Old 08-06-2015, 12:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Low Beams not working
Old 01-18-2010, 08:42 PM
rocoforce's Avatar
rocoforce
rocoforce is offline
Default Low Beams not working
Hi, I'm new to this site and hope someone can guide me to the right area or is able to help fix my problem. I have a 2001 Ram 2500 5.9L Diesel and it's been a champ up until this fall when I crossed the 100,000 mile marker. At first, my low beam headlights seemed to quit working, then they would be OK.
When they would not work, I could switch over to the high beams and then back, usually it would fix the problem. I looked at a wiring diagram for the multifunction switch and figured it must just be a bad switch. Got a new multifunction switch from AutoZone ($59) and installed it with no problems. The lowbeams seemed to work normal again, but for just a day. Has anyone else had this issue and what was the fix? I've seen where someone said it was a loose cable, but which one? It appears that the controls to the headlights are all "Ground" related. Is it possible to hardwire a new ground with a relay and have the lowbeams on all the time, even when the highbeams are triggered? Thanks, looking forward to many great responses.
Old 01-18-2010, 08:57 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Maxx_Magnum is offline
What switch did you replace? the signal lights/high low beam switch? I'd be willing to bet that its yer headlight switch itself. I know of at least 3 or 4 dodges that had to have the headlight switch replaced because of the same problems.
Old 01-18-2010, 09:48 PM
halfamil's Avatar
halfamil
halfamil is offline
Yep, pullout headlight switch. A very common problem.
Old 01-18-2010, 09:58 PM
yakkier's Avatar
yakkier
yakkier is offline
<----- 55 bucks at the dealership * USED *
Old 01-18-2010, 10:05 PM
halfamil's Avatar
halfamil
halfamil is offline
Old 02-25-2010, 05:44 PM
t78allgood's Avatar
t78allgood
t78allgood is offline
I am having the same problem.. my low beams dont work at all but my high beams do.. i have changed out the bulbs and the pull out switch.. and nothin worked.. still no low beams.. i dont know where else to look???????
Old 02-25-2010, 06:11 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Except on a 1999 and newer (maybe even 1998), it won't be a pull out type switch. It'll be a rotary type. JFYI. But the fix is the same for either switch, replacement.
Did you replace the multifunction switch on the steering column?
Old 02-25-2010, 06:14 PM
Maxx_Magnum
Jason, in 98 they are still the pullout type
Old 02-25-2010, 06:28 PM
t78allgood's Avatar
t78allgood
hey guys i just found a thread with this info.. it could be very helpful!!!!!
my present to my fellow 2nd gen ram owners...
http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
2 0 0 1 s h o p m a n u a l
Old 02-25-2010, 07:57 PM
halfamil's Avatar
halfamil
halfamil is offline
If we knew what kind of truck you have would help you alot more.
Quick Reply: Low Beams not working
