knocking engine
Old 12-29-2009, 11:49 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
It will take care of the motor!
Old 01-29-2010, 07:56 AM
Donna'sDango's Avatar
Donna'sDango
Donna'sDango is offline
Okay, been through a couple of tanks of premium 93 now, knocking is still there.... I LOVE my (wifes) durango. And I don't have an abundance of $$$. The knocking only starts at. About 1500 rpms. It sounds much more prominently when accelerating quickly. Am I f*cked?
Old 01-29-2010, 11:55 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
what grade of oil are you running??? make sure you are using the correct weight, too thin oil can cause it (assuming it sounds like the start up tick),
Old 01-29-2010, 02:35 PM
Dislander's Avatar
Dislander
Dislander is offline
Recheck the base timing. pull timing two degrees at a time if it is set proper untill the knock/ping stops. Ignition advance is likely the cause of the ping. could just be a lot of carbon build up in the cumustion chamber but in theory the seafoam would have helped there.
Old 01-29-2010, 11:39 PM
hydrashocker
Indexing the distributor COULD help but the timing is controled by the PCM and not by manual placement of the distributor (although it must be indexed). The PCM can Advance and retard the timing. Also, try and figure out WHERE the tapping sound is coming from?
The best thing is to correctly Index it.
Old 01-30-2010, 08:39 PM
Donna'sDango
I've been running 10W40 oil. I'm lost on the indexing part,
Old 01-31-2010, 12:26 PM
mb98d's Avatar
mb98d
mb98d is offline
it sounds more like a rod knock or wrist pin to me if it is only happening at start up and when he just starts to accelerate.
Old 01-31-2010, 03:39 PM
hydrashocker
You are running the incorrect oil! You should be running 10W-30.
As for indexing the distributor:
Tips and Tricks PDF
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
Look in here about mid way down. It means placing the distributor in the best timing position to the crankshaft at TDC (Top Dead Center). This allows the PCM to acuratly change the advance and retarding of the timing and also helps with fuel mileage.
Quick Reply: knocking engine
