removing the pinion shaft
Old 12-16-2009, 11:58 PM
Nathyne's Avatar
Nathyne
Nathyne is offline
Default removing the pinion shaft
I tried searching but my search doesn't seem to be working...
anyways i am having a hell of a time trying to get my pinion shaft out i removed the set bolt and after that ball my manual says is to remove pinion shaft... it is not stuck on the gears at all has a bit of movement but i just can't get the damn thing apart. ohh yes the set bolt came out whole aswell
any ideas?
thanks
Old 12-17-2009, 12:26 AM
Nathyne's Avatar
Nathyne
Nathyne is offline
on second inspection i was looking at the wrong bolt before lol, it snapped and is stuck in there any ideas on how to get it out?
Old 12-17-2009, 01:44 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Are you talking about the axle pinion shaft? If so then everything has to come out before you can take out the pinion. Check the FAQ for the service manual for a detailed instructions on it.
Old 12-17-2009, 11:02 AM
Nathyne's Avatar
Nathyne
Nathyne is offline
it's the pinion shaft in the rear differential that you need to remove to get the axles out
Old 12-17-2009, 11:50 AM
burntricer's Avatar
burntricer
burntricer is offline
OHHHHH the centershaft bolt...
if its broken, your going to fight with it more getting it out rather than pulling and changing the entire axle section...you could use an angle drill and a easy out
but its a *****.
Old 12-17-2009, 12:30 PM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
Mine had a nice groove worn in it from the spider gear, I just took a hammer and drift and beat it out..
Old 12-17-2009, 01:11 PM
burntricer's Avatar
burntricer
yeah, but thats the center pin. if the lock bolt is still in there, its threaded into the other side of the carrier housing after it goes through the carrier, your not gettin that sucker out easy
Old 12-18-2009, 11:43 AM
Nathyne's Avatar
Nathyne
Nathyne is offline
damn that was what i was afraid of. well i guess ill try the 90 drill and easy out...
thanks for the help
Old 12-18-2009, 11:44 PM
injmopar's Avatar
injmopar
injmopar is offline
When and if you can get the bolt out of the cross pin .You will need to mike the cross pin hole to see if it is oval .If you can find any difference ,toss the carrier.These newer carriers are softer than the old ones. This also happens in fwd trans. When the hole distorts it lets the pin move and shear the bolt. I have seen the pin slowly walk out and mill a grove in the transmition case. If it happens in a rear diff it is alot more violent .
Old 12-19-2009, 12:04 AM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
thanks for the help
I though you said the locking bolt came out as a whole (not broken)?
Broken cross pin bolts are a big problem in Ford rearends but I've worked on a lot and never managed to break one yet..
Quick Reply: removing the pinion shaft
