Front axle rebuild anyone?
Old 01-03-2010, 03:13 AM
iwhitne's Avatar
iwhitne
iwhitne is offline
Default Front axle rebuild anyone?
Well.. as winter has set in I've noticed a few issues with my front axle.
First... there is fluid dripping on both front tires after truck has been sitting for 2 days...I figure this is the axle seals..
Second... metal crunching sound when 4x4 is engagued... figure this is the U jooints on the axle...
Third... very very loose steering and sometimes feels like the control arm is loose or something along those lines...
So... i figure I'm going to do some work and figure it will be cheaper to do it all at once...
axle seals/U joints/ball joints/alignment/fix loose steering
anyone have a clue on a good price with quality parts (no duracrap) and or speacial tools I will need and time frame?
I know there is a DIY for the steering but I really need to know if anyone has done the U-joints and how hard it is.. might just take it to a shop because I also need my drivers door fixed
Old 01-03-2010, 10:44 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
for the axle seals, i imagine you could get it done in about 6 hours or less. it took me a few days because i started late a couple times and got sidetracked a couple times, those fish were calling my name.
the u joints are easy but i'm not sure about rebuilding the double cardon section of the front shaft but i believe there is a DIY on pavementsucks.
Old 01-03-2010, 11:17 AM
iwhitne's Avatar
iwhitne
iwhitne is offline
any speacial tools needed?
Old 01-03-2010, 11:55 AM
dodgeboy7's Avatar
dodgeboy7
dodgeboy7 is offline
yea a welder i just got dont doing a set last night. I used my welder to make a 4 foot seal driver works great and now that i have it my next set of seals well take half the time.
Old 01-03-2010, 12:43 PM
Sheriff420's Avatar
Sheriff420
i used a piece of threaded rod with a washer the size of the new seal on one end and the head of a sledge hammer for the hammer part of my slide hammer on the passenger axle seal.
they say a 1 3/4" socket is the perfect size to drive in the driver side seal.
don't forget that the driver seal doesn't have a stop in the tube so it would be easy to drive it too far. my passenger seal did have a stop in the tube. so just make note of the depth before you pull the old ones out.
other than that, you'll need a dead blow hammer for making sure the carrier is seated good when you re-install it.
and you can either use prybars or a come along to get the carrier out. i lined the hitch on my dads truck up with the differential and put a small chain around the center of the carrier and had him slowly crank the come along while i was under there to catch the carrier.
oh yeah, penetrating fluid, 3/4" breaker bar, cheater bar for the breaker bar, 1 11/16" socket, torque wrench capable of 175 ft. lbs, a couple cotter pins, new diff fluid and rtv, 14mm 12pt. socket that will fit your torque wrench (i couldn't get the top bolt on the hubs with the 1/2-3/8" adapter so i bought a 1/2" drive socket) and the seals. a good scraper (the razor blade type) and some 400 grit sandpaper get the sealing surface nice and clean too.
Old 01-03-2010, 12:48 PM
iwhitne's Avatar
iwhitne
iwhitne is offline
I see... well I've been looking online at parts
going to replace the following
L/R Front axle seals, U-Joints,Upper/Lower ball joints,all steering components including tie-rods, and track bar.
I used rockauto.com and came up with about $750 in parts
Also tried autozone (duracrap) and came up with about $620
I was thinking about doing the Hubs too.. but that's like another $500
is there anything else I should do while I'm working on the front end?
Old 01-03-2010, 01:01 PM
Sheriff420's Avatar
Sheriff420
polyurethane boots and bushings
Old 01-03-2010, 03:47 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Timkin hub cost me 190 napa hub was 120 with a discount.
Quick Reply: Front axle rebuild anyone?
