How do you remove the headlight assembly?
Old 01-12-2010, 01:35 PM
Bradd_D's Avatar
Bradd_D
Bradd_D is offline
Default How do you remove the headlight assembly?
I need to change a bulb and I can't get the headlight assembly off. I removed the 3 Torx bolts, but there appears to be a plastic piece inside the fender well that is holding it. Do I need a college degree?
Old 01-12-2010, 01:41 PM
NJFF5860's Avatar
NJFF5860
NJFF5860 is offline
Pull Hard...just be sure not to scratch your bumper when it pops off!
Old 01-12-2010, 01:45 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
yes. college degree and pry bar.
just kinda slowly work it out. there isnt anything else holding it in, but be careful to not break anything. it'll take some muscle with finess
Old 01-12-2010, 01:54 PM
02Steve1990's Avatar
02Steve1990
02Steve1990 is offline
Old 01-12-2010, 02:04 PM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
There is a round locating plastic piece and there is a square plastic piece as well. If it hasn't ever been taken off, the square piece has tabs on it. You can just pull it out, or if you're feeling squirrley you can pull the plastic inner fender well out and release the tabs if you don't feel like breaking them. Then the light assembly should just slide out with ease.
Old 01-13-2010, 02:17 AM
Bradd_D's Avatar
Bradd_D
Bradd_D is offline
Thanks very much, guys.
Old 01-13-2010, 08:15 AM
EASTTEXASDODGE08's Avatar
EASTTEXASDODGE08
EASTTEXASDODGE08 is offline
pull it like a b!tch, its hard to do, feels like your gonna pull to hard but right when you think that it will come out.
Old 11-19-2010, 10:49 PM
Lebon2009's Avatar
Lebon2009
Lebon2009 is offline
whats the easiest way to get the headlight assembly off in an 07 without removing the fender? i cant find a good way to get to the 3rd bolt.....
Old 11-19-2010, 11:07 PM
Dunno207's Avatar
Dunno207
Dunno207 is offline
huh? I thought 06'+ was easier to get off.
Old 11-22-2010, 08:49 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
If you are talking about the bolt under the light, I use a 9 or 12" extension to get to it on mine
Quick Reply: How do you remove the headlight assembly?
