Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
2007 to 2008 3.0 Diesel cont with trans codes
Old 01-22-2010, 11:43 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Default 2007 to 2008 3.0 Diesel cont with trans codes
2973-FUEL INJECTOR 4 VOLTAGE TOO HIGH
2973-FUEL INJECTOR 4 VOLTAGE TOO LOW
2974-FUEL INJECTOR 5 VOLTAGE TOO HIGH
2974-FUEL INJECTOR 5 VOLTAGE TOO LOW
2975-FUEL INJECTOR 6 VOLTAGE TOO HIGH
2975-FUEL INJECTOR 6 VOLTAGE TOO LOW
2978-EXHAUST GAS COOLER ACTUATOR - OPEN CIRCUIT
2979-PRESSURE REGULATOR VALVE VALUE TOO HIGH
2979-PRESSURE REGULATOR VALVE VALUE TOO LOW
3050-O2 SENSOR PART LOAD TOO HIGH
3050-O2 SENSOR PART LOAD TOO LOW
3080-ENGINE OIL SENSOR VALUE TOO HIGH
3087-CATALYTIC CONVERTER TEMPERATURE SENSOR OR TEMPERATURE SENSOR UPSTREAM OF DIESEL PARTICULATE FILTER FAULTY
3097-MONITORING AIR INTAKE VALUE TOO HIGH
3098-MONITORING AIR INTAKE VALUE TOO LOW
3099-MONITORING AIR INTAKE VALUE TOO LOW
3119-EXHAUST GAS TEMPERATURE SENSOR UPSTREAM OF CATALYTIC CONVERTER - PERFORMANCE
3121-CATALYTIC CONVERTER TEMPERATURE SENSOR VALUE TOO HIGH
3121-CATALYTIC CONVERTER TEMPERATURE SENSOR VALUE TOO LOW
3121-CATALYTIC CONVERTER TEMPERATURE SENSOR IMPLAUSIBLE VALUE
3130 INTAKE AIR TEMPERATURE SENSOR PLAUSIBILITY/PERFORMANCE
3131-02 SENSOR SHORT TO VOLTAGE
3131-02 SENSOR SHORT TO GROUND
3133-CATALYTIC CONVERTER MONITORING VALUE TOO LOW
3134-CATALYTIC CONVERTER MONITORING VALUE TOO LOW
3135-DIESEL PARTICULATE FILTER - VALUE TOO HIGH
3135-DIESEL PARTICULATE FILTER - VALUE TOO LOW
3136-DIESEL PARTICULATE FILTER - PRESSURE DIFFERENTIAL TOO HIGH
3137-DIESEL PARTICULATE FILTER - PRESSURE DIFFERENTIAL TOO LOW
3139-DIESEL PARTICULATE FILTER - VALUE TOO HIGH
3139-DIESEL PARTICULATE FILTER - VALUE TOO LOW
3154-MONITORING AIR INTAKE VALUE TOO HIGH
3155-MONITORING AIR INTAKE VALUE TOO LOW
EVENT 2217-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2218-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2219-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2220-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2221-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2222-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2223-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2224-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2225-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2226-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2227-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2228-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2229-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2230-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2231-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2232-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2294-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2295-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2296-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2297-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2298-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2299-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2800-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2801-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2802-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2803-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2804-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2805-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2806-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2807-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2808-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 2809-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
P0615-STARTER CONTROL SIGNAL INTERRUPTED
P0615-STARTER CONTROL EXCESSIVE CURRENT
P1270-INTAKE MANIFOLD RUNNER (SWIRL) PERFORMANCE
P2551-EGR AIRFLOW THROTTLE CONTROL CIRCUIT SHORT TO VOLTAGE
P2551-EGR AIRFLOW THROTTLE CONTROL CIRCUIT SHORTED TO GROUND
P2551-EGR AIRFLOW THROTTLE CONTROL CIRCUIT OVERLOAD
P2552-EGR AIRFLOW THROTTLE CONTROL CIRCUIT SHORTED TO GROUND
P2552-EGR AIRFLOW THROTTLE CONTROL CIRCUIT OVERLOAD
P2552-EGR AIRFLOW THROTTLE CONTROL CIRCUIT SHORT TO VOLTAGE
Standard Procedure
MODULE, Transmission Control (TCM)
Diagnosis and Testing
OVER VOLTAGE K187
UNDER VOLTAGE K187
CAN COMMUNICATION ERROR
LOST COMMUNICATION WITH ABS
LOST COMMUNICATION WITH EIS/CGW
LOST COMMUNICATION WITH CCN
ELECTRONIC SHIFT MODULE INTERNAL
PRNDL CONTROL CIRCUIT PERFORMANCE
PRNDL CONTROL CIRCUIT LOW
P0219-ENGINE OVERSPEED
P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0602-CONTROL MODULE PROGRAMMING ERROR/NOT PROGRAMMED
P0604-INTERNAL CONTROL MODULE RAM
P0605-INTERNAL CONTROL MODULE ROM
P0613-INTERNAL TRANSMISSION PROCESSOR
P0614-ECM/TCM INCOMPATIBLE
P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
P0657-SOLENOID SUPPLY VOLTAGE CIRCUIT
P0710-TRANSMISSION TEMPERATURE SENSOR CIRCUIT
P0712-TRANSMISSION TEMPERATURE SENSOR LOW
P0714-TRANSMISSION TEMPERATURE SENSOR INTERMITTENT
P0717-INPUT SPEED SENSOR 1 CIRCUIT NO SIGNAL
P0730-INCORRECT GEAR RATIO
P0731-GEAR RATIO ERROR IN 1ST
P0732-GEAR RATIO ERROR IN 2ND
P0733-GEAR RATIO ERROR IN 3RD
P0734-GEAR RATIO ERROR IN 4TH
P0735-GEAR RATIO ERROR IN 5TH
P0741-TORQUE CONVERTER CLUTCH CIRCUIT PERFORMANCE
P0742-TORQUE CONVERTER CLUTCH STUCK ON
P0743-TCC SOLENOID CIRCUIT
P0748-MODULATOR PRESSURE SOLENOID CIRCUIT
P0752-1-2/4-5 SOLENOID
P0753-1-2/4-5 SOLENOID CIRCUIT
P0757-2-3 SOLENOID
P0758-2-3 SOLENOID CIRCUIT
P0762-3-4 SOLENOID
P0763-3-4 SOLENOID CIRCUIT
P0778-SHIFT PRESSURE SOLENOID CIRCUIT
P0817-STARTER DISABLE (P/N) CIRCUIT/OPEN
P1629-TCM INTERNAL - SOLENOID SUPPLY/ WATCHDOG
P1631-TCM INTERNAL- PROCESSOR CLOCK PERFORMANCE
P1632-TCM INTERNAL - TEST INTERNAL WATCHDOG PERFORMANCE
P1633-TCM INTERNAL - TEST EXTERNAL WATCHDOG PERFORMANCE
P1634-TCM INTERNAL- INTERNAL WATCHDOG PERFORMANCE
P1636-TCM INTERNAL- EXTERNAL WATCHDOG PERFORMANCE
P1637-TCM INTERNAL-EEPROM PERFORMANCE
P1638-TCM INTERNAL-CAN 1 RAM PERFORMANCE
P1639-TCM INTERNAL-CAN 2 RAM PERFORMANCE
P1644-INCORRECT VARIANT/CONFIGURATION
P1704-INPUT SPEED SENSOR 1 OVERSPEED
P1705-INPUT SPEED SENSOR 2 OVERSPEED
P1731-INCORRECT GEAR ENGAGED
P2638-TORQUE MANAGEMENT FEEDBACK SIGNAL PERFORMANCE
P2767-INPUT SPEED SENSOR 2 CIRCUIT NO SIGNAL
P2783-TORQUE CONVERTER TEMPERATURE TOO HIGH
P2784-INPUT SPEED SENSOR 1/2 CORRELATION
U0002-CAN C BUS OFF PERFORMANCE
U0100-LOST COMMUNICATION WITH ECM/PCM
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE
U0155-LOST COMMUNICATION WITH CLUSTER/CCN
U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE
U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM
U0404-IMPLAUSIBLE DATA RECEIVED FROM ESM
U0414-IMPLAUSIBLE DATA RECEIVED FROM FDCM
U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS
U0423-IMPLAUSIBLE DATA RECEIVED FROM CLUSTER/CCN
U0424-IMPLAUSIBLE DATA RECEIVED FROM HVAC CONTROL MODULE
U0431-IMPLAUSIBLE DATA FROM FCM
U110B-LOST ENGINE COOLANT MESSAGE
U1118-LOST ENGINE MESSAGE
U1119-LOST FCM MESSAGE
U1400-IMPLAUSIBLE TPS SIGNAL RECEIVED
U1401-IMPLAUSIBLE ENGINE SPEED SIGNAL RECEIVED
U1402-IMPLAUSIBLE ENGINE TEMPERATURE SIGNAL RECEIVED
U1404-IMPLAUSIBLE STATIC ENGINE TORQUE SIGNAL RECEIVED
U1405-IMPLAUSIBLE MINIMUM ENGINE TORQUE SIGNAL RECEIVED
U1406-IMPLAUSIBLE MAXIMUM ENGINE TORQUE SIGNAL RECEIVED
U1407-IMPLAUSIBLE ENGINE TORQUE REQUEST SIGNAL RECEIVED
U1408-IMPLAUSIBLE BRAKE SIGNAL RECEIVED
U1409-IMPLAUSIBLE LEFT FRONT WHEEL SPEED SIGNAL RECEIVED
U140A-IMPLAUSIBLE RIGHT FRONT WHEEL SPEED SIGNAL RECEIVED
U140B-IMPLAUSIBLE LEFT REAR WHEEL SPEED SIGNAL RECEIVED
U140C-IMPLAUSIBLE RIGHT REAR WHEEL SPEED SIGNAL RECEIVED
U140D-IMPLAUSIBLE WHEEL SPEED SIGNALS RECEIVED
U140F-IMPLAUSIBLE ENGINE VARIANT DATA
U1410-IMPLAUSIBLE/MISSING FCM VARIANT DATA
U1505-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM FDCM
U1507-IMPLAUSIBLE ENGINE TEMPERATURE MESSAGE DATA LENGTH RECEIVED
U1508-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM ESM
U1509-IMPLAUSIBLE ENGINE VARIANT MESSAGE DATA LENGTH RECEIVED
U150A-IMPLAUSIBLE FCM VARIANT MESSAGE DATA LENGTH RECEIVED
Standard Procedure
Quick Reply: 2007 to 2008 3.0 Diesel cont with trans codes
