Oil filled Spark Plug Holes
Old 01-03-2010, 07:13 PM
rodknock95's Avatar
rodknock95
rodknock95 is offline
Default Oil filled Spark Plug Holes
I have read and read on this subject but havent found anything involving a 2.5 liter with this problem. I have a 2000 Stratus with the 2.5 and the spark plug holes fill up with oil and it eventually causes the plug wire to pop up. Does the gasket set come with those seals for those spark plug wells?
Blaze
Old 01-03-2010, 08:03 PM
pearl01stratcpe's Avatar
pearl01stratcpe
pearl01stratcpe is offline
Some do, some dont. Just make sure when you order a gasket set they come with them. You have to pull the valve cover off then place the seals on top of the spark plug tubes.
Old 01-03-2010, 08:28 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
The 2.5's are a simple O ring seal ... So most have them in the set ...
Old 01-04-2010, 01:41 PM
ratsttam's Avatar
ratsttam
ratsttam is offline
I just did mine about a year ago. Same exact issue, I had oil pooling around my plug wires. Autozone had two sets. One had the o-rings, the other did not. The pain in the butt was taking the intake off to get to the rear 3 plugs.
Don't overtighten the valve cover bolts.
This would be a great time to change the plugs/wires unless you've done that very recently.
https://dodgeforum.com/forum/dodge-s...asket-bad.html.
http://www.autozone.com/autozone/cat...andName=Felpro
Last edited by ratsttam; 01-04-2010 at 01:50 PM. Reason: Added links and information.
Old 12-22-2011, 11:39 AM
dacotahbuum's Avatar
dacotahbuum
dacotahbuum is offline
New Member
Default Oil in spark plug hole
Hey guys maybe you can help me out on this one. I have a 97 stratus with a 2.4 DOHC, It wouldn't start for me the other day (just turns over) so I started looking into things and discovered oil in one of my spark plug holes (#4) so thanks to your Forum I learned it was the gasket. I replaced all the gaskets and now it still won't start! Any ideas? I put new plugs in (gapped correctly). Ignition coil? Thanks for the help!
Old 12-22-2011, 03:44 PM
dacotahbuum
New Member
never mind guys, ignition coil! runs great agian
Quick Reply: Oil filled Spark Plug Holes
