENSOR
 U0172-LOST COMMUNICATION W/LEFT SIDE SATELLITE ACCELERATION SENSOR 1
 U0173-LOST COMMUNICATION W/LEFT SIDE SATELLITE ACCELERATION SENSOR 2
 U0175-LOST COMMUNICATION W/RIGHT SIDE SATELLITE ACCELERATION SENSOR 1
 U0176-LOST COMMUNICATION W/RIGHT SIDE SATELLITE ACCELERATION SENSOR 2
 U1414-IMPLAUSIBLE/MISSING ECU CONFIGURATION DATA
 U1415-IMPLAUSIBLE/MISSING VEHICLE CONFIGURATION DATA
 HVAC, ATC
 B1001-A/C SWITCH REQUEST INPUT CIRCUIT LOW
 B100A-RECIRCULATION SWITCH REQUEST INPUT CIRCUIT LOW
 B1016-REAR DEFROST SWITCH REQUEST INPUT CIRCUIT LOW
 B1031-EVAPORATOR FIN TEMPERATURE SENSOR CIRCUIT LOW
 B1032-EVAPORATOR FIN TEMPERATURE SENSOR CIRCUIT HIGH
 B1034-INFRARED TEMPERATURE SENSOR INPUT CIRCUIT LOW
 B1035-INFRARED TEMPERATURE SENSOR INPUT CIRCUIT HIGH
 B1040-PANEL MODE DOOR 1 CONTROL CIRCUIT/PERFORMANCE
 B1043-PANEL MODE DOOR 1 CONTROL CIRCUIT OPEN
 B1044-PANEL MODE DOOR 1 TRAVEL RANGE TOO SMALL
 B1045-PANEL MODE DOOR 1 TRAVEL RANGE TOO LARGE
 B1058-RECIRCULATION DOOR CONTROL CIRCUIT/PERFORMANCE
 B105B-RECIRCULATION DOOR CONTROL CIRCUIT OPEN
 B105C-RECIRCULATION DOOR TRAVEL RANGE TOO SMALL
 B105D-RECIRCULATION DOOR TRAVEL RANGE TOO LARGE
 B106B-REAR DEFROST CONTROL CIRCUIT LOW
 B106C-REAR DEFROST CONTROL CIRCUIT HIGH
 B1082-HVAC MUX CIRCUIT LOW
 B1083-HVAC MUX CIRCUIT HIGH
 B10A2-LEFT BLEND DOOR CONTROL CIRCUIT/PERFORMANCE
 B10A5-LEFT BLEND DOOR CONTROL CIRCUIT OPEN
 B10A6-LEFT BLEND DOOR TRAVEL TOO SMALL
 B10A7-LEFT BLEND DOOR TRAVEL TOO LARGE
 B10A8-LEFT BLEND DOOR ACTUATOR PERFORMANCE
 B10A9-RIGHT BLEND DOOR CONTROL CIRCUIT/PERFORMANCE
 B10AC-RIGHT BLEND DOOR CONTROL CIRCUIT OPEN
 B10AD-RIGHT BLEND DOOR TRAVEL TOO SMALL
 B10AE-RIGHT BLEND DOOR TRAVEL TOO LARGE
 B10AF-RIGHT BLEND DOOR ACTUATOR PERFORMANCE
 B10B2-A/C COOL DOWN TEST PERFORMANCE
 B1601-LEFT SOLAR SENSOR CIRCUIT LOW
 B1602-LEFT SOLAR SENSOR CIRCUIT HIGH
 B1604-RIGHT SOLAR SENSOR CIRCUIT LOW
 B1605-RIGHT SOLAR SENSOR CIRCUIT HIGH
 B1610-AMBIENT LIGHT SENSOR INPUT CIRCUIT LOW
 B1611-AMBIENT LIGHT SENSOR INPUT CIRCUIT HIGH
 U0019-CAN B BUS
 U0151-LOST COMMUNICATION WITH OCCUPANT RESTRAINT CONTROLLER (ORC)
 U0155-LOST COMMUNICATION WITH CLUSTER/CCN
 U0156-LOST COMMUNICATION WITH EOM
 U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN)
 U0186-LOST COMMUNICATION WITH AUDIO AMPLIFIER
 U0195-LOST COMMUNICATION WITH SDARS
 U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE
 U0197-LOST COMMUNICATION WITH HANDS FREE PHONE MODULE
 U0199-LOST COMMUNICATION WITH DRIVER DOOR MODULE
 U0200-LOST COMMUNICATION WITH PASSENGER DOOR MODULE
 U0208-LOST COMMUNICATION WITH HEATED SEAT CONTROL MODULE
 U0209-LOST COMMUNICATION WITH MEMORY SEAT CONTROL MODULE
 HVAC SYSTEM TEST (ATC)
 HVAC, MTC
 11-MODE POT OPEN
 12-MODE POT SHORTED
 13-TEMP POT OPEN
 14-TEMP POT SHORTED
 18-BLEND DOOR RANGE TOO SMALL
 21-BLEND DOOR RANGE TOO LARGE
 22-FRONT MODE DOOR RANGE TOO SMALL
 23-FRONT MODE DOOR RANGE TOO LARGE
 31-EVAPORATOR SENSOR OPEN
 32-EVAPORATOR SENSOR SHORTED
 33-A/C MODE SWITCH STUCK
 34-EBL MODE SWITCH STUCK
 35-FAILED COOL DOWN
 36-EEPROM CHECKSUM ERROR
 37-ROM CHECKSUM ERROR
 41-FRONT MODE OVERCURRENT
 43-BLEND OVERCURRENT
 44-RECIRC OVERCURRENT
 45-BLEND DOOR BOUND
 46-FRONT MODE DOOR BOUND
 47-RECIRC DOOR BOUND
 51-RECIRC DOOR RANGE TOO SMALL
 52-RECIRC DOOR RANGE TOO LARGE
 53-FRONT MODE DOOR LINKAGE BROKEN
 55-BLEND DOOR LINKAGE BROKEN
 56-RECIRC DOOR LINKAGE BROKEN
 61-COMMON DOOR DRIVER CIRCUIT SHORTED TO GROUND
 62-COMMON DOOR DRIVER CIRCUIT SHORTED TO IGNITION
 63-FRONT MODE DOOR DRIVER CIRCUIT SHORTED TO GROUND
 64-FRONT MODE DOOR DRIVER CIRCUIT SHORTED TO IGNITION
 67-BLEND DOOR DRIVER CIRCUIT SHORTED TO GROUND
 68-BLEND DOOR DRIVER CIRCUIT SHORTED TO IGNITION
 69-RECIRC DOOR DRIVER CIRCUIT SHORTED TO GROUND
 71-RECIRC DOOR DRIVER CIRCUIT SHORTED TO IGNITION
 72-SHORT TOO COMPLEX
 73-AC REQUEST OUTPUT SIGNAL TOO HIGH
 74-AC REQUEST OUTPUT SIGNAL TOO LOW
 75-AC REQUEST OUTPUT SIGNAL HIGH WHEN DRIVEN LOW
 76-AC REQUEST OUTPUT SIGNAL LOW WHEN DRIVEN HIGH
 77-EBL OUTPUT SHORTED HIGH
 81-BLOWER NOT ON HIGH AT START OF COOLDOWN TEST
 82-SENSOR TOO COLD TO START COOLDOWN TEST
 83-SENSOR FAILED OPEN DURING COOLDOWN TEST
 84-SENSOR FAILED SHORTED DURING COOLDOWN TEST
 85-BLOWER NOT ON HIGH DURING COOLDOWN TEST
 MODULE, Adaptive Cruise Control (ACC)
 C124B-XBW RULE VIOLATION
 C124C-ACC DISABLED DUE TO ESP
 C2206-VEHICLE CONFIGURATION MISMATCH
 C2315-ACC DISABLE DUE TO PCM FAULT
 P0562-BATTERY VOLTAGE LOW
 P0563-BATTERY VOLTAGE HIGH
 P1519-CRUISE CONTROL FRONT DISTANCE SENSOR LENS CRACKED MISSING
 P160A-ECU OVERTEMPERATURE
 P1614-ECU RESET/RECOVERY OCCURRED
 P161A-ECU IN-PLANT MODE ACTIVE
 P1644-INCORRECT VARIANT/CONFIGURATION
 P1666-CRUISE CONTROL MODULE INTERNAL
 P1678-ECU SENSOR ADJUSTMENT REQUIRED
 U0100-LOST COMMUNICATION WITH ECM/PCM
 U0101-LOST COMMUNICATION WITH TCM
 U110A-LOST COMMUNICATION WITH SCCM - CAN - C
 U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
 U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE
 U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM
 U0402-IMPLAUSIBLE DATA RECEIVED FROM TCM
 U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS
 U0429-IMPLAUSIBLE DATA RECEIVED FROM SCM
 U0431-IMPLAUSIBLE DATA RECEIVED FROM FCM
 MODULE, Antilock Brake (ABS)
 C100A-LEFT FRONT WHEEL SPEED SENSOR CIRCUIT
 C1011-LEFT FRONT WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE
 C1014-LEFT FRONT WHEEL SPEED COMPARATIVE PERFORMANCE
 C1015-RIGHT FRONT WHEEL SPEED SENSOR CIRCUIT
 C101C-RIGHT FRONT WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE
 C101F-RIGHT FRONT WHEEL SPEED COMPARATIVE PERFORMANCE
 C1020-LEFT REAR WHEEL SPEED SENSOR CIRCUIT
 C1027-LEFT REAR WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE
 C102A-LEFT REAR WHEEL SPEED COMPARATIVE PERFORMANCE
 C102B-RIGHT REAR WHEEL SPEED SENSOR CIRCUIT
 C1032-RIGHT REAR WHEEL SPEED SENSOR SIGNAL ERRATIC PERFORMANCE
 C1035-RIGHT REAR WHEEL SPEED COMPARATIVE PERFORMANCE
 C1041-LEFT FRONT TONE WHEEL PERFORMANCE
 C1042-RIGHT FRONT TONE WHEEL PERFORMANCE
 C1043-LEFT REAR TONE WHEEL PERFORMANCE
 C1044-RIGHT REAR TONE WHEEL PERFORMANCE
 C1046-LEFT FRONT WHEEL PRESSURE PHASE MONITORING
 C1047-RIGHT FRONT WHEEL PRESSURE PHASE MONITORING
 C1048-LEFT REAR WHEEL PRESSURE PHASE MONITORING
 C1049-RIGHT REAR WHEEL PRESSURE PHASE MONITORING
 C1073-ABS PUMP MOTOR CONTROL CIRCUIT
 C1078-TIRE REVOLUTIONS RANGE PERFORMANCE
 C107C-BRAKE PEDAL SWITCH 1/2 STUCK-GAS
 C107D-BRAKE PEDAL SWITCH 1/2 CORRELATION-GAS
 C1090-ABS BRAKE LAMP CONTROL CIRCUIT LOW
 C1091-ABS BRAKE LAMP CONTROL CIRCUIT HIGH
 C1210-G SENSOR INPUT CIRCUIT PERFORMANCE
 C1219-STEERING ANGLE SENSOR ERRATIC PERFORMANCE
 C121A-STEERING ANGLE SENSOR NOT INITIALIZED
 C121C-TORQUE REQUEST SIGNAL DENIED
 C121D-BRAKE PRESSURE SENSOR CIRCUIT
 C121E-BRAKE PRESSURE SENSOR COMPARATIVE PERFORMANCE
 C1231-DRIVE TEST:STEERING ANGLE SENSOR
 C1232-DRIVE TEST: PRESSURE SENSOR
 C1234-DRIVE TEST: SENSOR CLUSTER INSTALLATION
 C1238-DRIVE TEST: UNSUCCESSFUL
 C1239-EMISSIONS ROLLS TEST ACTIVE
 C123A-ESP SYSTEM SENSORS CALIBRATION
 C123B-ESP SYSTEM CONTROL TOO LONG
 C123C-DYNAMICS SENSOR MOUNTING/INSTALLATION PERFORMANCE
 C123F-STEERING ANGLE SENSOR COMPARATIVE PERFORMANCE
 C1240-STEERING ANGLE SENSOR OVERTRAVEL PERFORMANCE
 C1242-G SENSOR INPUT SIGNAL PERFORMANCE
 C1243-G SENSOR NOT INITIALIZED
 C2100-BATTERY VOLTAGE LOW
 C2101-BATTERY VOLTAGE HIGH
 C2114-DYNAMICS SENSOR SUPPLY VOLTAGE LOW
 C2115-DYNAMICS SENSOR SUPPLY VOLTAGE HIGH
 C2116-ABS PUMP MOTOR SUPPLY LOW VOLTAGE
 C2200-ANTI-LOCK BRAKE MODULE INTERNAL
 C2202-ORIGINAL VIN MISMATCH/MISSING
 C2204-DYNAMICS SENSOR INTERNAL
 C2205-STEERING ANGLE SENSOR INTERNAL
 U0100-LOST COMMUNICATION WITH THE ECM/PCM
 U0125-LOST COMMUNICATION WITH DYNAMICS SENSOR
 U0126-LOST COMMUNICATION WITH STEERING ANGLE SENSOR
 U0146-LOST COMMUNICATION WITH CENTRAL GATEWAY
 U1003-ESP CAN C BUS PERFORMANCE
 U1104-CAN C BUS CRC PERFORMANCE
 U140E-IMPLAUSIBLE VEHICLE CONFIGURATION DATA RECEIVED
 U1501-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM ECM/PCM
 U1502-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM TCM
 U1503-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM TIPM
 MODULE, Auto Highbeam (AHBM)
 B16A7-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE- LEFT
 B16A8-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE- RIGHT
 B16A9-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE- TOP
 B16AA-HIGH BEAM CAMERA ALIGNMENT PERFORMANCE- BOTTOM
 B210A-SYSTEM VOLTAGE LOW
 B210B-SYSTEM VOLTAGE HIGH
 B223A-AUTO HIGH BEAM ECU INTERNAL
 U0019-CAN B BUS
 MODULE, Driver Door (DDM)
 B16A0-DRIVER WINDOW SWITCH BACKLIGHTING CIRCUIT LOW
 B16A1-DRIVER WINDOW SWITCH BACKLIGHTING CIRCUIT HIGH
 B1852-DRIVER WINDOW SWITCH CIRCUIT STUCK
 B1854-DRIVER WINDOW MOTOR CONTROL CIRCUIT LOW
 B1855-DRIVER WINDOW MOTOR CONTROL CIRCUIT HIGH
 B1858-DRIVER WINDOW POSITION SENSOR POWER SUPPLY LOW
 B1859-DRIVER WINDOW POSITION SENSOR POWER SUPPLY HIGH
 B185A-DRIVER WINDOW POSITION SENSOR CIRCUIT PERFORMANCE
 B1868-DRIVER PASSENGER WINDOW SWITCH CIRCUIT STUCK
 B1D04-MIRROR ADJUST SWITCH INPUT CIRCUIT/PERFORMANCE
 B1D07-MIRROR ADJUST SWITCH INPUT CIRCUIT STUCK
 B1D09-DRIVER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT LOW
 B1D0A-DRIVER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT HIGH
 B1D0C-DRIVER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT LOW
 B1D0D-DRIVER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT HIGH
 B1D0F-DRIVER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT LOW
 B1D10-DRIVER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT HIGH
 B1D1E-DRIVER MIRROR VERTICAL MOTOR CONTROL CIRCUIT/PERFORMANCE
 B1D22-DRIVER MIRROR HORIZONTAL MOTOR CONTROL CIRCUIT/PERFORMANCE
 B1D4D-MEMORY SWITCH INPUT CIRCUIT STUCK
 B2218-DOOR MODULE INTERNAL
 B2578-DRIVER WINDOW NOT CALIBRATED/LOST CALIBRATION
 B2580-DRIVER WINDOW POSITION SENSOR(S) NO SIGNAL
 U0019-CAN B BUS
 U0159-LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE
 U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE
 U0167-LOST COMMUNICATION WITH INTRUSION TRANSCEIVER CONTROL MODULE
 U0169-LOST COMMUNICATION WITH SUNROOF CONTROL MODULE
 U0181-LOST COMMUNICATION WITH HEADLAMP LEVELING TRANSLATOR
 U0212-LOST COMMUNICATION WITH SCM - CAN-B
 U0231-LOST COMMUNICATION WITH LIGHT RAIN SENSING MODULE
 U0241-LOST COMMUNICATION WITH AUTO HIGHBEAM HEADLIGHT CONTROL MODULE
 MODULE, Drivetrain Control (DTCM)
 C1456-AWD CLUTCH POWER CONTROL CIRCUIT LOW
 C1457-AWD CLUTCH POWER CONTROL CIRCUIT HIGH
 C145D-AWD CLUTCH POWER/RETURN CONTROL CIRCUIT OPEN
 C1464-FRONT AXLE DISCONNECT CONTROL CIRCUIT LOW
 C1465-FRONT AXLE DISCONNECT CONTROL CIRCUIT HIGH
 C1477-TRANSFER CASE CLUTCH OVER TEMPERATURE
 C147A-TRANSFER CASE TEMPERATURE SENSOR HIGH
 C147B-FRONT AXLE DISCONNECT SENSOR CIRCUIT PERFORMANCE
 C147C-FRONT AXLE DISCONNECT POWER CIRCUIT LOW
 C147D-FRONT AXLE DISCONNECT POWER SUPPLY CIRCUIT HIGH
 C2112-SENSOR SUPPLY 1 VOLTAGE CIRCUIT HIGH
 C2201-INTERNAL CONTROLLER
 U0001-CAN C BUS
 U0121-LOST COMMUNICATION WITH ABS
 U0431-IMPLAUSIBLE DATA RECEIVED FROM FCM/TIPM
 MODULE, Electronic Overhead (EOM)
 B1A32-UNIVERSAL GARAGE DOOR SWITCH 1 STUCK
 B1A33-UNIVERSAL GARAGE DOOR SWITCH 2 STUCK
 B1A34-UNIVERSAL GARAGE DOOR SWITCH 3 STUCK
 B2217 - EVIC/EOM/CMTC INTERNAL
 B222D - ECU UNABLE TO CONFIGURE / CONFIGURATION NOT LEARNED
 B2331-VEHICLE NEEDS DEGAUSSED
 U0019-CAN B BUS
 MODULE, Electronic Shift (ESM)
 P0562-BATTERY VOLTAGE LOW - ESM
 P0562-BATTERY VOLTAGE LOW - ESM (COLUMN)
 P0563-BATTERY VOLTAGE HIGH - ESM
 P0563-BATTERY VOLTAGE HIGH - ESM (COLUMN SHIFT)
 P0607-ECU INTERNAL PERFORMANCE - ESM
 P0607-ECU INTERNAL PERFORMANCE - ESM (COLUMN SHIFT)
 P0930-BTSI CONTROL CIRCUIT LOW
 P0930-BTSI CONTROL CIRCUIT LOW - COLUMN SHIFT
 P0931-BTSI CONTROL CIRCUIT HIGH
 P0931-BTSI CONTROL CIRCUIT HIGH - COLUMN SHIFT
 P2775-AUTOSTICK UPSHIFT SWITCH CIRCUIT PERFORMANCE
 P2775-AUTOSTICK UPSHIFT SWITCH CIRCUIT PERFORMANCE (COLUMN SHIFT)
 P2779-AUTOSTICK DOWNSHIFT SWITCH CIRCUIT PERFORMANCE
 P2779-AUTOSTICK DOWNSHIFT SWITCH CIRCUIT PERFORMANCE (COLUMN SHIFT)
 U0002-CAN C BUS OFF PERFORMANCE - ESM
 U0002-CAN C BUS OFF PERFORMANCE - ESM (COLUMN SHIFT)
 U0100-LOST COMMUNICATION WITH ECM/PCM - ESM
 U0100-LOST COMMUNICATION WITH ECM/PCM - ESM (COLUMN SHIFT)
 U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE - ESM
 U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE - ESM (COLUMN SHIFT)
 U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE - ESM
 U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE - ESM (COLUMN SHIFT)
Old 02-03-2010, 11:57 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
MODULE, Hands Free (HFM)
 B143B-MICROPHONE 1 CIRCUIT LOW
 B143C-MICROPHONE 1 CIRCUIT HIGH
 B143E-MICROPHONE 2 CIRCUIT LOW
 B143F-MICROPHONE 2 CIRCUIT HIGH
 B2205-ORIGINAL VIN MISSING/MISMATCH
 U0019-CAN B BUS
 MODULE, Heated Seat (HSM)
 B1092-FRONT LEFT SEAT HEATER CONTROL CIRCUIT LOW
 B1094-FRONT LEFT SEAT HEATER CONTROL CIRCUIT OPEN
 B1096-FRONT RIGHT SEAT HEATER CONTROL CIRCUIT LOW
 B1098-FRONT RIGHT SEAT HEATER CONTROL CIRCUIT OPEN
 B221A-HEATED SEAT MODULE INTERNAL
 U0019-CAN B BUS
 U0154-LOST COMMUNICATION WITH OCCUPANT CLASSIFICATION MODULE
 U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIRELESS IGNITION NODE OR WIN)
 U0197-LOST COMMUNICATION WITH HFM
 U0212-LOST COMMUNICATION WITH SCCM - CAN B
 U0231-LOST COMMUNICATION WITH RAIN SENSING MODULE
 MODULE, Intrusion Transceiver (ITM)
 B1A37-SECURITY TRANSMITTER SENSOR CIRCUIT LOW
 B1A38-SECURITY TRANSMITTER SENSOR CIRCUIT HIGH
 B1A3A-SECURITY RECEIVER SENSOR CIRCUIT LOW
 B1A3B-SECURITY RECEIVER SENSOR CIRCUIT HIGH
 B1A3C-INTERNAL SIREN BATTERY
 B1A3D-SIREN BATTERY TAMPER / LOSS OF POWER SUPPLY
 B1A3E-SIREN / ITM MISMATCH
 B1A3F-ITM ARMING SEQUENCE PERFORMANCE
 B1A41-SECURITY TRANSMITTER SENSOR CIRCUIT OPEN
 B1A42-SECURITY TRANSMITTER SENSOR CIRCUIT SHORTED TOGETHER
 B1A43-SECURITY TRANSMITTER SENSOR RETURN CIRCUIT LOW
 B1A44-SECURITY RECEIVER SENSOR CIRCUIT OPEN
 B1A45-SECURITY RECEIVER SENSOR CIRCUIT SHORTED TOGETHER
 B1A46-SECURITY RECEIVER SENSOR RETURN CIRCUIT LOW
 B1A47-SECURITY TRANSMITTER/RECEIVER SENSOR RETURN CIRCUIT HIGH
 B2206-CURRENT VIN MISSING/MISMATCH
 B223C-INTRUSION TRANSCEIVER MODULE INTERNAL
 U0019-CAN B BUS
 U0100-LOST COMMUNICATION WITH ENGINE CONTROL MODULE/POWERTRAIN CONTROL MODULE
 U0121-LOST COMMUNICATION WITH ANTI—LOCK BRAKE MODULE
 U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE (TIPM)
 U110D-LOST COMMUNICATION WITH SECURITY SIREN
 U1416-IMPLAUSIBLE SECURITY SIREN SIGNAL RECEIVED
 MODULE, Light Rain Sensor (LRSM)
 B2211-RAIN SENSOR MODULE INITIALIZATION PERFORMANCE
 B221D-(RSM) RAIN SENSOR MODULE INTERNAL
 B2329-RAIN SENSOR OPTICAL PATH 1 PERFORMANCE
 B232A-RAIN SENSOR OPTICAL PATH 2 PERFORMANCE
 B232B-RAIN SENSOR OPTICAL PATH 3 PERFORMANCE
 B232C-RAIN SENSOR OPTICAL PATH 4 PERFORMANCE
 U0019-CAN B BUS
 MODULE, Memory Seat (MSMD)
 B1D56-ADJUSTABLE PEDAL SENSOR CIRCUIT LOW
 B1D57-ADJUSTABLE PEDAL SENSOR CIRCUIT HIGH
 B1D5B-ADJUSTABLE PEDAL SWITCH CIRCUIT PERFORMANCE
 B1D5C-ADJUSTABLE PEDAL SWITCH CIRCUIT STUCK FORWARD
 B1D5D-ADJUSTABLE PEDAL SWITCH CIRCUIT STUCK REARWARD
 B1D62-POWER SEAT SWITCH STUCK
 B1D63-POWER SEAT SWITCH OPEN
 B1D67-ADJUSTABLE PEDAL CONTROL CIRCUIT PERFORMANCE
 B1D6D-SEAT HORIZONTAL POSITION SENSOR CIRCUIT LOW
 B1D6E-SEAT HORIZONTAL POSITION SENSOR CIRCUIT HIGH
 B1D71-SEAT FRONT VERTICAL POSITION SENSOR CIRCUIT LOW
 B1D72-SEAT FRONT VERTICAL POSITION SENSOR CIRCUIT HIGH
 B1D75-SEAT REAR VERTICAL POSITION SENSOR CIRCUIT LOW
 B1D76-SEAT REAR VERTICAL POSITION SENSOR CIRCUIT HIGH
 B1D79-SEAT RECLINER POSITION SENSOR CIRCUIT LOW
 B1D7A-SEAT RECLINER POSITION SENSOR CIRCUIT HIGH
 B1D7B-SEAT HORIZONTAL MOTOR CONTROL CIRCUIT PERFORMANCE
 B1D7F-SEAT FRONT VERTICAL MOTOR CONTROL CIRCUIT PERFORMANCE
 B1D83-SEAT REAR VERTICAL MOTOR CONTROL CIRCUIT PERFORMANCE
 B1D87-SEAT BACKREST MOTOR CONTROL CIRCUIT PERFORMANCE
 B1D8D-STEERING COLUMN TELESCOPE POSITION SENSOR CIRCUIT LOW
 B1D8E-STEERING COLUMN TELESCOPE POSITION SENSOR CIRCUIT HIGH
 B1D91-STEERING COLUMN TILT POSITION SENSOR CIRCUIT LOW
 B1D92-STEERING COLUMN TILT POSITION SENSOR CIRCUIT HIGH
 B1D93-STEERING COLUMN TELESCOPE MOTOR CONTROL CIRCUIT PERFORMANCE
 B1D97-STEERING COLUMN TILT MOTOR CONTROL CIRCUIT PERFORMANCE
 B1D9B-SEAT HORIZONTAL FRONT STOP NOT LEARNED
 B221C-MEMORY SEAT MODULE INTERNAL
 U0019-CAN B BUS
 U0020-CAN B BUS OFF PERFORMANCE
 MODULE, Park Assist (PTS)
 B128E-11-PTS SENSOR 1-CIRCUIT SHORT TO GROUND
 B128E-12-PTS SENSOR 1-CIRCUIT SHORT TO BATTERY
 B128E-25-PTS SENSOR 1-SIGNAL SHAPE / WAVEFORM FAILURE
 B128E-92-PTS SENSOR 1-PERFORMANCE OR INCORRECT OPERATION
 B128F-11-PTS SENSOR 2-CIRCUIT SHORT TO GROUND
 B128F-12-PTS SENSOR 2-CIRCUIT SHORT TO BATTERY
 B128F-25-PTS SENSOR 2-SIGNAL SHAPE / WAVEFORM FAILURE
 B128F-92-PTS SENSOR 2-PERFORMANCE OR INCORRECT OPERATION
 B1290-11-PTS SENSOR 3-CIRCUIT SHORT TO GROUND
 B1290-12-PTS SENSOR 3-CIRCUIT SHORT TO BATTERY
 B1290-25-PTS SENSOR 3-SIGNAL SHAPE / WAVEFORM FAILURE
 B1290-92-PTS SENSOR 3-PERFORMANCE OR INCORRECT OPERATION
 B1291-11-PTS SENSOR 4-CIRCUIT SHORT TO GROUND
 B1291-12-PTS SENSOR 4-CIRCUIT SHORT TO BATTERY
 B1291-25-PTS SENSOR 4-SIGNAL SHAPE / WAVEFORM FAILURE
 B1291-92-PTS SENSOR 4-PERFORMANCE OR INCORRECT OPERATION
 B1292-11-PTS SENSOR 5-CIRCUIT SHORT TO GROUND
 B1292-12-PTS SENSOR 5-CIRCUIT SHORT TO BATTERY
 B1292-25-PTS SENSOR 5-SIGNAL SHAPE / WAVEFORM FAILURE
 B1295-92-PTS SENSOR 5-PERFORMANCE OR INCORRECT OPERATION
 B1293-11-PTS SENSOR 6-CIRCUIT SHORT TO GROUND
 B1293-12-PTS SENSOR 6-CIRCUIT SHORT TO BATTERY
 B1293-25-PTS SENSOR 6-SIGNAL SHAPE / WAVEFORM FAILURE
 B1293-92-PTS SENSOR 6-PERFORMANCE OR INCORRECT OPERATION
 B1295-11-PTS SENSOR 8 CIRCUIT SHORT TO GROUND
 B1295-12-PTS SENSOR 8-CIRCUIT SHORT TO BATTERY
 B1295-25-PTS SENSOR 8-SIGNAL SHAPE / WAVEFORM FAILURE
 B1295-92-PTS SENSOR 8-PERFORMANCE OR INCORRECT OPERATION
 B1296-11-PTS SENSOR 9-CIRCUIT SHORT TO GROUND
 B1296-12-PTS SENSOR 9-CIRCUIT SHORT TO BATTERY
 B1296-25-PTS SENSOR 9-SIGNAL SHAPE / WAVEFORM FAILURE
 B1296-92-PTS SENSOR 9-PERFORMANCE OR INCORRECT OPERATION
 B1297-11-PTS SENSOR 10-CIRCUIT SHORT TO GROUND
 B1297-12-PTS SENSOR 10-CIRCUIT SHORT TO BATTERY
 B1297-25-PTS SENSOR 10-SIGNAL SHAPE / WAVEFORM FAILURE
 B1297-92-PTS SENSOR 10-PERFORMANCE OR INCORRECT OPERATION
 B1298-11-PTS SENSOR 11-CIRCUIT SHORT TO GROUND
 B1298-12-PTS SENSOR 11-CIRCUIT SHORT TO BATTERY
 B1298-25-PTS SENSOR 11-SIGNAL SHAPE / WAVEFORM FAILURE
 B1298-92-PTS SENSOR 11-PERFORMANCE OR INCORRECT OPERATION
 B210C-16-BATTERY VOLTAGE INPUT-CIRCUIT VOLTAGE BELOW THRESHOLD
 B210C-17-BATTERY VOLTAGE INPUT-CIRCUIT VOLTAGE ABOVE THRESHOLD
 B2128-16-SENSOR SUPPLY VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD
 B2128-17-SENSOR SUPPLY VOLTAGE-CIRCUIT VOLTAGE ABOVE THRESHOLD
 B2129-16-PTS DISPLAY SUPPLY VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD
 B21DD-16-SYSTEM VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD
 B21DD-17-SYSTEM VOLTAGE-CIRCUIT VOLTAGE ABOVE THRESHOLD
 B222A-00-VEHICLE LINE MISMATCH
 B2232-00-(PTS) PARKTRONICS INTERNAL
 B2233-00-(PTS) PARKTRONICS FRONT DISPLAY INTERNAL
 B2234-00-(PTS) PARKTRONICS REAR DISPLAY INTERNAL
 U0010-00-CAN INTERIOR BUS
 U0141-00-LOST COMMUNICATION WITH IPM (FCM/TIPM)
 U0155-00-LOST COMMUNICATION WITH CLUSTER/CCN
 U0423-00-IMPLAUSIBLE DATA RECEIVED FROM CLUSTER/CCN
 U0431-00-IMPLAUSIBLE DATA RECEIVED FROM IPM (FCM/TIPM)
 U1101-00-LOST COMMUNICATION WITH PTS DISPLAY-REAR 1
 U112B-00-LOST COMMUNICATION WITH PTS DISPLAY-FRONT 1
 MODULE, Passenger Door (PDM)
 B16A4-PASSENGER WINDOW SWITCH BACKLIGHTING CIRCUIT LOW
 B16A5-PASSENGER WINDOW SWITCH BACKLIGHTING CIRCUIT HIGH
 B185D-PASSENGER WINDOW SWITCH CIRCUIT STUCK
 B185F-PASSENGER WINDOW MOTOR CONTROL CIRCUIT LOW
 B1860-PASSENGER WINDOW MOTOR CONTROL CIRCUIT HIGH
 B1863-PASSENGER WINDOW POSITION SENSOR POWER SUPPLY LOW
 B1864-PASSENGER WINDOW POSITION SENSOR POWER SUPPLY HIGH
 B1865-PASSENGER WINDOW POSITION SENSOR CIRCUIT PERFORMANCE
 B1D12-PASSENGER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT LOW
 B1D13-PASSENGER MIRROR POSITION SENSOR POWER SUPPLY CIRCUIT HIGH
 B1D15-PASSENGER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT LOW
 B1D16-PASSENGER MIRROR VERTICAL POSITION SENSOR INPUT CIRCUIT HIGH
 B1D18-PASSENGER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT LOW
 B1D19-PASSENGER MIRROR HORIZONTAL POSITION SENSOR INPUT CIRCUIT HIGH
 B1D2A-PASSENGER MIRROR VERTICAL MOTOR CONTROL CIRCUIT/PERFORMANCE
 B1D2E-PASSENGER MIRROR HORIZONTAL MOTOR CONTROL CIRCUIT/PERFORMANCE
 B2219-PASSENGER DOOR MODULE INTERNAL
 B2577-PASSENGER WINDOW NOT CALIBRATED/LOST CALIBRATION
 B2581-PASSENGER WINDOW POSITION SENSOR(S) NO SIGNAL
 U0019-CAN B BUS
 MODULE, Passive Entry (PEM)
 B1A71-01-PASSIVE ENTRY ANTENNA 1 - GENERAL ELECTRICAL FAILURE
 B1A72-01-PASSIVE ENTRY ANTENNA 2 - GENERAL ELECTRICAL FAILURE
 B1A73-01-PASSIVE ENTRY ANTENNA 3 - GENERAL ELECTRICAL FAILURE
 B1A74-01-PASSIVE ENTRY ANTENNA 4 - GENERAL ELECTRICAL FAILURE
 B2199-16-BATTERY VOLTAGE - CIRCUIT VOLTAGE BELOW THRESHOLD
 B2199-17-BATTERY VOLTAGE - CIRCUIT VOLTAGE ABOVE THRESHOLD
 B21DD-84-SYSTEM VOLTAGE - SIGNAL BELOW ALLOWABLE RANGE
 B219DD-85-SYSTEM VOLTAGE - SIGNAL ABOVE ALLOWABLE RANGE
 B2205-00-ORIGINAL VIN MISSING/MISMATCH
 B223B-00-VEHICLE CONFIGURATION MISMATCH
 B229B-00-PASSIVE ENTRY MODULE (PEM) INTERNAL
 B259A-00-FRONT LEFT DOOR HANDLE SENSE
 B259B-00-FRONT RIGHT DOOR HANDLE SENSE
 B259E-00-TRUNK/LIFTGATE DOOR HANDLE SENSE
 B25A3-00-FRONT LEFT DOOR HANDLE SENSOR
 B25A4-00-FRONT RIGHT DOOR HANDLE SENSOR
 U0019-00-CAN B BUS
 U0020-00-CAN B BUS OFF PERFORMANCE
 U0021-00-CAN B BUS (+) CIRCUIT OPEN
 U0022-00-CAN B BUS (+) CIRCUIT LOW
 U0023-00-CAN B BUS (+) CIRCUIT HIGH
 U0024-00-CAN B BUS (-) CIRCUIT OPEN
 U0025-00-CAN B BUS (-) CIRCUIT LOW
 U0026-00-CAN B BUS (-) CIRCUIT HIGH
 MODULE, Police/Taxi Interface (PTIM)
 P1462-FUEL LEVEL OUTPUT CIRCUIT LOW
 P1463-FUEL LEVEL OUTPUT CIRCUIT HIGH
 P1504-VEHICLE SPEED OUTPUT CIRCUIT LOW
 P1505-VEHICLE SPEED OUTPUT CIRCUIT HIGH
 P164A-MIL OUTPUT CIRCUIT LOW
 P164B-MIL OUTPUT CIRCUIT HIGH
 P170A-PARK/NEUTRAL OUTPUT CIRCUIT LOW
 P170B-PARK/NEUTRAL OUTPUT CIRCUIT HIGH
 P170C-ENGINE RPM OUTPUT CIRCUIT LOW
 P170D-ENGINE RPM OUTPUT CIRCUIT HIGH
 C1088-BRAKE LAMP SWITCH OUTPUT CIRCUIT LOW
 C1089-BRAKE LAMP OUTPUT CIRCUIT HIGH
 B1693-ACCESSORY DIMMING CONTROL CIRCUIT LOW
 B1694-ACCESSORY DIMMING CONTROL CIRCUIT HIGH
 B17CF-EMERGENCY FLASHING LAMP REQUEST 1 CIRCUIT HIGH
 B17D2-EMERGENCY FLASHING LAMP REQUEST 2 CIRCUIT HIGH
 B17D4-HEADLAMP STATUS OUTPUT CIRCUIT LOW
 B17D5-HEADLAMP STATUS OUTPUT CIRCUIT HIGH
 B19B4-DRIVER DOOR AJAR OUTPUT CIRCUIT LOW
 B19B5-DRIVER DOOR AJAR OUTPUT CIRCUIT HIGH
 B1A5B-PANIC ALARM MUTE REQUEST CIRCUIT HIGH
 B1A5D-PANIC ALARM ACTIVATION OUTPUT CIRCUIT LOW
 B1A5E-PANIC ALARM ACTIVATION STATUS CIRCUIT HIGH
 B1CC1-DEPLOYMENT NOTIFICATION OUTPUT CIRCUIT LOW
 B1CC2-DEPLOYMENT NOTIFICATION OUTPUT CIRCUIT HIGH
 B237C-DATA COMMUNICATION RADIO INPUT CIRCUIT HIGH
 B237F-HORN MUTE REQUEST CIRCUIT HIGH
 B2381-DRIVER SEAT BELT OUTPUT CIRCUIT LOW
 B2382-DRIVER SEAT BELT OUTPUT CIRCUIT HIGH
 B2384-HORN SWITCH OUTPUT CIRCUIT LOW
 B2385-HORN SWITCH OUTPUT CIRCUIT HIGH
 B2720-FRONTAL IMPACT OUTPUT CIRCUIT LOW
 B271F-FRONTAL IMPACT OUTPUT CIRCUIT HIGH
 U0021-CAN B BUS (+) CIRCUIT OPEN
 U0022-CAN B BUS (+) CIRCUIT LOW
 U0023-CAN B BUS (+) CIRCUIT HIGH
 U0024-CAN B BUS (-) CIRCUIT OPEN
 U0025-CAN B BUS (-) CIRCUIT LOW
 U0026-CAN B BUS (-) CIRCUIT HIGH
 U0156-LOST COMMUNICATION WITH ELECTRONIC OVERHEAD MODULE
 U0159-LOST COMMUNICATION WITH PARK ASSIST CONTROL MODULE
 U0212-LOST COMMUNICATION WITH STEERING COLUMN CONTROL MODULE
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
MODULE, Powertrain Control (PCM), NGC
 P000B-BANK 1 CAMSHAFT 2 POSITION SLOW RESPONSE
 P0013-BANK 1 CAMSHAFT 2 POSITION ACTUATOR CIRCUIT OPEN
 P0014-EXHAUST TARGET ERROR BANK 1
 P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 2.7L
 P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 3.5L
 P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT - BANK 1 SENSOR 1 - 5.7L/SRT8
 P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
 P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
 P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
 P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
 P0051-O2 SENSOR 2/1 HEATER CIRCUIT LOW
 P0052-O2 SENSOR 2/1 HEATER CIRCUIT HIGH
 P0057-O2 SENSOR 2/2 HEATER CIRCUIT LOW
 P0058-O2 SENSOR 2/2 HEATER CIRCUIT HIGH
 P0071-AMBIENT AIR TEMPERATURE SENSOR PERFORMANCE
 P0072-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW
 P0073-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH
 P0107-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT LOW
 P0108-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH
 P0111-INTAKE AIR TEMPERATURE SENSOR 1 PERFORMANCE
 P0112-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT LOW
 P0113-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT HIGH
 P0116-ENGINE COOLANT TEMPERATURE SENSOR PERFORMANCE
 P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW - 2.7L
 P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW - 3.5L/5.7L/SRT8
 P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH - 2.7L
 P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH - 3.5L/5.7L/SRT8
 P0121-THROTTLE POSITION SENSOR 1 PERFORMANCE
 P0122-THROTTLE POSITION SENSOR 1 CIRCUIT LOW
 P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH
 P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
 P0128-THERMOSTAT RATIONALITY
 P0129-BAROMETRIC PRESSURE OUT-OF-RANGE LOW
 P0131-O2 SENSOR 1/1 CIRCUIT LOW
 P0132-O2 SENSOR 1/1 CIRCUIT HIGH
 P0133-O2 SENSOR 1/1 SLOW RESPONSE
 P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
 P0137-O2 SENSOR 1/2 CIRCUIT LOW
 P0138-O2 SENSOR 1/2 CIRCUIT HIGH
 P0139-O2 SENSOR 1/2 SLOW RESPONSE
 P013A-O2 SENSOR 1/2 SLOW RESPONSE - RICH TO LEAN
 P013C-O2 SENSOR 2/2 SLOW RESPONSE - RICH TO LEAN
 P0140-O2 SENSOR 1/2 NO ACTIVITY DETECTED
 P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
 P0151-O2 SENSOR 2/1 CIRCUIT LOW
 P0152-O2 SENSOR 2/1 CIRCUIT HIGH
 P0153-O2 SENSOR 2/1 SLOW RESPONSE
 P0155-O2 SENSOR 2/1 HEATER PERFORMANCE
 P0157-O2 SENSOR 2/2 CIRCUIT LOW
 P0158-O2 SENSOR 2/2 CIRCUIT HIGH
 P0159-O2 SENSOR 2/2 SLOW RESPONSE
 P0160-O2 SENSOR 2/2 NO ACTIVITY DETECTED
 P0161-O2 SENSOR 2/2 HEATER PERFORMANCE
 P0171-FUEL SYSTEM 1/1 LEAN
 P0172-FUEL SYSTEM 1/1 RICH
 P0174-FUEL SYSTEM 2/1 LEAN
 P0175-FUEL SYSTEM 2/1 RICH
 P0196-ENGINE OIL TEMPERATURE SENSOR PERFORMANCE
 P0197-ENGINE OIL TEMPERATURE SENSOR CIRCUIT LOW
 P0198-ENGINE OIL TEMPERATURE SENSOR CIRCUIT HIGH
 P0201-FUEL INJECTOR 1 CIRCUIT/OPEN
 P0202-FUEL INJECTOR 2 CIRCUIT/OPEN
 P0203-FUEL INJECTOR 3 CIRCUIT/OPEN
 P0204-FUEL INJECTOR 4 CIRCUIT/OPEN
 P0205-FUEL INJECTOR 5 CIRCUIT/OPEN
 P0206-FUEL INJECTOR 6 CIRCUIT/OPEN
 P0207-FUEL INJECTOR 7 CIRCUIT/OPEN
 P0208-FUEL INJECTOR 8 CIRCUIT/OPEN
 P0221-THROTTLE POSITION SENSOR 2 CIRCUIT PERFORMANCE
 P0222-THROTTLE POSITION SENSOR 2 CIRCUIT LOW
 P0223-THROTTLE POSITION SENSOR 2 CIRCUIT HIGH
 P0298-ENGINE OIL TEMPERATURE TOO HIGH
 P0300-MULTIPLE CYLINDER MISFIRE
 P0301-CYLINDER 1 MISFIRE
 P0302-CYLINDER 2 MISFIRE
 P0303-CYLINDER 3 MISFIRE
 P0304-CYLINDER 4 MISFIRE
 P0305-CYLINDER 5 MISFIRE
 P0306-CYLINDER 6 MISFIRE
 P0307-CYLINDER 7 MISFIRE
 P0308-CYLINDER 8 MISFIRE
 P0315-NO CRANK SENSOR LEARNED
 P0325-KNOCK SENSOR 1 CIRCUIT
 P0330-KNOCK SENSOR 2 CIRCUIT
 P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
 P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
 P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 2.7
 P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 3.5L
 P0340-CAMSHAFT POSITION SENSOR CIRCUIT - BANK 1 SENSOR 1 - 5.7L/SRT8
 P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 2.7L
 P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 3.5L
 P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 5.7L/SRT8
 P0401-EGR SYSTEM PERFORMANCE
 P0403-EGR CONTROL CIRCUIT/OPEN
 P0404-EGR POSITION SENSOR PERFORMANCE
 P0405-EGR POSITION SENSOR CIRCUIT LOW
 P0406-EGR POSITION SENSOR CIRCUIT HIGH
 P0420-CATALYST EFFICIENCY (BANK 1)
 P0430-CATALYST EFFICIENCY (BANK 2)
 P0440-GENERAL EVAP SYSTEM FAILURE
 P0441-EVAP PURGE SYSTEM PERFORMANCE
 P0443-EVAP PURGE CONTROL CIRCUIT
 P0452-EVAP PRESSURE SWITCH STUCK CLOSED
 P0455-EVAP SYSTEM LARGE LEAK
 P0456-EVAP SYSTEM SMALL LEAK
 P0457-LOOSE FUEL CAP
 P0461-FUEL LEVEL SENSOR 1 PERFORMANCE
 P0462-FUEL LEVEL SENSOR 1 CIRCUIT LOW
 P0463-FUEL LEVEL SENSOR 1 CIRCUIT HIGH
 P0480-COOLING FAN 1 CONTROL CIRCUIT
 P0481-COOLING FAN 2 CONTROL CIRCUIT
 P050B-COLD START IGNITION TIMING PERFORMANCE
 P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE (Equipped with ABS)
 P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE (Not Equipped with ABS)
 P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Equipped with ABS)
 P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Not Equipped with ABS)
 P0506-IDLE SPEED PERFORMANCE LOWER THAN EXPECTED
 P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXPECTED
 P050D-COLD START ROUGH IDLE
 P0513-INVALID SKIM KEY
 P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT
 P0521-ENGINE OIL PRESSURE SENSOR PERFORMANCE
 P0522-ENGINE OIL PRESSURE SENSOR CIRCUIT LOW
 P0522-OIL PRESSURE TOO LOW - 3.5L
 P0523-ENGINE OIL PRESSURE SENSOR CIRCUIT HIGH
 P0524-ENGINE OIL PRESSURE TOO LOW
 P0551-POWER STEERING PRESSURE SWITCH PERFORMANCE
 P0571-BRAKE SWITCH 1 PERFORMANCE
 P0572-BRAKE SWITCH 1 STUCK ON
 P0579-SPEED CONTROL SWITCH 1 PERFORMANCE (EXCEPT POLICE PACKAGE)
 P0579-SPEED CONTROL SWITCH 1 PERFORMANCE (POLICE PACKAGE)
 P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW (EXCEPT POLICE PACKAGE)
 P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW (POLICE PACKAGE)
 P0585-SPEED CONTROL SWITCH 1/2 CORRELATION (EXCEPT POLICE PACKAGE)
 P0585-SPEED CONTROL SWITCH 1/2 CORRELATION (POLICE PACKAGE)
 P0591-SPEED CONTROL SWITCH 2 PERFORMANCE (EXCEPT POLICE PACKAGE)
 P0591-SPEED CONTROL SWITCH 2 PERFORMANCE (POLICE PACKAGE)
 P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW (EXCEPT POLICE PACKAGE)
 P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW (POLICE PACKAGE)
 P0600-SERIAL COMMUNICATION LINK
 P0601-INTERNAL MEMORY CHECKSUM INVALID
 P0606-INTERNAL CONTROL PROCESSOR
 P060B-ETC A/D GROUND PERFORMANCE
 P060D-ETC LEVEL 2 APP PERFORMANCE
 P060E-ETC LEVEL 2 TPS PERFORMANCE
 P060F-ETC LEVEL 2 ECT PERFORMANCE
 P061A-ETC LEVEL 2 TORQUE PERFORMANCE
 P061C-ETC LEVEL 2 RPM PERFORMANCE
 P0622-GENERATOR FIELD CONTROL CIRCUIT/OPEN
 P0627-FUEL PUMP CONTROL CIRCUIT/OPEN
 P062C-ETC LEVEL 2 MPH PERFORMANCE
 P0630-VIN NOT PROGRAMMED IN PCM
 P0632-ODOMETER NOT PROGRAMMED IN PCM
 P0633-SKIM SECRET KEY NOT STORED IN PCM
 P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
 P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
 P0645-A/C CONTROL CIRCUIT/OPEN
 P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
 P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH
 P0660-MANIFOLD TUNING VALVE (MTV) CONTROL CIRCUIT
 P0685-AUTO SHUTDOWN CONTROL CIRCUIT
 P0688-ASD/MAIN SENSE CIRCUIT
 P0573-BRAKE SWITCH 1 STUCK OFF
 P0700-TRANSMISSION CONTROL SYSTEM (MIL REQUEST)
 P0703-BRAKE SWITCH 2 PERFORMANCE
 P0850-PARK/NEUTRAL SWITCH PERFORMANCE
 P1004-SHORT RUNNER VALVE CONTROL PERFORMANCE
 P1005-MANIFOLD TUNING VALVE CONTROL PERFORMANCE
 P1115-GENERAL TEMPERATURE RATIONALITY
 P1128-CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
 P1129-CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
 P1239-ENGINE OIL TEMPERATURE TOO LOW
 P1404-EGR CLOSE POSITION PERFORMANCE
 P1411-CYLINDER 1 REACTIVATION CONTROL PERFORMANCE
 P1414-CYLINDER 4 REACTIVATION CONTROL PERFORMANCE
 P1416-CYLINDER 6 REACTIVATION CONTROL PERFORMANCE
 P1417-CYLINDER 7 REACTIVATION CONTROL PERFORMANCE
 P1501-VEHICLE SPEED SENSOR 1/2 CORRELATION - DRIVE WHEELS (Equipped with ABS)
 P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS (Equipped with ABS)
 P150D-COLD START ROUGH IDLE - OPEN THROTTLE START
 P1521-INCORRECT ENGINE OIL TYPE
 P1524- OIL PRESSURE OUT OF RANGE - CAMSHAFT ADVANCE/RETARD DISABLED
 P1572-BRAKE PEDAL STUCK ON
 P1573-BRAKE PEDAL STUCK OFF
 P1593-SPEED CONTROL SWITCH 1/2 STUCK (EXCEPT POLICE PACKAGE)
 P1593-SPEED CONTROL SWITCH 1/2 STUCK (POLICE PACKAGE)
 P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION FAILURE
 P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
 P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
 P1618-SENSOR REFERENCE VOLTAGE 1 ERRATIC
 P1628-SENSOR REFERENCE VOLTAGE 2 ERRATIC
 P1696-EEPROM MEMORY WRITE DENIED/INVALID
 P1697-EMR (SRI) MILEAGE NOT STORED
 P1897-LVL2 RPM FAIL - NO POST
 P2008-SHORT RUNNER VALVE (SRV) CONTROL CIRCUIT
 P2016-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT LOW
 P2017-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT HIGH
 P2066-FUEL LEVEL SENSOR 2 PERFORMANCE
 P2067-FUEL LEVEL SENSOR 2 CIRCUIT LOW
 P2068-FUEL LEVEL SENSOR 2 CIRCUIT HIGH
 P2072-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE
 P2077-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT LOW
 P2078-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT HIGH
 P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
 P2097-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH
 P2098-DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN
 P2099-DOWNSTREAM FUEL TRIM SYSTEM 2 RICH
 P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT/OPEN - BANK 1
 P2101-ELECTRONIC THROTTLE CONTROL MOTOR PERFORMANCE - BANK 1
 P2107-ELECTRONIC THROTTLE CONTROL MODULE PROCESSOR
 P2108-ELECTRONIC THROTTLE CONTROL MODULE PERFORMANCE
 P2110-ELECTRONIC THROTTLE CONTROL SYSTEM - FORCED LIMITED RPM
 P2111-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO CLOSE
 P2112-ELECTRONIC THROTTLE CONTROL SYSTEM - UNABLE TO OPEN
 P2115-ACCELERATOR PEDAL POSITION SENSOR 1 MINIMUM STOP PERFORMANCE
 P2116-ACCELERATOR PEDAL POSITION SENSOR 2 MINIMUM STOP PERFORMANCE
 P2118-ELECTRONIC THROTTLE CONTROL MOTOR CURRENT PERFORMANCE
 P2122-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW
 P2123-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH
 P2127-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW
 P2128-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH
 P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION
 P2138-ACCELERATOR PEDAL POSITION SENSOR 1/2 CORRELATION
 P2161-VEHICLE SPEED SENSOR 2 ERRATIC (with ABS)
 P2166-ACCELERATOR PEDAL POSITION SENSOR 1 MAXIMUM STOP PERFORMANCE
 P2167-ACCELERATOR PEDAL POSITION SENSOR 2 MAXIMUM STOP PERFORMANCE
 P2172-HIGH AIRFLOW/VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION)
 P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION)
 P2174-LOW AIRFLOW/RESTRICTION DETECTED (INSTANTANEOUS ACCUMULATION)
 P2175-LOW AIRFLOW/RESTRICTION DETECTED (SLOW ACCUMULATION)
 P2181-COOLING SYSTEM PERFORMANCE
 P2271-O2 SENSOR 1/2 SIGNAL BIASED RICH
 P2273-O2 SENSOR 2/2 SIGNAL BIASED RICH
 P2299-BRAKE PEDAL POSITION/ACCELERATOR PEDAL POSITION INCOMPATIBLE
 P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
 P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
 P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
 P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
 P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
 P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2317-IGNITION COIL 6 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 2.7/3.5
 P2317-IGNITION COIL 6 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2320-IGNITION COIL 7 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2323-IGNITION COIL 8 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION - 5.7L/SRT8
 P2503-CHARGING SYSTEM OUTPUT LOW
 P2504-CHARGING SYSTEM OUTPUT HIGH
 P2533-IGNITION SWITCH RUN/START POSITION CIRCUIT
 P2610-PCM INTERNAL ENGINE OFF TIMER PERFORMANCE
 P3400-MDS RATIONALITY BANK 1
 P3401-MDS SOLENOID 1 CIRCUIT
 P3402-CYLINDER 1 DEACTIVATION CONTROL PERFORMANCE
 P3425-MDS SOLENOID 4 CIRCUIT
 P3426-CYLINDER 4 DEACTIVATION CONTROL PERFORMANCE
 P3441-MDS SOLENOID 6 CIRCUIT
 P3442-CYLINDER 6 DEACTIVATION CONTROL PERFORMANCE
 P3449-MDS SOLENOID 7 CIRCUIT
 P3450-CYLINDER 7 DEACTIVATION CONTROL PERFORMANCE
 P3497-MDS RATIONALITY BANK 2
 U0001-CAN C BUS
 U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE
 U0104-LOST COMMUNICATION WITH ACC MODULE
 U0141-LOST COMMUNICATION WITH FCM/TIPM
 U110A-LOST COMMUNICATION WITH SCM (SAS)
 U110C-LOST FUEL LEVEL MESSAGE
 U110E-LOST AMBIENT TEMPERATURE MESSAGE
 U110F-LOST FUEL VOLUME MESSAGE
 U1110-LOST VEHICLE SPEED MESSAGE
 U1113-LOST A/C PRESSURE MESSAGE
 U1120-LOST WHEEL DISTANCE MESSAGE
 U1186-LOST COMMUNICATION WITH CRUISE CONTROL MODULE
 U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED
 U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED
 U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED
 U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
 U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED
 U1431-IMPLAUSIBLE CCM DATA RECEIVED
 MODULE, Steering Control (SCM)
 B1489-STEERING WHEEL CONTROL AUDIO SWITCH CIRCUIT
 B148A-STEERING WHEEL CONTROL MENU SWITCH CIRCUIT
 B148B-STEERING WHEEL CONTROL UP SWITCH CIRCUIT
 B148C-STEERING WHEEL CONTROL DOWN SWITCH CIRCUIT
 B148D-STEERING WHEEL CONTROL SIDE SWITCH CIRCUIT
 B148E-STEERING WHEEL CONTROL [+] SWITCH CIRCUIT
 B148F-STEERING WHEEL CONTROL [-] SWITCH CIRCUIT
 B1490-STEERING WHEEL CONTROL C/T SWITCH CIRCUIT
 B1DA0-STEERING COLUMN TILT SWITCH CIRCUIT STUCK
 B1DA5-STEERING COLUMN TELESCOPE SWITCH CIRCUIT STUCK
 B2225-STEERING CONTROL MODULE INTERNAL
 B2332-HORN SWITCH INPUT CIRCUIT/PERFORMANCE
 P0585-SPEED CONTROL MULTIPLEXED SWITCH 1/2 CORRELATION
 U0019-CAN B BUS CIRCUIT
 U0155-LOST COMMUNICATION WITH CLUSTER / CCN
 U1109-LOST COMMUNICATION WITH LIN STEERING WHEEL CONTROLS
 MODULE, Sunroof (SUNR)
 B1841-SUNROOF OPEN SWITCH INPUT CIRCUIT HIGH
 B1844-SUNROOF CLOSE SWITCH INPUT CIRCUIT HIGH
 B1847-SUNROOF VENT SWITCH INPUT CIRCUIT HIGH
 B1849-SUNROOF MOTOR CONTROL CIRCUIT/PERFORMANCE (STALLED)
 B2227-SUNROOF ECU INTERNAL
 U0019-CAN B BUS
 MODULE, Tire Pressure (TPM)
 B21DD-84-SYSTEM VOLTAGE - SIGNAL VOLTAGE BELOW ALLOWABLE RANGE
 B21DD-85-SYSTEM VOLTAGE - SIGNAL ABOVE ALLOWABLE RANGE
 C0077-00-LOW TIRE PRESSURE
 C1501-96-TIRE PRESSURE SENSOR 1 - INTERNAL COMPONENT FAILURE
 C1502-96-TIRE PRESSURE SENSOR 2 - INTERNAL COMPONENT FAILURE
 C1503-96-TIRE PRESSURE SENSOR 3 - INTERNAL COMPONENT FAILURE
 C1504-96-TIRE PRESSURE SENSOR 4 - INTERNAL COMPONENT FAILURE
 C151C-00-TIRE PRESSURE SENSORS MISSING
 C151D-00-TIRE PRESSURE SENSOR LOCATION UNDETERMINED
 C1580-00-LEFT/RIGHT SIDE TIRE PRESSURE SENSOR LOCATION UNDETERMINED
 C1581-00-FRONT/REAR TIRE PRESSURE SENSOR LOCATION UNDETERMINED
 C2209-00-TIRE PRESSURE MONITOR INTERNAL
 U0001-00-CAN C BUS
 U0002-00-CAN C BUS OFF PERFORMANCE
 U0100-00-LOST COMMUNICATION WITH ECM/PCM
 U0121-00-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
 U0168-00-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (WIN/WCM)
 MODULE, Totally Integrated Power (TIPM)
 B10B4-CABIN HEATER 1 CONTROL CIRCUIT LOW
 B10B5-CABIN HEATER 1 CONTROL CIRCUIT HIGH
 B10B8-CABIN HEATER 2 CONTROL CIRCUIT LOW
 B10B9-CABIN HEATER 2 CONTROL CIRCUIT HIGH
 B162B-LEFT LOW BEAM DRIVER CIRCUIT LOW
 B162C-LEFT LOW BEAM CONTROL CIRCUIT HIGH
 B162F-RIGHT LOW BEAM CONTROL CIRCUIT LOW
 B1630-RIGHT LOW BEAM CONTROL CIRCUIT HIGH
 B1633-LEFT HI BEAM CONTROL CIRCUIT LOW
 B1634-LEFT HI BEAM CONTROL CIRCUIT HIGH
 B1637-RIGHT HI BEAM CONTROL CIRCUIT LOW
 B1638-RIGHT HI BEAM CONTROL CIRCUIT HIGH
 B163B-FRONT LEFT TURN CONTROL CIRCUIT LOW
 B163C-FRONT LEFT TURN CONTROL CIRCUIT HIGH
 B163F-FRONT RIGHT TURN CONTROL CIRCUIT LOW
 B1640-FRONT RIGHT TURN CONTROL CIRCUIT HIGH
 B1643-REAR LEFT TURN CONTROL CIRCUIT LOW
 B1644-REAR LEFT TURN CONTROL CIRCUIT HIGH
 B1647-REAR RIGHT TURN CONTROL CIRCUIT LOW
 B1648-REAR RIGHT TURN CONTROL CIRCUIT HIGH
 B1659-FRONT FOG LAMP CONTROL CIRCUIT LOW
 B165C-PARK LAMP CONTROL CIRCUIT LOW
 B165D-PARK LAMP CONTROL CIRCUIT HIGH
 B1660-FRONT FOG LAMP CONTROL CIRCUIT HIGH
 B1663-REAR FOG LAMP CONTROL CIRCUIT LOW
 B1667-REVERSE LAMP CONTROL CIRCUIT LOW
 B1664-REAR FOG LAMP CONTROL CIRCUIT HIGH
 B1668-REVERSE LAMP CONTROL CIRCUIT HIGH
 B1820-HOOD AJAR INPUT CIRCUIT HIGH
 B1D68-ADJUSTABLE PEDAL CONTROL CIRCUIT LOW
 B2101-IGNITION RUN/START INPUT LOW
 B2102-IGNITION RUN/START INPUT HIGH
 B2104-IGNITION RUN/START 1 CONTROL CIRCUIT LOW
 B2105-IGNITION RUN/START 1 CONTROL CIRCUIT HIGH
 B2112-5 VOLT SUPPLY CIRCUIT LOW
 B211E-IGNITION RUN/ACC/PAD CONTROL CIRCUIT LOW
 B211F-IGNITION RUN/ACC/PAD CONTROL CIRCUIT HIGH
 B2122-IGNITION RUN CONTROL CIRCUIT LOW
 B2123-IGNITION RUN CONTROL CIRCUIT HIGH
 B2184-IGNITION UNLOCK RUN/START CONTROL CIRCUIT LOW
 B2215-FRONT CONTROL MODULE INTERNAL
 B222C-VEHICLE CONFIGURATION NOT PROGRAMMED
 B2304-WIPER PARK SWITCH INPUT CIRCUIT LOW
 B2305-WIPER PARK SWITCH INPUT CIRCUIT HIGH
 B2323-HEADLAMP WASHER MOTOR CONTROL CIRCUIT LOW
 B2324-HEADLAMP WASHER MOTOR CONTROL CIRCUIT HIGH
 B2328-WASHER FLUID LEVEL SENSOR INPUT CIRCUIT HIGH
 B2336-HORN CONTROL CIRCUIT LOW
 B2337-HORN CONTROL CIRCUIT HIGH
 B2346-WIPER MOTOR LOW SPEED CONTROL CIRCUIT LOW
 B2347-WIPER MOTOR LOW SPEED CONTROL CIRCUIT HIGH
 B234A-WIPER MOTOR HIGH SPEED CONTROL CIRCUIT LOW
 B234B-WIPER MOTOR HIGH SPEED CONTROL CIRCUIT HIGH
 C1007-BRAKE FLUID LEVEL CIRCUIT LOW
 C1008-BRAKE FLUID LEVEL CIRCUIT HIGH
 C1017-RIGHT FRONT WHEEL SPEED SENSOR CIRCUIT LOW
 C1018-RIGHT FRONT WHEEL SPEED SENSOR CIRCUIT HIGH
 P0532-A/C PRESSURE SENSOR CIRCUIT LOW
 P0533-A/C PRESSURE SENSOR CIRCUIT HIGH
 P0616-STARTER CONTROL CIRCUIT LOW - DIESEL
 P0616-STARTER CONTROL CIRCUIT LOW - NGC
 P0646-A/C CLUTCH CONTROL CIRCUIT LOW - DIESEL
 P0646-A/C CLUTCH CONTROL CIRCUIT 2 LOW - NGC
 P0647-A/C CLUTCH CONTROL CIRCUIT HIGH - DIESEL
 P0647-A/C CLUTCH CONTROL CIRCUIT 2 HIGH - NGC
 P0691-COOLING FAN 1 CONTROL CIRCUIT LOW
 P0692-COOLING FAN 1 CONTROL CIRCUIT HIGH
 P0693-COOLING FAN 2 CONTROL CIRCUIT LOW
 P0694-COOLING FAN 2 CONTROL CIRCUIT HIGH
 P0886-TCM POWER CONTROL CIRCUIT LOW
 P0887-TCM POWER CONTROL CIRCUIT HIGH
 U0001-CAN C BUS
 U0019-CAN B BUS
 U0102-LOST COMMUNICATION WITH DTCM
 U0104-LOST COMMUNICATION WITH CRUISE CONTROL MODULE
 U0127-LOST COMMUNICATION WITH TIRE PRESSURE MONITOR MODULE
 U0143-LOST COMMUNICATION WITH MULTI-PURPOSE MODULE (POLICE AND TAXI INTERFACE MODULE) (PTIM)
 U0196-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE - FIRST ROW
 U0203-LOST COMMUNICATION WITH DOOR MODULE FRONT LEFT - (DMFL) (DRIVER DOOR MODULE - DDM)
 U0204-LOST COMMUNICATION WITH DOOR MODULE FRONT RIGHT - (DMFR) (PASSENGER DOOR MODULE - PDM)
 U0241-LOST COMMUNICATION WITH AUTO HIGHBEAM HEADLAMP CONTROL MODULE
 U0249-LOST COMMUNICATION WITH VEHICLE ENTERTAINMENT CONTROL MODULE - LAST ROW (VES3)
 U1105-CAN B SIGNAL MISSING
 U1106-CAN C SIGNAL MISSING
 U1108-ADDITIONAL CAN B ECU DETECTED
 U110A-LOST COMMUNICATION WITH SCM - CAN-C
 U1145-LOST COMMUNICATION WITH KEYLESS GO SECURITY MODULE
 U1148-ADDITIONAL CAN-C ECU DETECTED
 U1158-LOST COMMUNICATION WITH SATELLITE VIDEO RECEIVER
Old 02-03-2010, 11:58 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
MODULE, Transmission Control (TCM)
 P0219-ENGINE OVERSPEED
 P0602-CONTROL MODULE PROGRAMMING ERROR/NOT PROGRAMMED
 P0604-INTERNAL CONTROL MODULE RAM
 P0605-INTERNAL CONTROL MODULE ROM
 P0613-INTERNAL TRANSMISSION PROCESSOR
 P0614-ECM/TCM INCOMPATIBLE
 P0657-SOLENOID SUPPLY VOLTAGE CIRCUIT
 P0710-TRANSMISSION TEMPERATURE SENSOR CIRCUIT
 P0712-TRANSMISSION TEMPERATURE SENSOR LOW
 P0714-TRANSMISSION TEMPERATURE SENSOR INTERMITTENT
 P0717-INPUT SPEED SENSOR 1 CIRCUIT NO SIGNAL
 P0730-INCORRECT GEAR RATIO
 P0731-GEAR RATIO ERROR IN 1ST
 P0732-GEAR RATIO ERROR IN 2ND
 P0733-GEAR RATIO ERROR IN 3RD
 P0734-GEAR RATIO ERROR IN 4TH
 P0735-GEAR RATIO ERROR IN 5TH
 P0741-TORQUE CONVERTER CLUTCH CIRCUIT PERFORMANCE
 P0742-TORQUE CONVERTER CLUTCH STUCK ON
 P0743-TCC SOLENOID CIRCUIT
 P0748-MODULATOR PRESSURE SOLENOID CIRCUIT
 P0752-1-2/4-5 SOLENOID
 P0753-1-2/4-5 SOLENOID CIRCUIT
 P0757-2-3 SOLENOID
 P0758-2-3 SOLENOID CIRCUIT
 P0762-3-4 SOLENOID
 P0763-3-4 SOLENOID CIRCUIT
 P0778-SHIFT PRESSURE SOLENOID CIRCUIT
 P0817-STARTER DISABLE (P/N) CIRCUIT/OPEN
 P1629-TCM INTERNAL - SOLENOID SUPPLY/ WATCHDOG
 P1631-TCM INTERNAL- PROCESSOR CLOCK PERFORMANCE
 P1632-TCM INTERNAL - TEST INTERNAL WATCHDOG PERFORMANCE
 P1633-TCM INTERNAL - TEST EXTERNAL WATCHDOG PERFORMANCE
 P1634-TCM INTERNAL- INTERNAL WATCHDOG PERFORMANCE
 P1636-TCM INTERNAL- EXTERNAL WATCHDOG PERFORMANCE
 P1637-TCM INTERNAL-EEPROM PERFORMANCE
 P1638-TCM INTERNAL-CAN 1 RAM PERFORMANCE
 P1639-TCM INTERNAL-CAN 2 RAM PERFORMANCE
 P1704-INPUT SPEED SENSOR 1 OVERSPEED
 P1705-INPUT SPEED SENSOR 2 OVERSPEED
 P1731-INCORRECT GEAR ENGAGED
 P2638-TORQUE MANAGEMENT FEEDBACK SIGNAL PERFORMANCE
 P2767-INPUT SPEED SENSOR 2 CIRCUIT NO SIGNAL
 P2783-TORQUE CONVERTER TEMPERATURE TOO HIGH
 P2784-INPUT SPEED SENSOR 1/2 CORRELATION
 U0404-IMPLAUSIBLE DATA RECEIVED FROM ESM
 U0414-IMPLAUSIBLE DATA RECEIVED FROM FDCM
 U0423-IMPLAUSIBLE DATA RECEIVED FROM CLUSTER/CCN
 U0424-IMPLAUSIBLE DATA RECEIVED FROM HVAC CONTROL MODULE
 U0431-IMPLAUSIBLE DATA FROM FCM/TIPM
 U110B-LOST ENGINE COOLANT MESSAGE
 U1118-LOST ENGINE MESSAGE
 U1119-LOST FCM MESSAGE
 U1400-IMPLAUSIBLE TPS SIGNAL RECEIVED
 U1401-IMPLAUSIBLE ENGINE SPEED SIGNAL RECEIVED
 U1402-IMPLAUSIBLE ENGINE TEMPERATURE SIGNAL RECEIVED
 U1404-IMPLAUSIBLE STATIC ENGINE TORQUE SIGNAL RECEIVED
 U1405-IMPLAUSIBLE MINIMUM ENGINE TORQUE SIGNAL RECEIVED
 U1406-IMPLAUSIBLE MAXIMUM ENGINE TORQUE SIGNAL RECEIVED
 U1407-IMPLAUSIBLE ENGINE TORQUE REQUEST SIGNAL RECEIVED
 U1408-IMPLAUSIBLE BRAKE SIGNAL RECEIVED
 U1409-IMPLAUSIBLE LEFT FRONT WHEEL SPEED SIGNAL RECEIVED
 U140A-IMPLAUSIBLE RIGHT FRONT WHEEL SPEED SIGNAL RECEIVED
 U140B-IMPLAUSIBLE LEFT REAR WHEEL SPEED SIGNAL RECEIVED
 U140C-IMPLAUSIBLE RIGHT REAR WHEEL SPEED SIGNAL RECEIVED
 U140D-IMPLAUSIBLE WHEEL SPEED SIGNALS RECEIVED
 U140F-IMPLAUSIBLE ENGINE VARIANT DATA
 U1410-IMPLAUSIBLE/MISSING FCM VARIANT DATA
 U1505-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM FDCM
 U1507-IMPLAUSIBLE ENGINE TEMPERATURE MESSAGE DATA LENGTH RECEIVED
 U1508-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM ESM
 U1509-IMPLAUSIBLE ENGINE VARIANT MESSAGE DATA LENGTH RECEIVED
 U150A-IMPLAUSIBLE FCM VARIANT MESSAGE DATA LENGTH RECEIVED
 NODE, Cabin Compartment (CCN)
 B1084-LEFT HEATED SEAT SWITCH INPUT CIRCUIT/PERFORMANCE
 B1087-RIGHT HEATED SEAT SWITCH INPUT CIRCUIT/PERFORMANCE
 B1200-AIRBAG WARNING INDICATOR CIRCUIT LOW
 B1202-AIRBAG WARNING INDICATOR CIRCUIT OPEN
 B120E-LEFT HEATED SEAT HI INDICATOR CONTROL CIRCUIT HIGH
 B120F-LEFT HEATED SEAT HI INDICATOR CONTROL CIRCUIT OPEN
 B1216-LEFT HEATED SEAT LO INDICATOR CONTROL CIRCUIT HIGH
 B1217-LEFT HEATED SEAT LO INDICATOR CONTROL CIRCUIT OPEN
 B121A-RIGHT HEATED SEAT HI INDICATOR CONTROL CIRCUIT HIGH
 B121B-RIGHT HEATED SEAT HI INDICATOR CONTROL CIRCUIT OPEN
 B1222-RIGHT HEATED SEAT LO INDICATOR CONTROL CIRCUIT HIGH
 B1223-RIGHT HEATED SEAT LO INDICATOR CONTROL CIRCUIT OPEN
 B1225-REAR WIPER INDICATOR CONTROL CIRCUIT LOW
 B1226-REAR WIPER INDICATOR CONTROL CIRCUIT HIGH
 B1607-HEADLAMP SWITCH INPUT CIRCUIT LOW
 B1608-HEADLAMP SWITCH INPUT CIRCUIT HIGH
 B160A-PANEL DIMMER INPUT CIRCUIT LOW
 B160B-PANEL DIMMER INPUT CIRCUIT HIGH
 B1613-PANEL ILLUMINATION CONTROL CIRCUIT LOW
 B1614-PANEL ILLUMINATION CONTROL CIRCUIT HIGH
 B161B-COURTESY/DOME LAMP CONTROL CIRCUIT LOW
 B161F-READING LAMP CONTROL CIRCUIT LOW
 B168F-FRONT FOG LAMP SWITCH STUCK
 B1801-DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW
 B1803-DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK LOCK
 B1804-DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK UNLOCK
 B1806-PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW
 B1808-PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK LOCK
 B1809-PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK UNLOCK
 B1826-TRUNK RELEASE SWITCH INPUT CIRCUIT LOW
 B1A20-PRE-ARM TIMEOUT
 B2213-CCN INTERNAL
 C230D-TRAC/ESP OFF SWITCH INPUT CIRCUIT LOW
 P0460-FUEL LEVEL SENSOR 1 CIRCUIT
 P0462-FUEL LEVEL SENSOR 1 LOW CIRCUIT
 P0463-FUEL LEVEL SENSOR 1 HIGH CIRCUIT
 U0019-CAN B BUS
 NODE, Wireless Ignition (WIN)
 B1A08-RKE FOB 1 PERFORMANCE
 B1A09-RKE FOB 2 PERFORMANCE
 B1A0A-RKE FOB 3 PERFORMANCE
 B1A0B-RKE FOB 4 PERFORMANCE
 B1A0C-RKE FOB 5 PERFORMANCE
 B1A0D-RKE FOB 6 PERFORMANCE
 B1A0E-RKE FOB 7 PERFORMANCE
 B1A0F-RKE FOB 8 PERFORMANCE
 B1A10-RKE FOB 1 BATTERY LOW
 B1A11-RKE FOB 2 BATTERY LOW
 B1A12-RKE FOB 3 BATTERY LOW
 B1A13-RKE FOB 4 BATTERY LOW
 B1A14-RKE FOB 5 BATTERY LOW
 B1A15-RKE FOB 6 BATTERY LOW
 B1A16-RKE FOB 7 BATTERY LOW
 B1A17-RKE FOB 8 BATTERY LOW
 B1A24-KEY NOT PROGRAMMED
 B1A25-INVALID KEY
 B1A26-MAXIMUM NUMBER OF KEYS PROGRAMMED
 B1A27-WIN PROGRAMMING PERFORMANCE
 B1A28-ECM MISMATCH WITH SKIM
 B1A29-SKIM BASESTATION MISMATCH
 B1A35-UNIDENTIFIED KEY COMMUNICATION ERROR
 B1A68-STEERING COLUMN LOCK MODULE BOLT CONTROL LOW (WIN)
 B1A6B STEERING COLUMN LOCK MODULE NOT INITIALIZED
 B1A6C-SECRET KEY MISMATCH
 B1A77- REMOTE START ANTENNA CIRCUIT LOW
 B1A79- REMOTE START ANTENNA CIRCUIT OPEN OR NOT CONNECTED
 B2204-ECU CONFIGURATION MISMATCH
 B2224-SKREEM INTERNAL
 B2229-SKREEM INTERNAL - SKIM IMMOBILIZER
 B2254-COLUMN LOCK MODULE INTERNAL
 C0077-00- LOW TIRE PRESSURE
 C1501-96-TIRE PRESSURE MONITORING (TPM) SENSOR 1 INTERNAL
 C1502-96-TIRE PRESSURE SENSOR 2 INTERNAL
 C1503-96-TIRE PRESSURE SENSOR 3 INTERNAL
 C1504-96-TIRE PRESSURE SENSOR 4 INTERNAL
 P0928-BTSI CONTROL CIRCUIT
 U0236-LOST COMMUNICATION WITH COLUMN LOCK MODULE
 U1197-SECURITY SEED RESPONSE NOT RECEIVED FROM ECM/PCM
 RADIO
 B1401-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1402-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1403-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1405-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B1406-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B1407-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1409-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B140A-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B140B-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B140D-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
 B140E-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
 B140F-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
 B1421-AUDIO CD READ ERROR/INOPERABLE DISC
 B1422-AUDIO DVD READ ERROR/INOPERABLE DISC
 B1424-IMPROPER DVD-WRONG REGION
 B1429-RADIO DISPLAY HIGH TEMPERATURE
 B142A-RADIO UNIT HIGH TEMPERATURE
 B142D-AUDIO ANTENNA NOT CONNECTED
 B142E-GPS ANTENNA NOT CONNECTED
 B142F-SATELLITE RADIO ANTENNA NOT CONNECTED
 B1430(2.5)-SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
 B1430(4.0)-SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
 B145C-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B145D-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B145E-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B145F-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
 B1492-GENERAL MICROPHONE PERFORMANCE
 B14B7-MICROPHONE 1 CIRCUIT OPEN
 B14B8-MICROPHONE 2 CIRCUIT OPEN
 B156B-SATELLITE RADIO ANTENNA CIRCUIT
 B221E-RADIO INTERNAL
 U0019-CAN B BUS
 SYSTEM, Video Entertainment, Three (VES3)
 B142B-VES UNIT HIGH TEMPERATURE
 B14CE-VES BRIGHTNESS UP INPUT BUTTON STUCK
 B14CF-VES BRIGHTNESS DOWN INPUT BUTTON STUCK
 B21A1-ECU RESET/RECOVERY OCCURRED
 B222B-VEHICLE ENTERTAINMENT SYSTEM INTERNAL
 U0019-CAN B BUS
 U1158-LOST COMMUNICATION WITH SATELLITE VIDEO RECEIVER (SDARV)
 TRANSLATOR, High Intensity Discharge (HIDT)
 B167A-LEFT FRONT HEADLAMP LIGHT SOURCE CIRCUIT
 B167B-RIGHT FRONT HEADLAMP LIGHT SOURCE CIRCUIT
 B2235-LEFT FRONT HEADLAMP BALLAST ECU INTERNAL
 B2236-RIGHT FRONT HEADLAMP BALLAST ECU INTERNAL
 B2237-LEFT FRONT HEADLAMP BALLAST NOT CALIBRATED
 B2286-CALIBRATION NOT LEARNED/LOST CALIBRATION
 B2239-HID LEVELING TRANSLATOR ECU INTERNAL
 U0019-CAN B BUS
Old 02-03-2010, 12:12 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Big thanks goes to master tech for getting me the list to post for you all.
Quick Reply: DTC Codes here
