Notices
Detailing Discuss detailing your ride inside and out here.
Whats the best tar remover?
Old 01-15-2010, 07:19 AM
dealrocker's Avatar
dealrocker
dealrocker is offline
Default Whats the best tar remover?
My friend own a Dodge Neon and he loves it. He went through a construction zone somewhere and don't how got tar on the bottom of the doors and fenders. It's a well know fact that tar can cause huge amounts of damage to a car paint and very tough to remove. Does anyone know of any products that will remove it easily.
Any product that easily available at Walmart store will be greatly appreciated.
Old 01-15-2010, 08:02 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Meguiars and Mothers make good ones. Try www.autogeek.com for products and tips on removing tar,
FF
Old 01-15-2010, 09:22 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
gas soaked rag.
Old 01-15-2010, 10:35 AM
1969CoronetR/T
vaffanculo
Gas will strip your clearcoat and can damage the paint...might as well use a shotgun,
FF
Old 01-15-2010, 04:39 PM
Bunky's Avatar
Bunky
Bunky is offline
Stoner's Tarminator is a good safe tar remover. It obviously strips wax too so you need to rewax any areas.
Old 01-20-2010, 11:50 PM
dbilik's Avatar
dbilik
dbilik is offline
WD-40. It probably isn't tar, it is primer, or emulsiphied asphalt. I'm an engineer and I have done a lot of paving, we always use WD-40 on a rag and wipe it off. Or, I should have said this first, try fabric softener. To clean the trucks we use fabric softener in the dump truck beds. The workers all use diesel fuel to clean their boot soles, but fabric softener is safer and smells less.
Old 01-26-2010, 11:06 PM
ultimateanswer's Avatar
ultimateanswer
ultimateanswer is offline
EcoLAB LAR!!! Label and adhesive remover! We use this stuff at CarMax and it is the business! Not to bad on price either around $4 by the bottle from your EcoLAB rep. But if you are looking at stuff you can buy at Wal-Mart then it is thinner all the way. Use it on a microfiber cloth and LIGHTLY rub the surface and away it goes!
Old 03-16-2010, 12:54 PM
dodgeman71's Avatar
dodgeman71
dodgeman71 is offline
dx330 tar and grease remover
Old 05-25-2010, 12:01 PM
Analyst's Avatar
Analyst
Analyst is offline
Petrol removes tar. Im serious, it may sound awkward to you but try it, petrol really works
Old 07-08-2010, 06:54 PM
oneHEMI57's Avatar
oneHEMI57
oneHEMI57 is offline
WD-40 or Trans fluid, soak small rag, rub and shake rag to snap the collected gravel out.
Quick Reply: Whats the best tar remover?
