Heater only blows on High....
My heater only blows on high...None of the other settings work... I have read somewhere else that odds are the switch is going bad because the voltage isn't getting regulated properly. Is this so? And is so where is a good place to online to purchase a new switch or if I have to go the the dealership what kinda of prices do I expect to pay...
it sound like the blower motor resister
The blower motor resistor is mounted to the heater-A/C housing, under the instrument panel and just inboard of the blower motor. It can be accessed without removing any other components.
REMOVAL
REMOVAL
- Disconnect and isolate the battery negative cable.
- Unplug the blower motor resistor wire harness connector.
- Remove the screws that secure the resistor to the heater-A/C housing.
- Remove the blower motor resistor.
