gas to diesel conversion?
Old 12-23-2009, 08:00 PM
CommanderTGK's Avatar
CommanderTGK
CommanderTGK is offline
Default gas to diesel conversion?
Just out of curiosity what would it take to convert my truck to a cummins turbo? Is it even possible? Advantages? Disadvantages?
Old 12-23-2009, 08:01 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
new rear end, new transfer case, tranny, motor, PCM, and probably more you'll need
advantages- cummins says it all
disadvantages- costly
Old 12-23-2009, 08:17 PM
torp74's Avatar
torp74
torp74 is offline
Since you already have a 2500 I don't believe you would have to have a new rear end. Don't know what tranny you have, but if it is a 47re you are good to go. Besides the engine itself you would obviously need the new pcm, and total fuel system as well. Big job. I say if you want a Cummins, start looking for a used truck on craigslist. It is the path of least resistance.
Old 12-23-2009, 08:31 PM
silverbullet-dodgeram's Avatar
silverbullet-dodgeram is offline
easiest way find a wrecked cummins and put ur body and the wrecked chaise
Old 12-23-2009, 10:46 PM
CommanderTGK
Does anyone know about how much that would cost for just labor? If I was to pick up a wrecked cummins that had just mostly body damage and dropped all the necessary parts including the engine into my truck?
Old 12-24-2009, 06:54 AM
olyelr's Avatar
olyelr
olyelr is offline
Probably more than what an entire truck with a cummins would cost.
If you really want a cummins (cant I don't blame you there), and don't plan on doing the swap yourself, I would suggest just buying a different truck. It will be cheaper in the long run.
Check out Superhawks build page on pavementsucks.com, he did this exact same swap several years ago and he's still working bugs out (and he knows his ****).
Old 12-24-2009, 06:59 AM
olyelr's Avatar
olyelr
olyelr is offline
Heres the link http://www.pavementsucks.com/board/t...Axles-complete
And yes, this was originally a half ton.
Old 12-24-2009, 07:07 AM
olyelr's Avatar
olyelr
olyelr is offline
While Im at it...
Yes, he does use it too
This one made me laugh... the ram in front of him is on 39.5" TSL's hahahahah
Old 12-24-2009, 08:20 AM
CommanderTGK
Thanks for the link! Looking into it...
Old 12-24-2009, 09:09 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
those are sick rams...
Quick Reply: gas to diesel conversion?
