2001 3.3L Dodge Grand Caravan - Serpentine Belt
Old 01-16-2010, 10:23 PM
KnuckleHead01's Avatar
KnuckleHead01
KnuckleHead01 is offline
Angry 2001 3.3L Dodge Grand Caravan - Serpentine Belt
How in the heck do you replace the serpentine belt on this vehicle. The side of the engine is so close to the passenger side engine compartment that I don't see anyway to release the tension on the belt tensioner to get the belt off.
Any special tools ????
Old 01-16-2010, 11:25 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Matco, Snap-on and mac tools have the tool that is need for the tensioner. Or maybe you can get a 3/8 drive ratchet to release the tension.
Old 01-17-2010, 10:21 AM
92dak5.24x4's Avatar
92dak5.24x4
92dak5.24x4 is offline
I bought a serpentine belt tool for $30 at the local tool store, it has a bunch of sockets, adapters and configurations to change the belt. Your van is a ton easier than doing a belt on a quad 4. now those really suck
Old 01-19-2010, 11:21 AM
vabear's Avatar
vabear
vabear is offline
Default Serpentine Belt
If it is only the belt, though it is a tight fit, the nut is 15MM and a box end wrench, ratchet with socket, or in my case a ratcheting box end wrench does the job. Rotate the tensioner clock wiseand the belt comes right off, putting it back on is a pisser IMHO.
Old 01-19-2010, 11:26 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
I use a long pry bar through the wheel well.
Old 01-19-2010, 12:25 PM
92dak5.24x4
I don't see how a prybar would work all that well. and if you don't have a hoist, trying to do a pry bar on your back is rather difficult. good suggestion, but in my experiences, the 15mm works the best and a $30 tensioner tool makes the job super easy
Old 01-19-2010, 03:08 PM
vabear's Avatar
vabear
vabear is offline
If you are in need of changing the tensioner there was a post with pictures in allpar.com done on a Chrysler T&C and I downloaded it to my documents. I cannot find that post on allpar but if you wish to eamil me at lazybears2@***.net I will try and send it to you.
Old 01-19-2010, 03:20 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
You pretty much have to do one of those from underneith anyway. I can't imagine trying to do one of those belts from the top.
Old 01-19-2010, 06:13 PM
dirtmover's Avatar
dirtmover
dirtmover is offline
Do it from above with a belt tool or ring spanner with some extra leverage. Before you start make sure you have sourced a replacement tensioner. When I did mine the tensioner was shot and would not apply tension to the belt when I released it. Changing the tensioner is a PITA.
Old 01-19-2010, 07:13 PM
vabear's Avatar
vabear
vabear is offline
The file I have uses a ratchet, 12"extension, 4"wobble extension and a 15 MM socket (all on a 3/8" drive). Come up from below and unscrew the nut and take the tensioner off, then put tensioner in place and wedge it there as you go under and strat the nut back on.
Quick Reply: 2001 3.3L Dodge Grand Caravan - Serpentine Belt
