B2500 rear axle swap
Old 01-29-2010, 02:54 PM
ymmij's Avatar
ymmij
ymmij is offline
Default B2500 rear axle swap
I did a search on axle swaps and really could not find anything.
My question is what Year rear axles will swap out to a 96 b2500.
Thanks for looking.
Jimmy
Old 01-29-2010, 04:12 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
Hi jimmy
Do you have the floating rear axles or a 9 1/4 axles?
Old 01-29-2010, 06:30 PM
ymmij's Avatar
ymmij
ymmij is offline
Thanks for the welcome MT.
I'm going to say 9 1/4 being it has the 318 in it.There are no tags on this diff.Is there a easy way to ID the diff. without pulling the cover?
Thanks for the reply MT
Jimmy
Old 01-29-2010, 07:25 PM
master tech
Floating axles, you would remove 10 to 12 bolts on the end of the rear drums and put the axles out. Or remove the rear inspection cover and remove the C Clips that hold the axles into the rear carrier. I don't really know from what years that you can use from, but i would guess 1996 up to the last year they made the ram van, which i think was 2002 or 2003.
Old 01-30-2010, 01:09 PM
landyacht318's Avatar
landyacht318
landyacht318 is offline
The three most common axles for our vans are the 8 3/8 commonly called the 8 1/4, the 9.25, and HD 1 ton models can come with a Dana 40 or 60.
I had the 8 3/8 and bought a junkyard 9.25 and had to have that rebuilt.
This link will help you identify what you have by pictures of the diff cover.
Lots of other really good info in this site as well.
http://www.ringpinion.com/DiffList.a...=Diff&TypeID=2
Good luck
Old 02-04-2010, 12:54 AM
Rusty93RamVan's Avatar
Rusty93RamVan
Rusty93RamVan is offline
Jimmy
The vehicle's build tag (sticker under hood, usually) will tell you what differential was installed at the factory.
Old 02-14-2010, 07:57 PM
ymmij's Avatar
ymmij
ymmij is offline
Does the list below represent what can be direct bolt-in w/o modifications for the 96 dodge van B250 with a 9.25? Any help would be appreciated. Thanks.
Jimmy
1 Ton Chrysler Van: 1978 - 2009 (Rear) 1/2 Ton Chrysler Van: 1970 - 2009 (Rear) 1/2 Ton Dodge Pickup: 1974 - 2009 (Rear) 3/4 Ton Chrysler Van: 1974 - 2009 (Rear) 3/4 Ton Dodge Pickup: 1974 - 1999 (Rear) Dakota: 1988 - 2008 (Rear) Durango: 1998 - 2009 (Rear)
Old 02-14-2010, 09:55 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Mobile Auto Repair is offline
You can go to your local Dodge dealer and ask for a "Build Sheet" for your vin number and that will tell you which axle should be under your van. Plus it will give you more information regarding what your van came equipped with. Some times they need the vin to get you the correct part.
Old 02-14-2010, 10:15 PM
landyacht318
I replaced a 1989 8 3/8 with a 9.25 from a '96 van . The only mods I had to do was a different U joint on the driveshaft to accomidate the different sized yokes.
Just measure the distance between the leaf spring flats. And overall length.
If you are looking for the same ratio, and there is no tag. It is printed on the ring gear itself. Or you can count the teeth on the ring and divide by the number of teeth on the pinion.
As far as I know, any dodge van axle from 71 to 2003 will interchange.
And if you are looking for a junkyard axle, you could luck out and get a good one, or get one louder than the one you seek to replace, which happened to me.
Old 02-15-2010, 07:28 PM
ymmij's Avatar
ymmij
ymmij is offline
thanks for the replys.....guess i'll have to build one.
Quick Reply: B2500 rear axle swap
