3.9 v6 MPG and Check engine light
Old 12-05-2009, 12:02 PM
Hammer Down's Avatar
Hammer Down
Hammer Down is offline
Default 3.9 v6 MPG and Check engine light
Hey, guys. I need to bug y'all on this side of the forum for a bit. My friend asked me to swap out the O2 sensor in his mom's 97 Dakota 3.9 liter V6 2WD. The complaint is that the check engine light is on and the code complains about the oxygen sensor. I'm also told that the truck is sucking gas worse than my Ram. Since the 3.9 in many aspects, is a miniature 5.9 Magnum, I looked at a couple of other things. I found that the cat rattles so I'm sure that's in need of replacement. I looked through the throttle body and saw that the intake had a thick oily residue on the bottom (worse than in mine before I did a hugh's plenum fix. There was also next to no oil in the engine. My not-so-professional opinion is that the plenum gasket has blown, sucking oil, killing fuel efficiency along with the cat and oxygen sensor.
How far off am I?
I just would like a second opinion before I have the old lady buy a bunch of stuff if it just needed the o2 sensor after-all.
On a side note, the truck has had less than stellar levels of maintainance. It has about 125,000 miles on it and judging from how the spark plugs were locked into place, I would say that they have not been changed in a very long time and an oil change is about 6000 miles over-due.
Old 12-05-2009, 01:43 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
Typically old/bad plugs will throw an o2 sensor code stating that the engine is lean. I would start there and let her know about the plenum gasket failure.
Old 12-05-2009, 02:52 PM
f0x672's Avatar
f0x672
f0x672 is offline
do the 02 sensors as well... get direct replacement, not the ones where to slice into the harness.. clean the throttle body, possibly replace the map sensor.. theres a big thread on this side, if i remember correctly, about the major increase in mpg replacing the map sensor.. when i repalced mine i gained about 2mpg, but that in turn with a clean throttle body, brand new plugs, wires, cap, and rotor.
Old 12-05-2009, 04:11 PM
bpark8824's Avatar
bpark8824
bpark8824 is offline
Sounds like that truck needs some TLC...
Old 12-06-2009, 11:01 AM
Hammer Down
No doubt! Thanks for the help, guys.
Old 12-06-2009, 01:57 PM
wink2873's Avatar
wink2873
wink2873 is offline
i'd say your diagnosis was very accurate. Its sucking in oil through the bad plenum, fouling spark plugs, fouling the O2'd and probably clogging the cat. The plenum gasket will have to be changed, and the 02's and the cat, and the spark plugs. I'd do a major seafoam treatment right before I changed the oil also. Run it through the vacuum lines, 1/3 of the can in the crankcase, and 1/3 of it in the gas. Just let it run long enough to get hot, then change the oil. Hopefully you can get out some sludge and clean up the combustion chambers a little too.
Old 12-06-2009, 04:46 PM
bpark8824's Avatar
bpark8824
Yeah, I agree with wink. Change the plenum gasket, and while you're at it, clean up the tb good. Run seaform through and change the oil and filter. While you are changing the plugs, a nice tune up would certainly help.
So....
-Change plenum gasket.
-Clean TB
- New o2's
- New cat
- Seaform, then change oil & filter
- New plugs, plug wires, cap, rotor, air filter.
- Clean the map sensor.
- reset the CEL
Do all of that and I think she'll run a TON better...
Quick Reply: 3.9 v6 MPG and Check engine light
