Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Sponsored by:
Sponsored by: Mall of Georgia
Help with ashtray
Old 02-16-2004, 04:12 PM
joshkaos's Avatar
joshkaos
joshkaos is offline
Default Help with ashtray
I need help with my ashtray. Some change got in back of the ashtray and now it will not close. Does anyone know how to get in back of the ashtray so that I can get the change out?
Thanks,
Old 02-16-2004, 04:57 PM
Dodgegirl19's Avatar
Dodgegirl19
Dodgegirl19 is offline
Lady Administrator
Default RE: Help with ashtray
Well, I'm not sure what year you've got. I don't know if it's the same on the brand new trucks, but take off the dash trim piece and you'll see four screw holding in the ashtray, unscrew and the ashtray is free.
~Amanda
Old 02-16-2004, 05:04 PM
joshkaos's Avatar
joshkaos
joshkaos is offline
Thanks Dodgegirl19,
I have a 2002 Dodge Ram 1500 Quad Cab SB.
Is it a lot of work to get the dash trim off?
Old 02-16-2004, 05:18 PM
ditchdoc's Avatar
ditchdoc
ditchdoc is offline
On my 2003 Q/C you can pull the trim it's has push snap comes right off.
Old 02-16-2004, 05:20 PM
Dodgegirl19
Lady Administrator
Nope it's not hard, just don't yank at it... be gentle, it can be tough, but it's only held in by clips, easy to remove and reinstall.
Glad I could help!!
~Amanda
Old 02-16-2004, 05:23 PM
joshkaos's Avatar
joshkaos
joshkaos is offline
Ditchdoc and Dodgegirl19,
Thank you both very much, don't mean to be a pain but are the pull tabs on the whole dash trim itself and are the tabs on certain corners? Just don't want to screw anything up!
Thanks again,
Old 02-16-2004, 07:46 PM
ditchdoc's Avatar
ditchdoc
ditchdoc is offline
Mine are just around the ash tray it self.
Old 02-19-2004, 01:53 PM
ladyrebel32's Avatar
ladyrebel32
ladyrebel32 is offline
I have the '03 Ram...and my ashtray just pulls out. It will feel stiff at first but pull down at the same time and it should pop out. (Had a cigarette butt get behind mine and it did the same thing)
Old 02-19-2004, 04:13 PM
backdraft98's Avatar
backdraft98
backdraft98 is offline
I have a 2002 1500, Quad Cab SWB and had the same problem. The insert just slips out of the door that opens and then just pull the door out of the clips that hold it in place. Getting it back in takes a little longer but it is fairly easy.
Quick Reply: Help with ashtray
