'04 Ram 1500 Quad Cab and towing?
Old 04-13-2005, 11:37 AM
Feralhog's Avatar
Feralhog
Feralhog is offline
Default '04 Ram 1500 Quad Cab and towing?
Greetings!
We own a 2004 Dodge Ram 1500 SLT with the 5.7L engine, towing package, 3.9x rear ratio. We have put a refundable deposit on a travel trailer with the following characteristics:
GVWR=7100#
GVW=5590#
Hitch Weight=856#
Base/Dry axle weight=4734#
I know its apples vs oranges and Dodge claims 8000+ pounds towing capacity, etc., etc.
My question is do the actual owners of similar Ram 1500s think I'll have trouble hauling this travel trailer?
Thank you!
Greg
5.7L
Old 04-13-2005, 11:56 AM
Duckmaniak's Avatar
Duckmaniak
Duckmaniak is offline
Default RE: '04 Ram 1500 Quad Cab and towing?
I have an '05 1500 with the Hemi and I pull a bumper pull horse trailer weighing in at 6500 lbs and have no problem what so ever. The only thing you might want to consider is if it is a tag-a-long type trailer (not a 5th wheel) , you might want a weight distributing hitch. Especially if the hitch weight is 856 lbs. One other thing, did you get the towing package on your 1500?
Duck
Old 04-13-2005, 12:06 PM
Feralhog's Avatar
Feralhog
Feralhog is offline
Thanks for your input.
I have a weight distribution system now (for a 24 ' trailer) and the dealer is going to upgrade it "free" to 1000 lbs bars.
The 1500 has the tow package.
We also have some hilly terrain around here (and most places one might camp at tend to also).
Thanks again!
Greg
Old 04-13-2005, 12:17 PM
Drew's Avatar
Drew
Drew is offline
you'll have a smile on your face when you hitch up, put it in gear and the thing takes off without you touching the gas pedal
happy trails
Old 04-13-2005, 01:12 PM
salomonskier's Avatar
salomonskier
salomonskier is offline
I have pulled much heavier things with no problem, i thinknyou should be fine.
Old 04-13-2005, 01:25 PM
horatio102's Avatar
horatio102
horatio102 is offline
ORIGINAL: Feralhog
Thanks again!
Greg
You're golden. Take it out of OD, use the distributing hitch, and consider airbags or overloads for the rear end of your truck and you won't have a problem.
Old 04-13-2005, 03:48 PM
Feralhog's Avatar
Feralhog
Feralhog is offline
Okay. Now I can display my ignorance. What the heck is "airbags or overloads"? First time I have heard those terms in regards to towing.
Thank you!
Old 04-13-2005, 04:41 PM
Drew's Avatar
Drew
Drew is offline
airbags just increase the hauling capacity of the suspension. also gives a better ride, and you can raise and lower the entire vehicle as well
overloads I would imagine would be adding in another leaf spring
Old 04-13-2005, 04:44 PM
Feralhog's Avatar
Feralhog
Feralhog is offline
That makes sense. I'm fairly new to hauling trailers so I was a bit lost.
I'll check into those.
Thank you!
Greg
Old 04-15-2005, 09:12 AM
Feralhog's Avatar
Feralhog
Feralhog is offline
Thanks for the info.
Anyone have any links to this air bag option should the trailer push my rear bumper to the ground?
Thanks!
Quick Reply: '04 Ram 1500 Quad Cab and towing?
