04 Cummins 2500 engs dies while driving
Old 01-20-2010, 02:32 PM
da rat's Avatar
da rat
da rat is offline
Default 04 Cummins 2500 engs dies while driving
Truck warmed up for 20 mins 30deg. outside. Drove 60 mph for 25 miles and went to change lanes when engine light came on lost engine power then stalled. Would restrart only to stall out immediately. Filled tank 150 miles ago. Never had problem before 117000 mile on vehicle. Going to repl. fuel filter and ck for bad fuel tomorrow. Anything else I should ck for.
Engine did not smoke when power was lost.
Any Help Appreciated
Rich
Old 01-20-2010, 03:27 PM
ecwrestoration@yahoo.com's Avatar
ecwrestoration@yahoo.com is offline
Cool
Put a catch pan under your fuel filter housing, open yellow drain valve, when it stops draining turn key to on (not start) listen for the fuel pump and see if its pumping fuel to the catch pan! Might be a bad fuel pump in tank!
Old 01-20-2010, 03:46 PM
Coal Train's Avatar
Coal Train
Coal Train is offline
Just to add to that, bump the starter for a moment (but do not start) this will make the pump cycle for 20 seconds vs the 1.5 seconds when you just turn the key on.
If no fuel comes out or there is very little pressure, then the lift pump is toast.
Old 01-20-2010, 03:58 PM
da rat's Avatar
da rat
da rat is offline
I will try that tomorrow had to leave in parking lot. What do you mean by lift pump.
Old 01-20-2010, 04:15 PM
pizzo's Avatar
pizzo
pizzo is offline
Your truck has a Lift pump It is mounted on the side of the engine. Their is a fuel filter housing there also.
CEL will come on when the fuel pump is toast??? IDK that... I learned something new today
You will need to get codes and let us know what they are.
Old 01-20-2010, 07:00 PM
da rat's Avatar
da rat
da rat is offline
That was my next question. Is there a way to get blink codes or do I need to hook a Diag. tester up to it
Old 01-20-2010, 07:10 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Try pyros key dance to obtain codes:
https://dodgeforum.com/forum/3rd-gen...-for-this.html
FF
Old 01-20-2010, 08:23 PM
da rat's Avatar
da rat
da rat is offline
Thanks Everyone will let you know tomorrow.
Old 01-21-2010, 10:28 AM
da rat's Avatar
da rat
da rat is offline
Codes given were:
p0113
p0148
p0628
Any help would be appreciated. Thanks
Old 01-21-2010, 11:02 AM
da rat's Avatar
da rat
da rat is offline
was told by dodge that upgrade goes in fuel tank now. Is there a company that make an aftermarket one to replace stock one.
Quick Reply: 04 Cummins 2500 engs dies while driving
