Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
92 dakota 3.9 water pump removal
Old 04-18-2005, 09:50 PM
shuey's Avatar
shuey
shuey is offline
Default 92 dakota 3.9 water pump removal
I noticed my fan having a lot of play when the belt is removed. I tried to get the fan assy. off and I never saw one like this before. Any advice on how to get it off and replace the water pump. Any help will be appreciated. Thanks
Old 04-20-2005, 01:56 AM
injmopar's Avatar
injmopar
injmopar is offline
Default RE: 92 dakota 3.9 water pump removal
If I remember right,put the belt back on and put a big wrench on the nut behind the fan. And smack the wrench with a 2x4.The impact will brake the nut loose before the belt can slip.
Old 04-20-2005, 03:49 AM
RP Racing940's Avatar
RP Racing940
RP Racing940 is offline
DOdge, in their infinite wisdom, decided to make you need a special tool to remove it. Like injn said, you can try that. Or you could put a pry bar under the shaft and pulley bolts to remove it that way. Just be carefull about the radiator.
Old 06-28-2005, 07:37 PM
qlty's Avatar
qlty
qlty is offline
On my 94 V6 3.9 I used an air chizel with a point bit and carefully placed the bit against one of the big nuts edges gave a couple shots with the air ,it loosened rigt up.It loosens ccwise.
Old 06-28-2005, 11:04 PM
914dakota's Avatar
914dakota
914dakota is offline
Some auto parts stores that have a loan a tool program have the tool that you need to get it off.
Quick Reply: 92 dakota 3.9 water pump removal
