Engine won't come up to temp
Old 01-03-2010, 07:29 PM
chevy468's Avatar
chevy468
chevy468 is offline
Default Engine won't come up to temp
My 99 Dodge Ram is not heating up. It will get as hot as about 150, but never any higher. I just replaced the thermostat with a 195 degree Stant, and radiator cap to no avail. The water pump is fairly new, installed last summer. I let it run for quite a while, and the upper radiator hose gets warm, almost hot as it should, but the lower is still cold. When the upper gets hot, the temp gauge is still reading about 150. I don't see any circulation in the radiator either.
Old 01-03-2010, 08:06 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
its not -0 where you're at is it ?
sounds like a bad t-stat. you could try a stove top water test to prove that it opens at 195. or just return it under warranty.
if the coolant entering the top is only 150, its pretty normal for it to exit the bottom cold again. especially in winter.
Old 01-04-2010, 01:00 AM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
does you heater get warm? guage could just be reading wrong
Old 01-04-2010, 01:05 AM
2001Ram's Avatar
2001Ram
2001Ram is offline
Does your check gauge light come on?
Old 01-04-2010, 01:42 AM
J415's Avatar
J415
J415 is offline
Did you install the stat pointing in the correct direction?
Old 01-04-2010, 08:19 AM
halfamil's Avatar
halfamil
halfamil is offline
Is your anti-freeze weak?
Old 01-04-2010, 09:58 AM
chevy468's Avatar
chevy468
chevy468 is offline
It is cold, in the low teens to high 20s. I did check the 195 stat I pulled out using the stove method, and it was opening at the correct temperature. It was installed in the correct direction as well. The antifreeze is a 50/50 mix as it should be. The heater in the truck gets warm, but not hot. The check engine light does not come on, and I know it works as well. Both heater core hoses are pretty warm as well. Thanks guys, I appreciate the help.
Old 01-04-2010, 10:36 AM
halfamil's Avatar
halfamil
halfamil is offline
Was the replacement t-stat a 195?
Old 01-04-2010, 12:00 PM
chevy468's Avatar
chevy468
chevy468 is offline
Yes it was..
Old 01-04-2010, 12:13 PM
halfamil's Avatar
halfamil
halfamil is offline
Check the antifreeze.Could be diluted from what was left in the engine.If it checks out to -40 F then start thinking about other things.Anything less than -40 F add pure anti-freeze.
Quick Reply: Engine won't come up to temp
